jock Posted July 2 Author Share Posted July 2 6 hours ago, GSAR said: I followed your advice, but my TV BOX isn't responding when I press the reset button (located on the AV port). It seems like the RK3228A isn't recognizing any type of USB device, including the Male to Male USB cable. I've tried keyboards and mouses, but none of them are working at all. Sorry, forgot to mention that you have to plug the male-to-male cable in the OTG port; other ports won't work. That's the maskrom mode. Anyway you can try to boot armbian from sdcard 0 Quote Link to comment Share on other sites More sharing options...
GSAR Posted July 3 Share Posted July 3 (edited) Hello, aswering for you guys. @fabiobassa I'm unsure if the power surge damaged the USB subsystem. Is there any way to determine or repair it? @jock Sorry, but will this type of male-to-male USB cable in the image below work? It's what I have. I've attempted to boot using Armbian from the SD card, but it continues to display only a black screen and doesn't boot. Edited July 3 by GSAR Uncompleted message 0 Quote Link to comment Share on other sites More sharing options...
Blyato Posted July 4 Share Posted July 4 (edited) edited Edited July 4 by Blyato miss sent 0 Quote Link to comment Share on other sites More sharing options...
Blyato Posted July 4 Share Posted July 4 On 6/8/2024 at 11:04 PM, Blyato said: I sent them a message, even sent an email and a whatsapp to the manufacture ( junuo ? hehe) , will see if I get a reply, google sadly doesn't help as seems it's the latest version of the board (v3.0), I really want to make this wifi work 😂 The thing about SBC is that I already have one, the thing is that I spent some good time searching for a chip that would have multiple usb hosts instead of just one, and that's not easy to find, specially not below 50 euros, I came across the rk3228, that somehow is available at those tv boxes :(. Vendor sadly never replied, got in touch with the manufacture, their sales gave me a whatsapp number for tech department but never got a reply there, sad By the way, is there a way of making it boot from SD card? Armbian takes a long time to boot from the eemc it seems. 0 Quote Link to comment Share on other sites More sharing options...
RaptorSDS Posted July 4 Share Posted July 4 vor 5 Minuten schrieb Blyato: By the way, is there a way of making it boot from SD card? Armbian takes a long time to boot from the eemc it seems. wirte the armbian image to SD Card and than insert and start , than it should boot from SD card like the multitool i had nowadays 4 of this box, one old AMlogic s802 ( over 5 years in use with armbian scan and printserver) ) 1 xrk322x that work out of the box with armbian , one rk322x with resolder wifi from wired china chip to rtl8723ds , and now a rk3328 with android ( sadly sd card is on wrong sdio port) 2 Quote Link to comment Share on other sites More sharing options...
Blyato Posted July 5 Share Posted July 5 (edited) On 7/4/2024 at 7:40 PM, RaptorSDS said: wirte the armbian image to SD Card and than insert and start , than it should boot from SD card like the multitool i had nowadays 4 of this box, one old AMlogic s802 ( over 5 years in use with armbian scan and printserver) ) 1 xrk322x that work out of the box with armbian , one rk322x with resolder wifi from wired china chip to rtl8723ds , and now a rk3328 with android ( sadly sd card is on wrong sdio port) ty ! I thought by changing to SD card would help, but seems I fell into the same issue I was having, long boot times (5min~ or even more). I did systemd-analyze and got this: 2min 6.998s systemd-random-seed.service 2min 6.462s armbian-zram-config.service 13.093s NetworkManager-wait-online.service 4.494s armbian-ramlog.service 4.194s NetworkManager.service 3.418s sysfsutils.service 3.333s systemd-logind.service 3.272s dbus.service 2.759s dev-mmcblk0p1.device 2.030s systemd-journal-flush.service 1.458s alsa-restore.service 1.404s rsyslog.service 1.329s e2scrub_reap.service 1.323s sysstat.service 1.182s user@1000.service 1.005s systemd-journald.service 1.002s systemd-udev-trigger.service 933ms systemd-resolved.service 849ms chrony.service 800ms keyboard-setup.service 516ms systemd-udevd.service 427ms nginx.service 401ms ssh.service 343ms dev-mqueue.mount 336ms sys-kernel-debug.mount 323ms fake-hwclock.service 299ms wpa_supplicant.service 299ms kmod-static-nodes.service 297ms systemd-binfmt.service Anybody saw this issue before? Also have been facing issue with HDMI, tried to add video tag on extratags on armbian env , it appears on xrandr -q but yeah, not even terminal or anything appears on boot.... This is the armbian monitor output link Edited July 5 by Blyato another issue xd 0 Quote Link to comment Share on other sites More sharing options...
