vor 1 Stunde schrieb n3o:
ok, the 2 bootloader here https://github.com/ilmich/rkflashtool/tree/master/bin do You know of what type are?
 no but ilmich would post close ones , so i thing there will be open ones , but simple first if you havent problem with legacy armbian please dont do step 10 infront of step 1
bullseye and jammy
bullseye debian 11
jammy ubuntu 22.04
think it's bettere install legacy armbian to nand, and only after this flash armbian newest to sd (I think it's possible boot system directly from sd without install , true?)
yes you can nand first , yes correct sd card direct without install when bootloader 1 else you maybe need "jump start" from multitool
Hello everyone,
I recently acquired a TV BOX MXQ PRO 4k 5g with the RK3228a chipset and the mxq-ep-2-v1.0 model board. I've been trying to install Armbian on it, but I've encountered some challenges that I could use some assistance with.
Here's what I've experienced so far:
1. When I press the reset button (AV), it triggers the Android recovery mode instead of booting into the system.
2. My attempts to create a clean Armbian ISO "Armbian_23.8.0-trunk.56_Rk322x-box_bookworm_edge_6.3.8_xfce_desktop" on an SD card have not been successful in achieving a successful boot.
3. I've also considered using software like RKDevTool, SDDiskTool, or Rockchip Assistant, but I'm unsure if these proprietary tools are necessary or if there's an alternative solution.
I've attached images of the board and the boot screen for reference. Could anyone provide guidance on how to successfully install Armbian on this device or recommend any tutorials for initializing the SD card? Your insights would be greatly appreciated.
Thank you in advance for your help!
[Attached Images: Images of the board and boot screen]
Best regards,
Lucas (calusbr)
Guidance is the first page of this thread. If you're unsure about a passage wrote there, explain with a post what you're unsure about.
Hi, I have a MXQ_PRO 4K, new, (mxq_r2b_lp3_v2.62_220225) too! It don't work the multitool, black screen, orange led turn on, in sdcard ou flashdrive! In other MXQ old, RQ329 that work fine, it's configured sdcard, that don't work in the new mxq, black screen and led turn off, what can be this problem?
Thank you for help!
We don't know! The board is new and it just does not work 🤷‍♂️
And please don't ask for solutions: proper serial logs, original device trees and firmware perhaps may help, but most we need the board in our hands to give the chance to support it.
@Benedito Portela The console is on the pads on the underside of the PCB as of the older version and you can see it in my tear down of the old version here https://github.com/MattWestb/R29-MXQ-LP3-V2.3-00908.
The MASCROM pads i think being moved and looks being some pads near the memory but the photo is not sharp enough for see that and hopefully you dont need it but you need erasing the eMMC for getting the box booting external media with current kernel and if like getting it working good writing one new updated bootloader in the eMMC that making it booting all medias also USB storage by jump star from the eMMC to external media.
I have not the HDMI and WiFi working but is not bad then i dont need them then using Eth and the HDMI is only making the CPU using more power and being heater so better not connecting it then have getting SSH working and using one good SHH terminal program to manage the box.
Edit: The MASCROM pads is 110% the same only its little nearer the CPU then the layout is the same so shall working as the old version only look on the photos and you is finding them.
Edited by MattWestB
@jock Hello there,
I've been following the steps outlined on page 1 carefully to install Armbian on my TV Box. Unfortunately, I've encountered a roadblock. Even though I've completed all the steps, when I insert the SDCARD into the TV Box and power it on, the device doesn't seem to start up. Strangely, the TV Box only powers on when the SDCARD is not connected, or if I press the reset button without the SDCARD, it boots into Android recovery mode. I'm at a loss on how to initiate the SDCARD boot with Multitool or load a clean Armbian image.
Any guidance or insights on how to overcome this issue and successfully boot from the SDCARD would be highly appreciated.
Hi MattWestB, thank you for attention! I saw your post, but i need of HDMI, Sound e Eth, i don't use SSH terminal! I wotk with electronic informatic hardware, i know a bit of linux, but the tvbox are very complicate to configure, i want help, if you know where i can learn about boot process, how change configs to setup to hardware correct, i'm grateful!
@Benedito Portela Im not one code warier but was installing my first  Linux fro 2 diskettes one with kernel and the other with root FS and i think the kernel was 0.95 or somthing but im not so deep in it so i can doing little but im better electronic hardware.
The HDMI problem we dont have and fix for then the persons with knowledge has nit getting there hands on one for digging deeper in it.
Is you Italian ? If yes our 2 best is the same and if you can getting your box to one of them it can being possible they finding that hardware tricks that  is needed for getting it working OK.
