A few questions about the NanoPC T6 image
fever_wits
Hello,
I apologize for my bad English.
I have a NanoPi R6S and a NanoPC T6.
Both Nano devices have Armbian images.
Both devices use a processor:
CPU Model: Rockchip RK3588
Number of Cores: Quad-core ARM Cortex-A76 + Quad Core Cortex-A55
Frequency: Cortex-A76 (up to 2.4GHz), Cortex-A55 (up to 1.8GHz)
A few things struck me
On NanoPi R6S
in the dts file, the frequency of A76 cores is up to 2.4GHz
you can see the frequencies at which each core works
cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_available_frequencies
408000 600000 816000 1008000 1200000 1416000 1608000 1800000
408000 600000 816000 1008000 1200000 1416000 1608000 1800000 2016000 2208000 2352000
408000 600000 816000 1008000 1200000 1416000 1608000 1800000 2016000 2208000 2256000
governors:
cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_available_governors
conservative ondemand userspace powersave performance schedutil
On NanoPi T6
in the dts file, the frequency of A76 cores is up to 2.2GHz - I fixed it
- this is missing.
- this is missing, having instead
cat /sys/devices/system/cpu/cpuidle/available_governors
ladder menu teo
NanoPi R6S is currently running kernel 5.10.110-rockchip-rk3588
NanoPC T6 is currently running kernel 6.8.0-rc6-edge-rockchip-rk3588
I also noticed differences in CPU cache.
NanoPI R6S
Architecture:                    aarch64
CPU op-mode(s):                  32-bit, 64-bit
Byte Order:                      Little Endian
CPU(s):                          8
On-line CPU(s) list:             0-7
Thread(s) per core:              1
Core(s) per socket:              2
Socket(s):                       3
Vendor ID:                       ARM
Model:                           0
Model name:                      Cortex-A55
Stepping:                        r2p0
CPU max MHz:                     2352.0000
CPU min MHz:                     408.0000
BogoMIPS:                        48.00
L1d cache:                       256 KiB
L1i cache:                       256 KiB
L2 cache:                        1 MiB
L3 cache:                        3 MiB
Vulnerability Itlb multihit:     Not affected
Vulnerability L1tf:              Not affected
Vulnerability Mds:               Not affected
Vulnerability Meltdown:          Not affected
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
Vulnerability Spectre v2:        Vulnerable: Unprivileged eBPF enabled
Vulnerability Srbds:             Not affected
Vulnerability Tsx async abort:   Not affected
Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
NanoPC T6
CPU(s):                 8
Vendor ID:              ARM
    Model:              0
    Core(s) per socket: 4
    Socket(s):          1
    Stepping:           r2p0
    BogoMIPS:           48.00
  Model name:           Cortex-A76
    Model:              0
    Socket(s):          1
    Stepping:           r4p0
    BogoMIPS:           48.00
Caches (sum of all):
  L1d:                  384 KiB (8 instances)
  L1i:                  384 KiB (8 instances)
  L2:                   2.5 MiB (8 instances)
  L3:                   3 MiB (1 instance)
NUMA:
  NUMA node(s):         1
  NUMA node0 CPU(s):    0-7
Vulnerabilities:
  Gather data sampling: Not affected
  L1tf:                 Not affected
  Mds:                  Not affected
  Mmio stale data:      Not affected
  Retbleed:             Not affected
  Spec rstack overflow: Not affected
  Srbds:                Not affected
When using the command: cpufreq-info
NanoPI R6S
cpufreq-info
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
  driver: cpufreq-dt
  CPUs which run at the same hardware frequency: 0 1 2 3
  CPUs which need to have their frequency coordinated by software: 0 1 2 3
  maximum transition latency: 84.0 us.
  hardware limits: 408 MHz - 1.80 GHz
  available frequency steps: 408 MHz, 600 MHz, 816 MHz, 1.01 GHz, 1.20 GHz, 1.42 GHz, 1.61 GHz, 1.80 GHz
  available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil
  current policy: frequency should be within 408 MHz and 1.80 GHz.
                  The governor "ondemand" may decide which speed to use
                  within this range.
  current CPU frequency is 408 MHz (asserted by call to hardware).
  cpufreq stats: 408 MHz:76.72%, 600 MHz:6.69%, 816 MHz:0.31%, 1.01 GHz:0.00%, 1.20 GHz:0.00%, 1.42 GHz:0.00%, 1.61 GHz:0.00%, 1.80 GHz:16.29%  (11087717)
analyzing CPU 1:
  driver: cpufreq-dt
                  within this range.
analyzing CPU 2:
  driver: cpufreq-dt
                  within this range.
analyzing CPU 3:
  driver: cpufreq-dt
                  within this range.
analyzing CPU 4:
  driver: cpufreq-dt
  CPUs which run at the same hardware frequency: 4 5
  CPUs which need to have their frequency coordinated by software: 4 5
  maximum transition latency: 324 us.