Leo Luiz Posted July 6 Share Posted July 6 I'm using balenaEtcher to burn the multitool image into a flash drive, but it ends with a partition of about 396MB. The linux image is about ~900MB uncompressed so there's no space left on the partition to move the distro file into the images folder. I also tried unetbootin and it doesn't create the images folder. What are my options? (I can't do SD card). Thank you. 0 Quote Link to comment Share on other sites More sharing options...
RaptorSDS Posted July 6 Share Posted July 6 vor 1 Minute schrieb Leo Luiz: 'm using balenaEtcher to burn the multitool image into a flash drive, but it ends with a partition of about 396MB. The linux image is about ~900MB uncompressed two methods , 1. boot image first than automatic resize to bigger size ( most of the drive) , than put your image on card 2. use the compressed image of armbian on the sd card , the multotool also can use zip and tar and tar.xz and tar.gz 2 Quote Link to comment Share on other sites More sharing options...
Mikee Mike Posted July 7 Share Posted July 7 Hi All, Im having an issue with my rk3228. Multitool and most (if not all) of the stable armbian (both sd card and emmc) keeps my unit shut down after 1 minute. Same with @hexdump issue 3 or 4 yrs ago. I tried to research the issue but came up nothing. I got a little success when I used the multitool with old tee img. It doesnt shut down when im using that. Its probably the trust.img but im not 100% sure and I also dont know how to replace or change the trust.img in the armbian build.. Hope someone can help me or point me to the right direction.. Cheers, m 0 Quote Link to comment Share on other sites More sharing options...
Emilio Peña Posted July 10 Share Posted July 10 Please, Does anyone know how to have Armbian / Multitool for RK3228 / RK3228H or if it is compatible with any jock tutorial? Thank you 0 Quote Link to comment Share on other sites More sharing options...
imabou Posted July 16 Share Posted July 16 hello guys i have couple of boxes flashed with armbian jammy I got this issue of box boot to initramfs on sudden reboot or power loss and after I do this command after doing a mount/mmcblk2p1 command and rebooting the box the box runs normally. is there way to make the system read only of fix this issue on the startup ? 0 Quote Link to comment Share on other sites More sharing options...
RaptorSDS Posted July 16 Share Posted July 16 Am 10.7.2024 um 21:32 schrieb Emilio Peña: Does anyone know how to have Armbian / Multitool for RK3228 / RK3228H or if it is compatible with any jock tutorial? normally all are compatible but there are no 3228H , there is 3328A and 3228B and 3229 (all same ) but like we say always there are so many creepy box outside with so many variant hardware and HW quality there are always some issue . you can follow the tutorials 0 Quote Link to comment Share on other sites More sharing options...
Mikee Mike Posted July 17 Share Posted July 17 Hi @jock, what is the difference between latest multitool and the multitool with old tee img? Thanks in advance! 0 Quote Link to comment Share on other sites More sharing options...
jock Posted July 17 Author Share Posted July 17 @Mikee Mike the difference is that the "old tee" is a very old TrustOS proprietary and closed source binary from rockchip that does not put the board in standby after one minute. On the other side it has several compatibility issues among various boards. The "regular" multitool has a newer TrustOS that works fine for the majority of the boards around, but on some very rare boards will put them in standby after one minute. As long as they are closed source binaries, we don't know why that happens. 1 Quote Link to comment Share on other sites More sharing options...
Mikee Mike Posted July 20 Share Posted July 20 Thank you for the response @jock. Is it possible to use that old TrustOS in an Armbian? Or maybe is there an existing Armbian that uses that old TrustOS? Thanks again! 0 Quote Link to comment Share on other sites More sharing options...
jock Posted July 20 Author Share Posted July 20 2 hours ago, Mikee Mike said: Thank you for the response @jock. Is it possible to use that old TrustOS in an Armbian? Or maybe is there an existing Armbian that uses that old TrustOS? Thanks again! No, because it is old and buggy. It would perhaps let some boards work but it will break many others. The best option is to use the opensource trust os, but it lacks some features (DDR frequency scaling, virtual poweroff most of all). 1 Quote Link to comment Share on other sites More sharing options...
