On 7/31/2025 at 8:40 AM, lebestnoob said:
I've started using an MXQ-4K box as a file server, but writing files over the network is slow, with speeds in the 3-5 MB/s range. Reads cap out at the fast ethernet link speed (~11 MB/s). I don't believe there's a CPU, disc, or RAM bottleneck as the speeds are the same regardless of file size or transfer protocol as SMB, FTP, and WebDAV all give me the same speeds, and checking in htop, they are never at 100%. These speeds are also observed when downloading a file from another device on the local network using wget or aria2 while sshed into it, with faster speeds on other devices. As far as I can tell, iostat doesn't suggest high io wait times are the culprit. If it matters, I'm writing to an external USB HDD, but the write speeds are the same when writing to the SD card through the network, which makes me believe this is not an issue. If I write a ~1.0GB file using dd to the HDD while sshed into it with `dd if=/dev/random of=/mnt/disk/tmp.bin bs=64k count=16500 conv=fdatasync`, it gives a local disk speed of ~20 MB/s, which is more than enough to saturate the 100 mbps link. Has anyone else experienced similar results? Are the slow network speeds just a limitation of the onboard nic/hardware? I'm open to suggestions.
what filesystem your drive using? usually if its WIndows Filesystem, that's where you get some performance penalty and NTFS is the one being the worst of all. Last time I tried using a ext4 formatted usb3 flash drive and was able to read/write to drive at 11MB/sec over wired LAN, no tweaks on samba server were done other than setting up some shares.
I'm using an ext4 formatted 1TB drive, connected with a usb 3.0 ASMedia SATA controller. The drive reads and writes faster on other machines connected with the same adapter, so I'm confident it's not the hard drive or adapter. I also tried using BTRFS on the drive and it provides similar results. Now that I'm thinking about it, could it be the uas driver? I'll have to experiment with that.
this device has only usb2.0 , also when usb3.0 connector only usb2.0 pinout . also lan is most only 100mbit still with 1gbit label ,  the interface by chip only 100mbit so 11MB/s are in spec
Posted (edited)
its probably just your client side OS. try using the "use sendfile = yes" option on your smb.conf and see if theres performance improvement.
else, try using the legacy image (if your board is old enough to support it) as that one im using.
Edited by remlei
Posted (edited)
Hello, I really messed up, flashed on eMMC a rk3399 armbian image on my rk322x and now the LED is just blue with a hint of red, tried to short the eMMC 7-8th pins/reset button+usb but nothing.
The device doesn't boot form sd card either, neither multitool nor any flashed image, just stuck on blue LED.
I really don't know what to do.
Edited by BernardoT
vor 1 Stunde schrieb BernardoT:
that because this is the wrong thread , here we are at Rk322x ,also our multitool are the wrong one , maybe multitool for rk33xx helps
Edited my post for clarification, I've flashed a 3399 image on my 322x
Hello
Then you're doing it wrong. Bypassing the eMMC shorting the CLK pin to ground will definitely force the boot from sdcard, or fall into maskrom mode if no sdcard is in the slot.
I wonder what debug info is prompted on the serial port (if any) and if the device is recognize if you connect the OTG USB port to a PC with a male-to-male cable
Posted (edited)
I've made it! I hard to press really hard on the pins to make it work. Thank you.
Edited by BernardoT
