For EVERYBODY on this 3ad:
Me and jock and orhers authors  know PERFECTLY that could be tedious ready ALL BUT ALL pages but the problem of fake printing on chips including CPU  have been discussed severals but  severals  times.
And many times has bene suggested to have AT LEAST a USB/TTL converter to interact with uart.
@Max Sterg
Let me understand : Is multitool booting ???
Posted (edited)
Sorry I didn't want to start a discussion about "fake printing", it was just a note for those wondering why I was asking for help here with an "Amlogic"
In any case UART log here: usb-uarth.txt I don't think it's useful though. After "Starting kernel..." I see video output, then it shuts down and starts booting again
EDIT:
UART log with ttyS2 as default console: usb-uart-dmesg.txt
Edited by handymenny
Add usb-uart-dmesg log
@Max StergAll the hints are suggesting that  you definitely have a S905L chip, not a rk322x one.
This thread is not suitable for you and multitool will never boot, I think there isn't any kind of support for S905L in armbian.
You'd better ask in this other forum: https://forum.armbian.com/forum/192-amlogic-cpu-boxes/
@handymennyYour Amlogic S905W is totally looking as a fake. In the photo the other printing of the other chips is in light gray over the dark gray of the plastic, but the S905W signature is much darker.
You can compare with @Max Sterg post just above, where his S905L has the same light gray printing over dark gray just like the other sorrounding chips.
Some front and back pictures of the board are useful, at least to understand what board you have (if it is an R29, it is already known they have problems). Also from the log I see you're using an image that is at least one year old.
Maybe also try with a newer image.
Posted (edited)
Is Apt-upgrade enough? I've already tried that. I've also tried using the latest (legacy) stable, apt upgrade and switch kernel. I tried latest nightly too
If you're referring to the uboot version, maybe it's because I've the 4.4 kernel on the emmc?
The only writings on the board are X96-mini and FDX 2029. Android reports the board as r30, but I don't know if it can be trusted
I don't know if it's useful, but I can boot into systemd's emergency mode, but not into rescue mode.
Note: by latest stable I mean the one available here: https://users.armbian.com/jock/rk322x/armbian/stable
@jock ok thank you my friend, I think there isn't any other forum with the S905L but i will double check, Is there any alike board like S905L? i mean is there any SAME board as S905L? at least i will try different versions !!!! 😜
@handymenny totally new board to me, never saw anything like that.
Ok, I got it about u-boot, then seeing 2021.04 is ok.
Did you already try the suggestion to add cpu-stability to overlays= line into /boot/armbianEnv.txt ?
I don't know what is the cause of the reboot, but surely that ttyS2 message is not related because it is usually one of the latest messages before prompting the usual login process and a lot happens between that message and the login prompt, it is just that it is does not produce any log data.
Do you see something like a crash dump and a stack trace before reboot? Maybe adding panic=20 to the kernel command line could delay the reboot and may tell you something more about the problem. (add an extraargs=panic=20 line in /boot/armbianEnv.txt)
Also you may try to rename the kernel modules directory from /lib/modules/<your-kernel-version> to anything different and see if you still have issues.
I'm just suggesting a very blind approach, because I really I have no clue about, and also because sudden reboots without a stack trace always at the same point is very unusual.
Posted (edited)
Other suggestions were not helpful, but this one was very helpful (I was going to recompile the kernel randomly disabling the subsystems/drivers)
The module causing the crash is rockchip_thermal, double checked by renaming it + blacklist in modprobe.d/blacklist.conf + modprobe rockchip_thermal
EDIT:
I tried to flip some bits in dtb/dts to make that driver incapable of issuing shutdowns. I found one that allowed me to load the driver: rockchip,hw-tshut-polarity = <0x00>
After this edit and once the driver is loaded, I can read the temperature and it is correct
5 hours ago, handymenny said:
EDIT:
Gotcha!
I think we've spotted the bad one!
I may guess that your board shutdown gpio has a reversed polarity, and thus the driver was immediately causing a shutdown because it was thinking your chip was overheating .@fukowaka may profit from this discovery, I will take a look into the dts and try to find a general solution to this, even because the legacy kernel is working right.
Thanks!!
Posted (edited)
Yes, this's the most interesting part.
I tried to see if there were any big differences between linux 4.4 and 5.10 (I also tried builds with 5.10) and I didn't find anything interesting in thermal management.
4.4 has rockchip_thermal inegrated (not an external module), right? I wonder if it's the cause of this strange behavior.
