Sid Boyce Posted February 22, 2024 Posted February 22, 2024 What ever I try I get Ign or Errors. Happens also on all Pi4's that had been working for years as well as for a new install I am attempting using Armbian_24.2.1_Rpi4b_jammy_current_6.6.16_xfce_desktop.img.xz root@rpi4b:/etc/apt# apt --allow-unauthenticated upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages have been kept back: gir1.2-gdm-1.0 iptables libgdm1 libip4tc2 libip6tc2 libxtables12 The following packages will be upgraded: coreutils gir1.2-javascriptcoregtk-4.0 gir1.2-webkit2-4.0 libjavascriptcoregtk-4.0-18 libwebkit2gtk-4.0-37 linux-libc-dev 6 upgraded, 0 newly installed, 0 to remove and 6 not upgraded. Need to get 32.2 MB of archives. After this operation, 269 kB disk space will be freed. Do you want to continue? [Y/n] Ign:1 http://ports.ubuntu.com jammy-updates/main arm64 coreutils arm64 8.32-4.1ubuntu1.1 Ign:2 http://apt.armbian.com jammy/main arm64 linux-libc-dev arm64 23.02.2 Ign:3 http://ports.ubuntu.com jammy-security/main arm64 gir1.2-webkit2-4.0 arm64 2.42.5-0ubuntu0.22.04.2 Ign:2 http://apt.armbian.com jammy/main arm64 linux-libc-dev arm64 23.02.2 Ign:4 http://ports.ubuntu.com jammy-security/main arm64 gir1.2-javascriptcoregtk-4.0 arm64 2.42.5-0ubuntu0.22.04.2 Ign:2 http://apt.armbian.com jammy/main arm64 linux-libc-dev arm64 23.02.2 Ign:5 http://ports.ubuntu.com jammy-security/main arm64 libwebkit2gtk-4.0-37 arm64 2.42.5-0ubuntu0.22.04.2 Err:2 http://apt.armbian.com jammy/main arm64 linux-libc-dev arm64 23.02.2 Connection failed [IP: 130.185.239.78 80] Ign:6 http://ports.ubuntu.com jammy-security/main arm64 libjavascriptcoregtk-4.0-18 arm64 2.42.5-0ubuntu0.22.04.2 0 Quote
Werner Posted February 22, 2024 Posted February 22, 2024 45 minutes ago, Sid Boyce said: Connection failed [IP: 130.185.239.78 80] Double-check that you can reach that IP address through your internet connection. 0 Quote
Sid Boyce Posted February 22, 2024 Author Posted February 22, 2024 root@rpi4b:/etc/apt# ping 130.185.239.78 80 PING 130.185.239.78 (130.185.239.78): 56 data bytes 64 bytes from 130.185.239.78: icmp_seq=0 ttl=49 time=107.169 ms 64 bytes from 130.185.239.78: icmp_seq=1 ttl=49 time=107.792 ms 64 bytes from 130.185.239.78: icmp_seq=2 ttl=49 time=106.246 ms 64 bytes from 130.185.239.78: icmp_seq=3 ttl=49 time=107.586 ms 64 bytes from 130.185.239.78: icmp_seq=4 ttl=49 time=106.834 ms 64 bytes from 130.185.239.78: icmp_seq=5 ttl=49 time=107.063 ms http to the site doesn't work, https gives a warning and I can connect clicking on "Accept risk and Continue" 0 Quote
Sid Boyce Posted February 22, 2024 Author Posted February 22, 2024 root@rpi4b:/etc/apt# cat /etc/resolv.conf # Generated by NetworkManager search cable.virginm.net localdomain nameserver 194.168.4.100 nameserver 194.168.8.100 nameserver 192.168.10.103 Changed the first nameserver to 8.8.8.8 root@rpi4b:/etc/apt# apt-get update Ign:1 http://ports.ubuntu.com jammy InRelease Ign:2 http://cli.github.com/packages stable InRelease Ign:3 http://apt.armbian.com jammy InRelease Ign:4 http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Ign:5 http://ports.ubuntu.com jammy-security InRelease Ign:2 http://cli.github.com/packages stable InRelease Ign:3 http://apt.armbian.com jammy InRelease Ign:4 http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Ign:6 http://ports.ubuntu.com jammy-updates InRelease Ign:2 http://cli.github.com/packages stable InRelease Ign:4 http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Ign:3 http://apt.armbian.com jammy InRelease Ign:7 http://ports.ubuntu.com jammy-backports InRelease Err:2 http://cli.github.com/packages stable InRelease Connection failed [IP: 185.199.109.153 80] Err:3 http://apt.armbian.com jammy InRelease Connection failed [IP: 130.185.239.78 80] Err:4 http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Connection failed [IP: 35.185.44.232 80] 0% [Waiting for headers]^C root@rpi4b:/etc/apt I am running my network through IPFire firewall. I'll check to see if there is a recent change with the latest version that may be causing this to happen 0 Quote
