Screen goes black after starting kernel, i've installed the latest version of Armbian. Before that, there was no problem. I was using Armbian debian server
What kernel? What version? Based on those data I assume everything is ok.
Wrote on mobile phone
Everything is ok at starting, I see the "Armbian" logo in the middle of the screen, then logs come at the left corner of the screen. it goes black after "Starting kernel" log. It is latest Armbian. Original kernel.
If it is neccesary, i can record a video.
Do you get a login prompt? If you do, nothing is wrong, just boot log is apparently directed to serial console.
I can see that
After that it goes off, just like in this photo
cpu       1200 mhz allowed, 1200 mhz possible, 4 cores active
dram      624 mhz
hdmi/gpu  active
usb ports active
eth0      10Mb/s/Half, Link: no
wlan0     IEEE 802.11bgn  ESSID:"*******"  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency:2.432 GHz  Access Point: ******
          Bit Rate:150 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:****-****-****-****-****-****-****-****   Security mode:open
          Power Management:off
          Link Quality=89/100  Signal level=88/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0"
Dmesg log: http://s3.dosya.tc/server10/b5alqt/log.zip.html
Sorry about that, please click "INDIR" to download. Its turkish, if you want i can upload it somewhere else, or just put it here
It was working properly on previus build. And you are right, it is, and it should be supported. I'll try to use lower resolutions.
Result:
576i "input signal out of range"
720p50 not working
720p60 not working
Higher resolutions cant be subject on this monitor.
if your monitor is not of hdmi but of dvi type
then you need to use the -d switch in h3disp utility.
Thank you, finally. I hadnt read description of h3disp.