  hardware limits: 408 MHz - 2.35 GHz
  available frequency steps: 408 MHz, 600 MHz, 816 MHz, 1.01 GHz, 1.20 GHz, 1.42 GHz, 1.61 GHz, 1.80 GHz, 2.02 GHz, 2.21 GHz, 2.35 GHz
  current policy: frequency should be within 408 MHz and 2.35 GHz.
                  within this range.
  cpufreq stats: 408 MHz:85.33%, 600 MHz:1.13%, 816 MHz:0.40%, 1.01 GHz:0.00%, 1.20 GHz:0.00%, 1.42 GHz:0.00%, 1.61 GHz:0.00%, 1.80 GHz:0.00%, 2.02 GHz:0.00%, 2.21 GHz:0.00%, 2.35 GHz:13.14%  (2586948)
analyzing CPU 5:
  driver: cpufreq-dt
                  within this range.
analyzing CPU 6:
  driver: cpufreq-dt
  CPUs which run at the same hardware frequency: 6 7
  CPUs which need to have their frequency coordinated by software: 6 7
  hardware limits: 408 MHz - 2.26 GHz
  available frequency steps: 408 MHz, 600 MHz, 816 MHz, 1.01 GHz, 1.20 GHz, 1.42 GHz, 1.61 GHz, 1.80 GHz, 2.02 GHz, 2.21 GHz, 2.26 GHz
  current policy: frequency should be within 408 MHz and 2.26 GHz.
                  within this range.
  cpufreq stats: 408 MHz:92.30%, 600 MHz:0.44%, 816 MHz:0.16%, 1.01 GHz:0.00%, 1.20 GHz:0.00%, 1.42 GHz:0.00%, 1.61 GHz:0.00%, 1.80 GHz:0.00%, 2.02 GHz:0.00%, 2.21 GHz:0.00%, 2.26 GHz:7.10%  (1012245)
analyzing CPU 7:
  driver: cpufreq-dt
                  within this range.
NanoPC T6
cpufreq-info
analyzing CPU 0:
  no or unknown cpufreq driver is active on this CPU
  maximum transition latency: 4294.55 ms.
analyzing CPU 1:
analyzing CPU 2:
analyzing CPU 3:
analyzing CPU 4:
analyzing CPU 5:
analyzing CPU 6:
analyzing CPU 7:
The CPU driver appears to be missing.
When using the command: cpu-info
NanoPI R6S
cpu-info
Packages:
        0: Unknown
Microarchitectures:
        4x Cortex-A76
        4x Cortex-A55
Cores:
        0: 1 processor (0), ARM Cortex-A76
        1: 1 processor (1), ARM Cortex-A76
        2: 1 processor (2), ARM Cortex-A76
        3: 1 processor (3), ARM Cortex-A76
        4: 1 processor (4), ARM Cortex-A55
        5: 1 processor (5), ARM Cortex-A55
        6: 1 processor (6), ARM Cortex-A55
        7: 1 processor (7), ARM Cortex-A55
NanoPC T6
cpu-info
Packages:
        0: Unknown
Microarchitectures:
        8x Cortex-A55
Cores:
        0: 1 processor (0), ARM Cortex-A55
        1: 1 processor (1), ARM Cortex-A55
        2: 1 processor (2), ARM Cortex-A55
        3: 1 processor (3), ARM Cortex-A55
My question is the following. Are the differences because of the dts file or because of the kernel.
Anyone else using a NanoPC T6 and would like to help fix this?
At the moment, I'm not using NanoPC T6 as a server yet, and I have the opportunity to experiment.
It will be used as a small server for graphics, tftp and others.
Is there any additional information needed.
Regards,
Hello,
I downloaded the source from the git repository.
The configurator and compiler are very intuitive.
They are easy to work with. Saved a lot of time and nerves :)
Thanks for what has been done as a configurator and the documentation.
Because I don't know if my problem is in the dtb file or in the kernel.
I compiled three versions
edge 6.8.0-rc7 - this does not work correctly.
legacy 5.10.160 - everything works here.
vendor 6.1.43 - everything works here.
And I was pleasantly surprised to find out that the fan control is also active.
CPU frequency scaling - works correctly on "legacy" and "vendor".
CPUs are successfully overclocked to factory frequencies.
For now, I'm still experimenting with compiling the kernel.
I'm open to suggestions and tests.
I hope this information was helpful.
Regards,
I don't know these boards at all, please take as an idea of experimentation, ordinarily you would have to look for differences in both the kernel (drivers) and dtb/dtsi (nodes), and where the opp tables are located.
Best of luck!
Hello,
At the moment I am working with an image that is from the site.
Many of the things work OK, but there are some that have reservations.