Solution Sid Boyce Posted February 22, 2024 Author Solution Posted February 22, 2024 (edited) Found a similar problem and fix with arduino.cc on the IPFire firewall forum ... Disabling "Intrusion Prevention System" in IPFire has fixed it. Edited February 22, 2024 by Sid Boyce 0 Quote
Sid Boyce Posted February 26, 2024 Author Posted February 26, 2024 Fixed by disabling Intrusion Prevention Service (IPS) in IPFire. Strangely I found a topic I submitted a long time ago where I couldn't get to arduino.cc in a browser which was fixed by disabling IPS. When upgrading IPFire, IPS got enabled by default. 0 Quote
Giunti Posted March 2, 2024 Posted March 2, 2024 In search posts referring to a similar (?) problem I ran across this post hoping to find some remedial hints. Upon trying to update/upgrade my Cubietruck Bookworm OS I received this error message: root@CT:~# apt-get update OK:1 http://deb.debian.org/debian bookworm InRelease OK:2 http://deb.debian.org/debian bookworm-updates InRelease OK:3 http://deb.debian.org/debian bookworm-backports InRelease OK:4 http://security.debian.org bookworm-security InRelease Ign:5 http://fi.mirror.armbian.de/apt bookworm InRelease Fehl:6 http://fi.mirror.armbian.de/apt bookworm Release 404 Not Found [IP: 65.21.120.247 80] Paketlisten werden gelesen… Fertig E: Das Depot »http://apt.armbian.com bookworm Release« enthält keine Release-Datei mehr. N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert. N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8). The stated address does not seem to hold a release file anymore, which does not allow for a secure upgrade. Otherwise my Armbian/Debian system runs flawlessly. Is there a way to get over this problem? Many thanks in advance for help. 0 Quote
Igor Posted March 2, 2024 Posted March 2, 2024 39 minutes ago, Giunti said: Is there a way to get over this problem? It is. Wait. We are working on it. https://github.com/armbian/mirror/issues/16 0 Quote
Giunti Posted March 4, 2024 Posted March 4, 2024 Thanx a multitude, Igor. "apt-get update" seems to work again, however, "upgrade" yielded another error. I then tried upgrade --fix-missing" and that seemed to do the job alright. See screenshots attached in chronological order. If that conforms with your expectations, I'm happy, too.😁 All the best, Giunti PS.: I'm sorry for the German representation of the messages in the screenshots. 0 Quote
Igor Posted March 4, 2024 Posted March 4, 2024 59 minutes ago, Giunti said: I then tried upgrade --fix-missing" and that seemed to do the job alright. Yeah, mirrors syncing / checking which are in sync is not working perfectly well. Yet. In a day, those random errors should be gone. 0 Quote
Sid Boyce Posted March 4, 2024 Author Posted March 4, 2024 My problem was due to IPS (Intrusion Prevention System) being enabled on my IPFire firewall box. When I did a search on the IPFire forum I found I had raised an issue some time ago -- not able to access only www.arduino.cc and that was due to IPS being enabled. Recent IPFire upgrades automatically turned it on. 0 Quote
maknho Posted March 5, 2024 Posted March 5, 2024 always the same error here (odroid n2+° WHen update 404 Not Found [IP: 65.21.120.247 80] 0 Quote
Igor Posted March 5, 2024 Posted March 5, 2024 3 hours ago, maknho said: always the same error here (odroid n2+° WHen update 404 Not Found [IP: 65.21.120.247 80] Can you provide what you get from: sudo apt update sudo apt upgrade Dot it 3x. 0 Quote
