v4l2 Webcam Error "Inappropriate ioctl for device"
I have a Logitech C920 webcam I am trying to use on my Radxa Zero.
I'm running Armbian 23.11.1 Bookworm 6.1.63 64-bit.
When I run v4l2-ctl -i /dev/video1 --list-formats to query the webcam, it errors out.
VIDIOC_S_INPUT: failed: Inappropriate ioctl for device
ioctl: VIDIOC_ENUM_FMT
        Type: Video Capture Multiplanar
        [0]: 'NM12' (Y/UV 4:2:0 (N-C))
It seems anything relying on v4l2 is also failing to work.
Anyone have ideas of what the issue may be?
Thanks!
FYI...If I use this webcam on a RaspberryPi 4 running Bookworm, it produces the following output and all v4l2 work.
Video input set to 0 (Input 1: Camera, ok)
        Type: Video Capture
        [0]: 'YUYV' (YUYV 4:2:2)
        [1]: 'H264' (H.264, compressed)
        [2]: 'MJPG' (Motion-JPEG, compressed)
On 1/14/2024 at 1:06 PM, Igor said:
You get anything from:
v4l2-ctl --list-devices
No, that does not work either.
The issue happens under "Armbian Bookworm    Minimal CLI".
Another fact I've found:
Since posting the original question, I tried "Armbian Jammy    Minimal CLI".
The camera works under Jammy.
So the issue seems specific to Armbian Bookworm.
(Note the camera also works under Raspberry PI's Bookworm.)
