orangeRK Posted January 3 Posted January 3 I have a problem flashing the oranges. I flash it with a 32G SD card with Linux with a network cable directly to the switch. After the process is finished, I turn off the orange and remove the card and turn it on again, but the orange LED (communication) on the network card stops working. This occurs in every 10 oranges flashed, 1 or two this type of error occurs. What is the solution?
Werner Posted January 3 Posted January 3 3 hours ago, orangeRK said: This occurs in every 10 oranges flashed, 1 or two this type of error occurs. What is the solution? Proper debugging. https://debug.armbian.de moved
Gunjan Gupta Posted January 3 Posted January 3 5 hours ago, orangeRK said: I have a problem flashing the oranges. I flash it with a 32G SD card with Linux with a network cable directly to the switch. After the process is finished, I turn off the orange and remove the card and turn it on again, but the orange LED (communication) on the network card stops working. This occurs in every 10 oranges flashed, 1 or two this type of error occurs. What is the solution? To debug the problem first we need to know about your setup and the steps to produce the problem. Apart from knowing that you are probably using Orange Pi 3 LTS, we know nothing about your setup. Like what image you are using and what kernel version you are on. Also there doesn't seem to be any logs shared. Please use armbianmonitor -u and share the url. If network is not available, you can also use armbianmonitor -U to dump logs to console and then share the same manually.
orangeRK Posted January 4 Author Posted January 4 Linux orangepi3-lts 5.16.17-sun50iw6 #3.0.6 SMP Tue Aug 16 18:33:28 CST 2022 aarch64 aarch64 aarch64 GNU/Linux Distributor ID: Ubuntu Description: Ubuntu 22.04.2 LTS Release: 22.04 Codename: jammy
Igor Posted January 4 Posted January 4 Not even our kernel not even our OS, closing. In case you need help, you have a PM.
orangeRK Posted January 9 Author Posted January 9 I have a problem flashing the oranges. I flash it with a 32G SD card with Linux with a network cable directly to the switch. After the process is finished, I turn off the orange and remove the card and turn it on again, but the orange LED (communication) on the network card stops working. This occurs in every 10 oranges flashed, 1 or two this type of error occurs. What is the solution? Linux orangepi3-lts 5.16.17-sun50iw6 #3.0.6 SMP Tue Aug 16 18:33:28 CST 2022 aarch64 aarch64 aarch64 GNU/Linux Distributor ID: Ubuntu Description: Ubuntu 22.04.2 LTS Release: 22.04 Codename: jammy Obs: I recently tried the commands to update: sudo apt update and sudo apt upgrade, some started to work after that, but others still persist in the error of the network port not working after fleshing.
Werner Posted January 9 Posted January 9 You are not using Armbian. Ask where you got the OS from you are actually using.
orangeRK Posted January 11 Author Posted January 11 I have a problem flashing the oranges. I flash it with a 32G SD card with Linux with a network cable directly to the switch. After the process is finished, I turn off the orange and remove the card and turn it on again, but the orange LED (communication) on the network card stops working. This occurs in every 10 oranges flashed, 1 or two this type of error occurs. What is the solution? Linux orangepi3-lts 5.16.17-sun50iw6 #3.0.6 SMP Tue Aug 16 18:33:28 CST 2022 aarch64 aarch64 aarch64 GNU/Linux Distributor ID: Ubuntu Description: Ubuntu 22.04.2 LTS Release: 22.04 Codename: jammy Obs: I recently tried the commands to update: sudo apt update and sudo apt upgrade, some started to work after that, but others still persist in the error of the network port not working after fleshing.
Werner Posted January 11 Posted January 11 User has been temporary suspended for repeated violation of our terms.