Werner Posted March 6, 2024 Posted March 6, 2024 If I had to guess missing release file. means unsupported userspace Release files for trixie, mantic, bookworm, sid, jammy and noble are there. 0 Quote
maknho Posted March 6, 2024 Posted March 6, 2024 (edited) 8 hours ago, Igor said: Can you provide what you get from: sudo apt update sudo apt upgrade Dot it 3x. apt update Atteint :1 http://security.debian.org bullseye-security InRelease Atteint :2 http://deb.debian.org/debian bullseye InRelease Atteint :3 http://deb.debian.org/debian bullseye-updates InRelease Atteint :4 http://forge.yunohost.org/debian bullseye InRelease Atteint :5 https://packages.sury.org/php bullseye InRelease Ign :6 http://fi.mirror.armbian.de/apt bullseye InRelease Err :7 http://fi.mirror.armbian.de/apt bullseye Release 404 Not Found [IP : 65.21.120.247 80] Lecture des listes de paquets... Fait E: Le dépôt http://apt.armbian.com bullseye Release ne contient plus de fichier Release. N: Les mises à jour depuis un tel dépôt ne peuvent s'effectuer de manière sécurisée, et sont donc désactivées par défaut. N: Voir les pages de manuel d'apt-secure(8) pour la création des dépôts et les détails de configuration d'un utilisateur Edited March 6, 2024 by maknho 0 Quote
Igor Posted March 6, 2024 Posted March 6, 2024 3 hours ago, Werner said: Release files for trixie, mantic, bookworm, sid, jammy and noble are there. Re-adding bullseye too? 0 Quote
a_aimo Posted March 6, 2024 Posted March 6, 2024 Hello. Recently I noticed the buster and bullseye sources were removed. Is that mean Armbian buster and bullseye EOL? However I can't find any news about this. If they are EOL, is there anyone able to give me a URL to find their archives? Because of my devices' hardware, their OS's kernels can't be upgraded. (AML S805 with Nand flash) cat /etc/apt/sources.list.d/armbian.list deb http://apt.armbian.com buster main buster-utils buster-desktop 0 Quote
Werner Posted March 6, 2024 Posted March 6, 2024 6 hours ago, Igor said: Re-adding bullseye too? Yeah, why not. As CSC of course. 1 Quote
bedna Posted March 6, 2024 Posted March 6, 2024 (edited) OPI PC2 here. I had a missing release error the other day and just assumed it was because it was no longer supported. That is no longer the case and I also get: Hit:1 http://deb.debian.org/debian bullseye InRelease Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB] Get:3 http://security.debian.org bullseye-security InRelease [48.4 kB] Get:4 http://deb.debian.org/debian bullseye-backports InRelease [49.0 kB] Err:6 http://apt.armbian.com bullseye InRelease 502 Bad Gateway [IP: 130.185.239.78 80] Get:5 https://cli.github.com/packages stable InRelease [3917 B] Hit:7 https://download.docker.com/linux/debian bullseye InRelease Get:8 http://security.debian.org bullseye-security/main arm64 Packages [342 kB] Get:9 https://cli.github.com/packages stable/main arm64 Packages [346 B] Fetched 488 kB in 3s (167 kB/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done 2 packages can be upgraded. Run 'apt list --upgradable' to see them. W: Failed to fetch http://apt.armbian.com/dists/bullseye/InRelease 502 Bad Gateway [IP: 130.185.239.78 80] W: Some index files failed to download. They have been ignored, or old ones used instead. Nobody confirmed bullseye so I have to ask.. Edited March 6, 2024 by bedna 0 Quote
Arendjan Posted March 6, 2024 Posted March 6, 2024 I see that bullseye is added back, could focal also be added back? Best regards, Arend-Jan 0 Quote
a_aimo Posted March 11, 2024 Posted March 11, 2024 I also noticed bullseye was added back. Is buster end of support? Is there any URL of buster's archive like debian-archive ? Thanks so much. 0 Quote
