I have a problem flashing the oranges. I flash it with a 32G SD card with Linux with a network cable directly to the switch. After the process is finished, I turn off the orange and remove the card and turn it on again, but the orange LED (communication) on the network card stops working. This occurs in every 10 oranges flashed, 1 or two this type of error occurs. What is the solution?
To debug the problem first we need to know about your setup and the steps to produce the problem. Apart from knowing that you are probably using Orange Pi 3 LTS, we know nothing about your setup. Like what image you are using and what kernel version you are on. Also there doesn't seem to be any logs shared. Please use armbianmonitor -u and share the url. If network is not available, you can also use armbianmonitor -U to dump logs to console and then share the same manually.
Linux orangepi3-lts 5.16.17-sun50iw6 #3.0.6 SMP Tue Aug 16 18:33:28 CST 2022 aarch64 aarch64 aarch64 GNU/Linux
Distributor ID: Ubuntu
Description: Ubuntu 22.04.2 LTS
Release: 22.04
Codename: jammy
Not even our kernel not even our OS, closing. In case you need help, you have a PM.
  • Igor locked this topic
Release: 22.04
Codename: jammy
Obs:
I recently tried the commands to update: sudo apt update and sudo apt upgrade, some started to work after that, but others still persist in the error of the network port not working after fleshing.
  • Werner locked this topic
Release: 22.04
Codename: jammy
Obs:
