I have a Logitech C920 webcam I am trying to use on my Radxa Zero.
I'm running Armbian 23.11.1 Bookworm 6.1.63 64-bit.
When I run v4l2-ctl -i /dev/video1 --list-formats to query the webcam, it errors out.
VIDIOC_S_INPUT: failed: Inappropriate ioctl for device
ioctl: VIDIOC_ENUM_FMT
        Type: Video Capture Multiplanar
        [0]: 'NM12' (Y/UV 4:2:0 (N-C))
It seems anything relying on v4l2 is also failing to work.
Anyone have ideas of what the issue may be?
Thanks!
FYI...If I use this webcam on a RaspberryPi 4 running Bookworm, it produces the following output and all v4l2 work.
Video input set to 0 (Input 1: Camera, ok)
        Type: Video Capture
        [0]: 'YUYV' (YUYV 4:2:2)
        [1]: 'H264' (H.264, compressed)
        [2]: 'MJPG' (Motion-JPEG, compressed)
You get anything from:
v4l2-ctl --list-devices
No, that does not work either.
The issue happens under "Armbian Bookworm    Minimal CLI".
Another fact I've found:
Since posting the original question, I tried "Armbian Jammy    Minimal CLI".
The camera works under Jammy.
So the issue seems specific to Armbian Bookworm.
(Note the camera also works under Raspberry PI's Bookworm.)
Hi! I'm new here too. I tested my webcam using webcammictest.io, and it worked fine, so the hardware seems okay. If you're encountering the "Inappropriate ioctl for device" error with v4l2-ctl, it might be due to driver compatibility issues or kernel differences. You could try using a different Armbian version, like Jammy, to see if that resolves the problem
