JamesCL Posted March 2, 2024 Posted March 2, 2024 Hello friends, htop does not show me the temperature, I am attaching information about my system (I have the libsensors library installed). If someone can help me please. Thank you. OS: Armbian 24.5.0-trunk.89 trixie aarch64 Host: Xunlong Orange Pi 5 Kernel: 6.8.0-rc1-edge-rockchip-rk3588 Uptime: 1 hour, 14 mins Packages: 333 (dpkg) Shell: bash 5.2.21 Terminal: /dev/pts/0 CPU: (8) @ 1.800GHz Memory: 187MiB / 7687MiB 0 Quote
Werner Posted March 2, 2024 Posted March 2, 2024 Bleeding edge kernel, unsupported userspace and expect everything to work flawless.... 0 Quote
Marco Schirrmeister Posted March 3, 2024 Posted March 3, 2024 I think this issue here https://github.com/htop-dev/htop/issues/1160 describes the problem. Might be a problem that needs to be fixed within htop. If you are willing to switch tools, have a look at btop. That should give you should give you the overall temperature. 0 Quote
JamesCL Posted June 17, 2024 Author Posted June 17, 2024 After applying the following changes I was able to obtain the temperatures in my OPI5. https://github.com/htop-dev/htop/pull/1411/files#diff-cd34c934b018d562cd6c276738f8e4ff18638bff20de91ef057e83a425dd68a1 Thank 0 Quote