Honestly, I think that kind of shutdown can even be disabled, because the kernel should already be able to do thermal throttling and shutdown the system by itself when the temperature reaches a threshold. The shutdown of the rockchip_thermal module is an emergency shutdown that is triggered on an interrupt I may guess, so it is immediately executed and does not pass through the kernel subsystems, but actually is redundant.
If you have the chance to retrieve the original firmware dtb, it may be useful to get a look into to see if the polarity is set there.
Posted (edited)
X96-mini_rk322x_Android_Linux-3.10.dts
I tried to include rockchip_thermal in the 5.15 kernel, it just crashes 4-5 seconds after "Starting kernel...". Then I reversed the polarity and lowered the shutdown temperature (10°) and it crashed exactly after 4-5 seconds. So definitely my board needs a reversed polarity. I guess the newer driver does some initialization, thus setting a wrong initial state.
You could set an invalid polarity (rockchip_thermal.c#L1295) so that this mechanism is disabled. A reboot isn't so helpful in lowering temperatures anyway....
Hello. Good day! When I connect my box via wifi (chipset is ssv6051), I can't seem to communicate to it via SSH, or access admin web interface when I setup pihole.
The internet and network works well on the box through wifi, except for this.
On windows, I get "Destination host unreachable" error when I ping the box that is connected to wifi; however, when I try to ping my pc on the box (vice-versa), it works perfectly well.
Is  there any configuration that I need to modify, or this function only works through LAN?
Any help is really appreciated. Many many thanks!
Posted (edited)
@radiant98 I've the same problem and that's exactly what I'm debugging now.
The incoming broadcast/multicast traffic is "corrupted", I've no idea why. A simple test to check if it's the same issue: ping your pc from the tvbox and then try accessing ssh, it should work (for a few minutes).
With ethernet everything works perfectly.
@handymenny For what I had the chance to observe in the past, the ssv6051 was not answering to ARP requests sent on the broadcast MAC address, so after some idle period the interface becomes unreachable until some outbound traffic is made. This problem although can be the consequence of a more deep issue, and problems with broadcast/multicast traffic can be a quite plausible cause.
Posted (edited)
Yes, that's the consequence.
I did two tests, one with WPA2-PSK and another with an open network.
TEST 1 (WPA2-PSK)
Packets received by other LAN devices:
Spoiler
Frame 172416: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface \Device\NPF_{XXX}, id 0
    Section number: 1
    Interface id: 0 (\Device\NPF_{XXX})
        Interface name: \Device\NPF_{XXX}
        Interface description: Wi-Fi
    Encapsulation type: Ethernet (1)
    Arrival Time: Oct 31, 2022 21:30:23.706271000 ora solare Europa occidentale
    [Time shift for this packet: 0.000000000 seconds]
    Epoch Time: 1667248223.706271000 seconds
    [Time delta from previous captured frame: 0.571755000 seconds]
    [Time delta from previous displayed frame: 0.571755000 seconds]
    [Time since reference or first frame: 7696.139623000 seconds]
    Frame Number: 172416
    Frame Length: 42 bytes (336 bits)
    Capture Length: 42 bytes (336 bits)
    [Frame is marked: False]
    [Frame is ignored: False]
    [Protocols in frame: eth:ethertype:arp]
    [Coloring Rule Name: ARP]
    [Coloring Rule String: arp]
Ethernet II, Src: AA_xx:xx:xx (AA:xx:xx:xx), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
    Destination: Broadcast (ff:ff:ff:ff:ff:ff)
        Address: Broadcast (ff:ff:ff:ff:ff:ff)
        .... ..1. .... .... .... .... = LG bit: Locally administered address (this is NOT the factory default)
        .... ...1 .... .... .... .... = IG bit: Group address (multicast/broadcast)
    Source: AA_xx:xx:xx (AA:xx:xx:xx)
        Address: AA_xx:xx:xx (AA:xx:xx:xx)
        .... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)
        .... ...0 .... .... .... .... = IG bit: Individual address (unicast)
    Type: ARP (0x0806)
Address Resolution Protocol (request)
    Hardware type: Ethernet (1)
    Protocol type: IPv4 (0x0800)
    Hardware size: 6
    Protocol size: 4
    Opcode: request (1)
    Sender MAC address: AA_xx:xx:xx (AA:xx:xx:xx)