I  think your box shall being possible getting up and running but the HDMI i think cant being done for the moment (its over 1.5 years old problem with some boxes).
That is needed if doing it the easy way is soldering the comport and using one terminal program and one USB-TTL 3.3V for making the first configuration then you cant see what you is doing with only keyboard then the HDMI is not working.
MattWestB, I'm brazillian! I have a mxq R329  working fine in a project, and wish have other like backup! I don't knew that tvbox have many variations and that it new don't work well, I sould be choice the orange pi or other simples raspberry clone to make project, but i get this used box, from a friend, and start in the tvbox's world! I'll continued to learn, any news, i tell you! Thank you!
No guidance is possible without the serial logs; if people don't know what is going on, how can suggest you further steps?
Next time buy an armbian properly supported SBC and you will have no troubles
DISCLAIMER
We don't own , have studied , have even seen ANY of the new mxq_r2b_lp3_v2.62_220225 boards
We don't know what is going on those, no further help, infos, tips avaible until we get one of
        PLEASE STOP
asking why they don't work because       WE SIMPLY DON'T KNOW
Any of you can still donate one sample for further investigations
Thanks for understanding it !!!!
Edited by fabiobassa
@fabiobassa
so couldnt you give some hints what to check etc. Whats the proces of making new board work ? some tutorials, links where to learn it etc.
Most of RK3228/9 just works fine, soc didn't change - then prob something with HW settings of DRAM/EMMC.
Without this dev team will never increase ;) cant find any other place to share info with any community about this board than this topic, and you say to stop ...
for now focusing on recompiling DTB from android, but without any boot success
regular just breaks from the beginig https://github.com/kenavru/rk3228_TVBox/blob/main/CurrentKernel.txt
Internal error: kernel stack overflow: 0 [#1] PREEMPT SMP ARM
hmm starting getting some life signals from hdmi xD
[    8.793093] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    8.803291] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    8.813785] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    8.819688] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    8.826025] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    8.832361] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    8.838696] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    8.845897] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    8.851792] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    8.859077] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    8.865836] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    8.873359] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    8.879201] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    8.886291] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    8.893199] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    8.899051] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[   14.251109] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[   14.261117] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[   14.271538] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[   14.277411] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[   14.283713] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[   14.290010] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[   14.296309] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[   14.303475] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[   14.309339] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[   14.316590] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[   14.323236] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[   14.330666] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[   14.336446] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[   14.343423] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[   14.350308] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[   14.356151] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[   19.655318] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[   19.665302] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[   19.675724] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[   19.681597] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[   19.687899] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[   19.694197] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[   19.700495] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[   19.707662] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[   19.713528] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[   19.720781] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[   19.727432] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[   19.734856] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[   19.740634] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[   19.747615] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[   19.754500] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[   19.760344] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[   25.050875] random: nonblocking pool is initialized
[   25.059333] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[   25.069306] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[   25.079722] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[   25.085592] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[   25.091895] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[   25.098212] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[   25.104513] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[   25.111678] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[   25.117542] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[   25.124799] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[   25.131445] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[   25.138891] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[   25.144653] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[   25.151625] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[   25.158506] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[   25.164347] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[   30.463258] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[   30.473244] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[   30.483665] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[   30.489536] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[   30.495838] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[   30.502135] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[   30.508434] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[   30.515605] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[   30.521460] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[   30.528693] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[   30.535315] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[   30.542714] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[   30.548471] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[   30.555440] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[   30.562320] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[   30.568162] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[   35.939134] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[   35.948952] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[   35.959396] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[   35.965290] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[   35.971615] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[   35.977934] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[   35.984255] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[   35.991449] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[   35.997336] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[   36.004612] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[   36.011281] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[   36.018727] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[   36.024501] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[   36.031475] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[   36.038356] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[   36.044207] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
Edited by ego worker
@ego worker
Just phisically have the board in our hands !!!!
This Is the best hint we can give
About the tutorial, this 3ad Is a big tutorial.
Here you can find infos on boot process, logs, other bugs we found ( DDR timing, trust, other, cec)
Just go with trials and errors as we already have done or donate a sample for the purpose
bullseye and jammy
bullseye debian 11
jammy ubuntu 22.04
bad news : I have tried to run the box with sdcard inside with multitool, but nothing happen (the tv goes to energy save).