Renan Urata Posted July 23 Share Posted July 23 hi guys, tryied to short the 7 8 pin no lucko... used this schema of dot on chip as first pin and then mesuared voltages to check if there was a 0v and a 1.8v pins, tried a bunch to make pc recognize usb device, no lucko... Did a flash from linux to armbian with no sucess and then I got to boot with usb, no sd, with multitool and flashed some armbian 5.15 and 6.40 with success, then I wanted to try out a android image because performance was really poor on linux, could not even reproduce videos with out stutters on mpv, browser experience was horible. Then after using multitool to flash LibreELEC-RK322x.arm-9.2-devel-20200427220805-b7186bc-rk3229-v884k, it bricked my board... by the way this is a ddr3 board and this image seens to be ddr3 also, don~t know why it bricked, I tought that I could reflash with multitool if something bad happened since it was ok with armbian. One thing to note is that after the first flash attempt with armbian via linux, I could not enter flash mode by usb with computer like before, only with multitool... Can some one help me please? 0 Quote Link to comment Share on other sites More sharing options...
geraldine adi Posted August 6 Share Posted August 6 (edited) While using a multitool on the RK3229Q 221P V1.3 board to perform a backup, the screen suddenly went blank midway through the process. What could be causing this issue? my device is MXQ PRO 4K 5G Edited August 6 by geraldine adi 0 Quote Link to comment Share on other sites More sharing options...
bellad Posted August 12 Share Posted August 12 hello géraldine adi , i've same box ,did you find the armbian firmware ?? 0 Quote Link to comment Share on other sites More sharing options...
bellad Posted August 18 Share Posted August 18 hello , i've install armbian on my box tv rk3229 with Multitool and Armbian_24.2.5_Rk322x-box_jammy_current_6.6.22_minimal.img.xz my problem is error : SSV WLAN driver ssv6200: calibation fail after 1 iterations [ 74.050778] SOS!SOS! [ 74.050797] SSV WLAN driver ssv6200: Failed to initialize mac, ret=-1 [ 74.075988] SSV WLAN driver ssv6200: chip id: SSV6006C0 , tag: 0 [ 74.116548] ERROR!!Please check interface! [ 74.116580] [0xca000200]: 0x0c000000!=0x00000000 i've put in /etc/modprobe.d/ssv6051.conf options ssv6051 stacfgpath=/lib/firmware/ssv6051-wifi.cfg but no work can you help , please 0 Quote Link to comment Share on other sites More sharing options...
jock Posted August 18 Author Share Posted August 18 @bellad unsupported chip, there is nothing to do 🤷♂️ 0 Quote Link to comment Share on other sites More sharing options...
bellad Posted August 18 Share Posted August 18 thank's , but i no understand with lsmod ssv6051 exist !! Module Size Used by snd_soc_hdmi_codec 16384 1 snd_soc_spdif_tx 12288 1 ir_nec_decoder 12288 0 gpio_ir_recv 12288 0 cpufreq_dt 12288 0 snd_soc_simple_card 16384 0 snd_soc_simple_card_utils 20480 1 snd_soc_simple_card ssv6051 151552 0 dw_hdmi_i2s_audio 12288 0 dw_hdmi_cec 12288 0 hantro_vpu 237568 0 rockchip_vdec 65536 0 lz4hc 12288 0 rockchip_rga 20480 0 rockchip_iep 16384 0 lima 40960 0 v4l2_vp9 20480 2 rockchip_vdec,hantro_vpu v4l2_h264 12288 2 rockchip_vdec,hantro_vpu videobuf2_dma_contig 16384 3 rockchip_iep,rockchip_vdec,hantro_vpu gpu_sched 24576 1 lima v4l2_mem2mem 20480 4 rockchip_iep,rockchip_vdec,hantro_vpu,rockchip_rga lz4 12288 0 snd_soc_rk3228 12288 1 snd_soc_rockchip_spdif 12288 2 snd_soc_rockchip_i2s 20480 4 rockchip_thermal 20480 0 snd_soc_core 159744 7 snd_soc_spdif_tx,snd_soc_rockchip_spdif,snd_soc_rockchip_i2s,snd_soc_hdmi_codec,snd_soc_simple_card_utils,snd_soc_rk3228,snd_soc_simple_card snd_pcm_dmaengine 12288 1 snd_soc_core snd_pcm 94208 4 snd_pcm_dmaengine,snd_soc_hdmi_codec,snd_soc_simple_card_utils,snd_soc_core snd_timer 28672 1 snd_pcm dw_wdt 12288 0 rk_crypto 24576 0 snd 57344 4 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm crypto_engine 12288 1 rk_crypto soundcore 12288 1 snd zram 28672 3 binfmt_misc 16384 1 sch_fq_codel 16384 2 fuse 114688 1 ip_tables 24576 0 gpio_keys 16384 0 0 Quote Link to comment Share on other sites More sharing options...