    Sender IP address: 192.168.9.233
    Target MAC address: 00:00:00_00:00:00 (00:00:00:00:00:00)
    Target IP address: 192.168.9.244
Frame 172417: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface \Device\NPF_{XXX}, id 0
    Section number: 1
    Arrival Time: Oct 31, 2022 21:30:24.197854000 ora solare Europa occidentale
    Epoch Time: 1667248224.197854000 seconds
    [Time delta from previous captured frame: 0.491583000 seconds]
    [Time delta from previous displayed frame: 0.491583000 seconds]
    [Time since reference or first frame: 7696.631206000 seconds]
    Frame Number: 172417
    Type: ARP (0x0806)
    Hardware size: 6
    Protocol size: 4
    Opcode: request (1)
Frame 172418: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface \Device\NPF_{XXX}, id 0
    Section number: 1
    Arrival Time: Oct 31, 2022 21:30:24.689007000 ora solare Europa occidentale
    Epoch Time: 1667248224.689007000 seconds
    [Time delta from previous captured frame: 0.491153000 seconds]
    [Time delta from previous displayed frame: 0.491153000 seconds]
    [Time since reference or first frame: 7697.122359000 seconds]
    Frame Number: 172418
    Type: ARP (0x0806)
    Hardware size: 6
    Protocol size: 4
    Opcode: request (1)
Packets received by ssv6051:
Spoiler
Frame 64: 66 bytes on wire (528 bits), 66 bytes captured (528 bits) on interface wlan0, id 0
    Section number: 1
    Interface id: 0 (wlan0)
        Interface name: wlan0
    Arrival Time: Oct 31, 2022 21:30:23.863956722 ora solare Europa occidentale
    Epoch Time: 1667248223.863956722 seconds
    [Time delta from previous captured frame: 0.573442855 seconds]
    [Time delta from previous displayed frame: 0.573442855 seconds]
    [Time since reference or first frame: 45.014632027 seconds]
    Frame Number: 64
    Frame Length: 66 bytes (528 bits)
    Capture Length: 66 bytes (528 bits)
    [Protocols in frame: eth:llc:data]
    [Coloring Rule Name: Broadcast]
    [Coloring Rule String: eth[0] & 1]
IEEE 802.3 Ethernet
    Length: 52
Logical-Link Control
    DSAP: Unknown (0x7d)
        0111 110. = SAP: Unknown
        .... ...1 = IG Bit: Group
    SSAP: NULL LSAP (0x01)
        0000 000. = SAP: NULL LSAP
        .... ...1 = CR Bit: Response
    Control field: I, N(R)=80, N(S)=0 (0xA000)
        1010 000. .... .... = N(R): 80
        .... .... 0000 000. = N(S): 0
        .... .... .... ...0 = Frame type: Information frame (0x0)
Data (48 bytes)
Frame 65: 66 bytes on wire (528 bits), 66 bytes captured (528 bits) on interface wlan0, id 0
    Section number: 1
    Arrival Time: Oct 31, 2022 21:30:24.355487586 ora solare Europa occidentale
    Epoch Time: 1667248224.355487586 seconds
    [Time delta from previous captured frame: 0.491530864 seconds]
    [Time delta from previous displayed frame: 0.491530864 seconds]
    [Time since reference or first frame: 45.506162891 seconds]
    Frame Number: 65
    [Protocols in frame: eth:llc:x25:data]
IEEE 802.3 Ethernet
    Length: 52
    DSAP: ISO 8208 (X.25 over 802.2) (0x7e)
        0111 111. = SAP: ISO 8208 (X.25 over 802.2)
        .... ...0 = IG Bit: Individual
X.25
Data (45 bytes)
<Frame 66: 66 bytes on wire (528 bits), 66 bytes captured (528 bits) on interface wlan0, id 0
    Section number: 1
    Arrival Time: Oct 31, 2022 21:30:24.847014658 ora solare Europa occidentale
    Epoch Time: 1667248224.847014658 seconds
    [Time delta from previous captured frame: 0.491527072 seconds]
    [Time delta from previous displayed frame: 0.491527072 seconds]
    [Time since reference or first frame: 45.997689963 seconds]
    Frame Number: 66
IEEE 802.3 Ethernet
    Length: 52
    DSAP: ISO 802.2 (0x7f)
Data (48 bytes)
TEST 2 (Open)
Packet sent to Brodcast:
Spoiler
Frame 2152: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface \Device\NPF_{XXX}, id 0
    Section number: 1
    Arrival Time: Nov  1, 2022 12:24:49.413379000 ora solare Europa occidentale
    Epoch Time: 1667301889.413379000 seconds
    [Time delta from previous captured frame: 0.008009000 seconds]
    [Time delta from previous displayed frame: 1.848025000 seconds]
    [Time since reference or first frame: 114.428035000 seconds]
    Frame Number: 2152
Ethernet II, Src: BB:xx:xx:xx (BB_xx:xx:xx), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
    Source: BB:xx:xx:xx (BB_xx:xx:xx)
        Address: BB:xx:xx:xx (BB_xx:xx:xx)