Removing the sd card android tried to boot, but it's stop to recovery mode
If I choose "Reboot to bootloader" device stop and nothing more happen (same result as with sd card inserted), if I choose "View recovery logs" the following info appear (I have only made photo of last 3 pages and I have open kmsg file because .log files was empty). Here the screenshot
What should I do?
vor 8 Minuten schrieb n3o:
 Have you tried with SD-Card insert and manuall by press recovery button with tootbrush (trough audio port) --> than switch to bootloader or maybe sd-card boot direct
the box has to have the sd-card already in slot to read it ID and some other stuff when bootloader has to read from it
when boot first to recovery without SD-card than maybe some information missing (for the bootloader)
no, I haven't made try this. What should I do precisely? Should insert toothpick inside audio jack port?
yes, I have insert sd card into the slot before turn on the box
vor 40 Minuten schrieb n3o:
Yes correct toothpick (soory for my toothbrush)  audio port ( be gentle there is only a micro switch) hold  and than plug in the power adapter ,
or alternativ plug in powercord and as fast as possible  push the button for 1sec
the picture is from my box , you box is diffirent but the button and button position  behind audio jack should be the same
Edited by RaptorSDS
Problem still occur ... nothing boot, monitor is always in save energy mode
@jock@n3o@fabiobassa
so we try simple step , but looks like close bootoader or broken bootloader --> any idee to get multitool running
@jock is there a maskrom mode for NAND
i think its more easy to short a clock pin for n3o than all the flashing rktool android and bootloader stuff .
i dont lnow it there a android image here for rktool ?
I think that maskrom mode for NAND is this (get from first post) https://forum.armbian.com/topic/12656-csc-armbian-for-rk322x-tv-boxes/?do=findComment&comment=121103
Considering my very few knowledge on electronic and the fact that I'm not expert on hardware, I think it's more easy the link above
what do You think of this https://drive.google.com/file/d/1SKX7fcWhqeGVN8qxZ5pVUEmMOHI_WvQ8/view ? I have take it from here https://4pda.to/forum/index.php?showtopic=892127 ...
Yes, of course; NAND also have a clock, shorting the clock pin has the same effect on eMMC and NAND devices.
Still I haven't seen a serial log, without that, going further with support is a waste of time.
vor 15 Minuten schrieb jock:
i thing you have found the NW018 Nand memory information  , please do you have more information what is clock pin maybe datasheet or picture to get in MASKrom mode
here I have posted serial log https://forum.armbian.com/topic/12656-csc-armbian-for-rk322x-tv-boxes/?do=findComment&comment=169159
I have tried to connect usb otg (usb port near to spdif connector behind box) to my pc but I don't see it (I have tried to install 5.1 driver, 4.8, 4.5 and so on) but front blue led is turnon
33 minutes ago, jock said:
Seriously, are you thinking that thousands of log lines of the original android (I read kernel 3.10) are of any use?
Paste the logs of the problematic boot, not when it goes well, damn!
First of all that log was related to boot without sd inserted (in such case android go to recovery mode and it doesn't go well), after that I think that the problem is the same to android boot and sd card boot.
I have tried to connect the device to another pc with windows 7, also in this case isn't recognized from windows. Can be the driver assistant 5.1.1 the cause of problem or I must necessary work on pin?
Should I follow this tut https://forum.armbian.com/topic/12656-csc-armbian-for-rk322x-tv-boxes/page/5/#comment-99167
to short pin 7 and pin 8 it's enough use a clip such this  https://cdn.pixabay.com/photo/2012/04/14/16/54/paperclip-34594_1280.png
Edited by n3o
Hi, i have a problem when i burn the multitool in the SD card. In the instruction said that the armbian image has to be placed in the images folder from the FAT partition but the only partition that have an Images folder is NTFS. I already tried many times with different burners and the result is the same. It should work the same or no?
vor 2 Stunden schrieb n3o:
@n3o
Yes I know you want a box that will boot Armbian only with insert SD card and you are fine, now we have some difficulties and you try to read all that can help and try to do things by yourself while waiting.
You try to do the right steps but as last time please be more patient.
Yes we now know that you have some exp in software but not linux and not this box. Yes we understand that you try to understand every step and try to be a good help but please dont mix topic.
Not every box is the same, not every chip is the same, so not all pictures are like your box.
Jock want the log files, not picture of the boot from mutitool and/or log file of trying direct flash armbian on sd card and then boot.
We can not support Android or anything that comes from Android.
Yes we are very, very short in describing what we expect in every single step we want from everyone who has problem and ask for help.
But here are so many who just post not working and thats it or people who dont read first topic.
And also we are write so often to try to help and we think that many have already followed that our topic is Armbian on this box or dont understand that this all is also our free time and hobby. We think that people should understand that this is all at their own risk and that they need to understand something about what they are about to do like uart adapter or working with ssh or console.
Edited by RaptorSDS