fabiobassa Posted August 18 Share Posted August 18 (edited) @bellad 6200 Is not 6051 neither 6052 or other Is Just 6200 !!! And even It loads ssv6051 module, the 6200 chip Is unsupported as @jock already said Edited August 18 by fabiobassa 0 Quote Link to comment Share on other sites More sharing options...
bellad Posted August 18 Share Posted August 18 ah ok , thank you , I'm going to test a usb key wifi 1 Quote Link to comment Share on other sites More sharing options...
bellad Posted August 18 Share Posted August 18 i see in /lib/firmware/ aic8800 , i've this in usb key how to install it ?? 0 Quote Link to comment Share on other sites More sharing options...
RaptorSDS Posted August 18 Share Posted August 18 vor 34 Minuten schrieb bellad: aic8800 why this , i thing most of usb wifi adapter ( WIFI N or AC at 2.4GHZ ) are realtek 81xx or some RTK88xx , that are good support and already inside this armbian ,also some Broadcom USB things . please be arware most of 5GHZ WIFI AC ( dual Mode) are not as good supported at linux 0 Quote Link to comment Share on other sites More sharing options...
hfrts Posted August 23 Share Posted August 23 (edited) Hello there! I'm in possession of 12 different models of RK3228 TV Box devices. While I'm having varying degrees of success with current Armbian-community distributions (wi-fi compatibility is iffy, performance is very limited), as I troubleshoot I keep wondering about the same question: how can I accurately find out my correct led-config. Is it the board footprint? Is there documentation on this aspect? Edited August 23 by hfrts 0 Quote Link to comment Share on other sites More sharing options...
jock Posted August 23 Author Share Posted August 23 @hfrts hello! First of all: no documentation from the manufacturs of any kind. Cheap tv boxes come without any kind of documentation: they are dirty cheap hardware with barely working software. The board footprint/silkscreen is indeed the first thing to look for to find the matching led-config: all known boards are listed within the rk322x-config script. If your board is not listed, then the stock firmware (or its device tree) and photos of the board most of the time are enough to properly match an existing led-config with the board or create a new led-config for a new board. 1 Quote Link to comment Share on other sites More sharing options...
fabiobassa Posted August 23 Share Posted August 23 (edited) @hfrts hello First of all and following the @jock's answer and the general rule of thumb of this 3ad I suggest post some photos of board and even better uart logs for every board. Second are well known general problems with inside wifi chips Third when you say " performance is very limited....." are you referring to wifi performance or overall performance of the box? Performance of wifi is limited to 24/26 mbs since the internal chip often is just one chain tx/rx sock ( maximum is 54 but this speed is avaible on double chain socks ) If " performance is very limited....." is referred to overall performance of the box, well try consider its hardware specs and what is the purpose you use the box for @jock... "they are dirty cheap hardware..." .........that costed to you, me and all other friends hundred of sleepless nights LOL 😅 Edited August 23 by fabiobassa 0 Quote Link to comment Share on other sites More sharing options...
striga Posted September 22 Share Posted September 22 Hello, I have this issue that whenever I update to latest kernel, HDMI screen does not work. I am using a rk3228a tv box, it does work fine with 6.1.18 kernel. Any thoughts on this issue, or how to solve it? Many thanks beforehand. 0 Quote Link to comment Share on other sites More sharing options...