    Type: ARP (0x0806)
    Hardware size: 6
    Protocol size: 4
    Opcode: request (1)
    Sender MAC address: BB:xx:xx:xx (BB_xx:xx:xx)
    Sender IP address: 192.168.43.118
    Target IP address: 192.168.43.60
Packet received by ssv6051:
Spoiler
Frame 146: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface wlan0, id 0
    Section number: 1
    Arrival Time: Nov  1, 2022 12:24:49.359594497 ora solare Europa occidentale
    Epoch Time: 1667301889.359594497 seconds
    [Time delta from previous captured frame: 0.174150059 seconds]
    [Time delta from previous displayed frame: 1.848057094 seconds]
    [Time since reference or first frame: 42.616040768 seconds]
    Frame Number: 146
Ethernet II, Src: BB_xx:xx:xx (BB:xx:xx:xx), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
    Source: BB_xx:xx:xx (BB:xx:xx:xx)
        Address: BB_xx:xx:xx (BB:xx:xx:xx)
    Type: ARP (0x0806)
    Hardware size: 6
    Protocol size: 4
    Opcode: request (1)
    Sender MAC address: BB_xx:xx:xx (BB:xx:xx:xx)
This leads me to conclude that the issue is decrypting broadcast packets (also because unicast ARP works). I'm not very familiar with wpa2, but I remember that they are encrypted differently
Some questions: Do you know if "official" Android roms have this issue? Does the other driver, svv6x5x, work with ssv6051p?
About the android roms, I have no direct experiences but I may guess the same issue applies because the "original" driver in the legacy 4.4 rockchip kernel also behaves the same.
The driver working on mainline kernel is nothing more than an adaptation from the legacy one.
The other driver ssv6x5x, despite the name matching, does not work with ssv6051p.
Me and @ilmich inspected both of them. We found that some parts are significantly different, and the result is ssv6x5x driver works only with ssv6256p chip (common on some "5G" boards) and ssv6051 driver works only with ssv6051p chip.
Adapting ssv6x5x to work on ssv6051p apparently is not a trivial task, and is complicated by the lack of internal documentation.
@handymenny Maybe it is a makefile configuration option. Double check the kernel running on your android installation, because the driver in the rockchip 4.4 repository looks like an adaptation from something from kernel 3.x ported to 4.4 and then later ported by us to 5.x, so it could have happened something in the process has been lost.
@handymenny hmmm, that line is very interesting! To let things work on mainline kernel, hw encryption and decryption have been disabled and everything is handled by the mac80211 layer in the kernel, which has fast enough algorithms to provided enough throughput without taxing the system too much. Maybe that block inside the ifdef is not compiled because the macro is not defined.
Unfortunately the driver is filled with such ifdef conditionals which are very hard to track.
Posted (edited)
Hi. Someone could help me with running Linux on my tv box MXQ Pro 4k 2gb RAM on the rk3229 processor. During the whole day I tried many options, looked at a lot of manuals, but did not get a result.
Initially, I wanted to run Linux from a memory card. But none of the images from the link above started. My TV box just won't start. The monitor enters the HDMI/Analog mode several times and goes into sleep mode.
Now I have installed a multitool on the memory card and started a backup. Although the backup is working, but my monitor is constantly flashing. I also don't know what it's related to
Edited by Orcus
hi @handymenny, benvenuto nel club 😃
congratulations on your findings, as @jock said we managed to get wifi running on new kernels, but for me a lot of things are obscure.
As for Android from sd card, technically it's possible. Never tried, but if you have a backup I think a dd to the sd card is enough.
From an update image it's more complicated because you should explode it with the tools and flash the various pieces (boot, system, userdata) with the right offsets.
@handymenny Cool, thanks! Maybe the broadcast decrypt can be fixed adding a proper -DUSE_MAC80211_DECRYPT_BROADCAST directive in the kernel module makefile nearby the other conditionals that relate to hardware/software encryption and decryption, without hardcoding the conditional.
Anyway thanks, do what you prefer and if you open a pull request I will accept and rebuild the armbian patches to fix the problem ;)
