OrangePI 2 wifi driver issue in mainline dev (4.10)
1 1
14 posts in this topic
I've build an dev image for my OrangePi 2 (kernel 4.10) to try mainline kernel and got into troubles with onboard wifi. It works fine in legacy with 8189es module, but there is no 8189es module in mainline image. So I tried 8189fs but it's not working.
After doing some search I've managed to build 8189es module myself using https://github.com/jwrdegoede/rtl8189ES_linux.gitrepository. Quick manual:
git clone https://github.com/jwrdegoede/rtl8189ES_linux.git
cd rtl8189ES_linux/
make ARCH=arm KSRC=/usr/src/linux-headers-$(uname -r) CROSS_COMPILE=
sudo mkdir /lib/modules/4.10.0-sun8i/kernel/drivers/net/wireless/realtek/rtl8189es/
sudo cp 8189es.ko /lib/modules/4.10.0-sun8i/kernel/drivers/net/wireless/realtek/rtl8189es/
sudo depmod -a
sudo modprobe 8189es
I'd suspect that this issue applies to all boards with RTL8189ETV sdio wifi (OPI 2, OPI+2, NanoPI A64, etc). And the question is - why this driver is missing in default armbian repo?
Share this post
Link to post
Share on other sites
Since Hans started to play around is possible, that driver will find a way upstream and we won't need to add it with a patch. Anyway, this kernel is Work In Progress and if you see something missing or you find a bug and know how to fix it, you are welcome to help. We can't address all issues.
Share this post
Link to post
Hm. I'm not sure about that.
Feel free to convert this driver to in-tree one and making a pull request if you want to solve this problem sooner than later.
Share this post
Link to post
To which repo PR should go to?
Share this post
Link to post
I've just tried to build driver on kernel 4.11.0 but got some nasty errors:
rufik@opi:~/workspace/rtl8189ES_linux$ make ARCH=arm KSRC=/usr/src/linux-headers-4.11.0-sun8i CROSS_COMPILE=
make ARCH=arm CROSS_COMPILE= -C /usr/src/linux-headers-4.11.0-sun8i M=/home/rufik/workspace/rtl8189ES_linux  modules
make[1]: Entering directory '/usr/src/linux-headers-4.11.0-sun8i'
  CC [M]  /home/rufik/workspace/rtl8189ES_linux/core/rtw_cmd.o
In file included from /home/rufik/workspace/rtl8189ES_linux/include/drv_types.h:32:0,
                 from /home/rufik/workspace/rtl8189ES_linux/core/rtw_cmd.c:22:
/home/rufik/workspace/rtl8189ES_linux/include/osdep_service.h: In function thread_enter’:
/home/rufik/workspace/rtl8189ES_linux/include/osdep_service.h:343:2: error: implicit declaration of function allow_signal [-Werror=implicit-function-declaration]
  allow_signal(SIGTERM);
/home/rufik/workspace/rtl8189ES_linux/include/osdep_service.h: In function flush_signals_thread’:
/home/rufik/workspace/rtl8189ES_linux/include/osdep_service.h:353:6: error: implicit declaration of function signal_pending [-Werror=implicit-function-declaration]
  if (signal_pending (current))
/home/rufik/workspace/rtl8189ES_linux/include/osdep_service.h:355:3: error: implicit declaration of function flush_signals [-Werror=implicit-function-declaration]
   flush_signals(current);
cc1: some warnings being treated as errors
scripts/Makefile.build:294: recipe for target '/home/rufik/workspace/rtl8189ES_linux/core/rtw_cmd.o' failed
make[2]: *** [/home/rufik/workspace/rtl8189ES_linux/core/rtw_cmd.o] Error 1
Makefile:1492: recipe for target '_module_/home/rufik/workspace/rtl8189ES_linux' failed
make[1]: *** [_module_/home/rufik/workspace/rtl8189ES_linux] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.11.0-sun8i'
Makefile:1640: recipe for target 'modules' failed
make: *** [modules] Error 2
So I've made quick fix, here is PR to Hans' repo: https://github.com/jwrdegoede/rtl8189ES_linux/pull/2
Works quite fine:
[Thu May  4 14:18:59 2017] 8189es: loading out-of-tree module taints kernel.
[Thu May  4 14:18:59 2017] bFWReady == _FALSE call reset 8051...
[Thu May  4 14:19:00 2017] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[Thu May  4 14:19:00 2017] ==> rtl8188e_iol_efuse_patch
#ifconfig
wlan0     Link encap:Ethernet  HWaddr 00:e0:4c:f0:1c:fd
          inet addr:xxx.xxx.xxx.6  Bcast:xxx.xxx.xxx.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:8 errors:0 dropped:0 overruns:0 frame:0
          TX packets:13 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:2426 (2.4 KB)  TX bytes:3674 (3.6 KB)
I'll try to adopt it as in-tree in the meantime...
Share this post
Link to post
The fix was already included in the driver: https://github.com/jwrdegoede/rtl8189ES_linux/pull/1/files
Also this fix was already integrated into the in-tree driver patch, but I'm not sure if the driver was enabled in the kernel config after fixing it.
Share this post
Link to post
Ups, it went to rtl8189fs branch, so I missed it...
In-tree driver patch - to you mean armbian repo or mainline kernel?
Share this post
Link to post
@zador.blood.stained I've managed to build kernel with 8189fs module, but I need to test it yet. I wonder if 8189es is pretty the same as 8189fs? Because diff shows a lot of changes between master and rtl8189fs branches...
Share this post
Link to post
Don't have any boards with 8189es chip, so can't test if 8189fs driver works with them, sorry.
Share this post
Link to post
Yeah, I have OPI 2, so I'll do it :)
I just wonder what is the difference between ES and FS versions...
Share this post
Link to post
Tested. The FS version does not work on OPI 2 kernel 4.11.0 at all, iface does not show up:
# lsmod
8189fs                839680  0
# dmesg
[Fri May  5 14:17:11 2017] ######platform_wifi_power_on:
# ifconfig wlan0
wlan0: error fetching interface information: Device not found
So, it looks like this driver should be fetched from master branch with my PR and converted to in-tree as RTL8189ES.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
1 1
  • Support the project
    We need your help to stay focused on the project.
    Choose the amount and currency you would like to donate in below.