I don't know if it's appropriate to comment in the tickets or address someone specifically or write elsewhere.
That's what the last comment was about. I am happy with what has been done, but I would like to share impressions if anyone is interested.
I know we are all busy with work, family, etc. And in order not to waste the time of many people, I asked like this.
Regards,
@fever_wits I just want to point out if you don't already know, the board you have isn't supported by Armbian.  It is community maintained.  That means there is no one specifically that has responsibility for the board.  It is up to people who read these forums to respond if they have an interest.  So don't expect any specific response in any specific time frame.  Having said that, this is the correct place to post questions, observations, and hopefully solutions to issues with your board.  Armbian provides community builds as a service but doesn't have the resources to test or in anyway to support them.  So fixes/changes happen only as community members contribute them via PRs to armbian.  If no one contributes, over time the quality of a board degrades and when it stops building it then gets removed from armbian all together.
@TonyMac32 was listed as a board maintainer in build repo.
Yes, I also have Nanopc-t6 and experience same issue
BTW NanoPC-T6 is based on full 3588 (not 3588S as NanoPi-R6S) so there is an error below) on a picture. NanoPC-T6 is quite similar to Orange PI 5 Plus - comes also with 4-8-16GB versions but uses better 12V power input versus 5V on Orange.
Edited by bph
Hello,
I will use the NanoPC-T6 for a micro server.
The main thing it will run on is LibreNMS (currently my LibreNMS is on a NanoPi R6S)
I will also use ZFS, tftp, bond, vlan and others.
The reason I use the NanoPC-T6 is the 16GB ram as well as the PCIe slot.
I am attaching 2 pictures if anyone is curious about what I have created.
It's not very pretty, but it's functional.
What I have further configured in /boot/armbianEnv.txt
verbosity=7 - I prefer to see the OS loading
extraargs=net.ifnames=0 biosdevname=0 consoleblanl=0 brd.rd_nr=0 mitigations=off
                 brd.rd_nr=0 stops all Ram Block Devices
                 mitigations=off - this is on an internal network and since I don't know if I'll lose performance I just stop everything
console=serial - console output only serial port
docker_optimizations=off - I don't use docker
I only use the memory card for /boot
The OS is on the SSD in raid1 (about 16GB), the rest is raid1 in a zfs array, for 3 pools (mysql, librenms, storage)
I have installed ZFS like this: apt install linux-headers-vendor-rk35xx zfsutils-linux zfs-dkms zfs-zed
From the kernels offered by Armbian 5.10, 6.1 and 6.8, I use 6.1
I removed the network-manager wpasupplicant packages, instead of network-manager I use ifupdown2
The control of the fan is through the dts file.
The steering has 5 levels.
1st degree is at 50 degrees, then 2nd degree - 60 and so on
With installed fan and stress-ng more than 55 degrees I can not lift.
At linux-image-vendor-rk35xx_24.5.0-trunk.226_arm64
                 ZFS - compiles normally.
                 governor - on CPU works, has all modes of operation
                 governor for dmc, gpu and npu - only ondeman.
                 Network cards work normally.
                 FAN - management through the dts file works normally.
At linux-image-vendor-rk35xx_24.5.0-trunk.231_arm64
                 Installed from apt dist-upgrade, ZFS doesn't compile, had to do aptitude reinstall zfsutils-linux zfs-dkms zfs-zed
                 governor at dmc, gpu and npu - , has all modes of operation
On this build, one core is constantly at 100% (probably ZFS, but not sure about top and htop doesn't show which one is causing the IO)
I am using the 13.03 image, in this version in install linux-headers does not work, I installed it by hand.
While writing this I saw in armbian-config that there is already a version linux-image-vendor-rk35xx_24.5.0-trunk.244_arm64 but I can't find what is fixed and will wait for it to appear with apt.
I have further increased the size of /boot to 2GB like this:
aptitude install fatresize
umount /boot/
fatresize -v -p -s 2G /dev/mmcblk1p1
mount -a
Before using armbian kernel I had compiled 6.1 with these optimizations.
General setup ---> Preemption Model (Voluntary Kernel Preemption (Desktop)) ---> No Forced Preemption (Server)
General setup ---> Compiler optimization level (Optimize for performance (-O2)) ---> Optimize for performance (-O2)
Kernel Features ---> Timer frequency (300 HZ) ---> (X) 100 HZ
As a positive effect, the system is a little more "agile".
Negative effect, slightly warmer is the housing of the box.
What I would like fixed.
My version of NanoPC-T6 is 16GB ram and 256GB internal disk.
In this case I don't see the internal disk.
The other thing I want is to keep the old versions of the kernel.
Currently, when I install a new version of the kernel, the old version of the kernel is uninstalled, and if the OS does not start, I have to do everything from the beginning. It could be a setting, but I can't find where it is.
Regarding what I used like FAN, PCIe to Sata and SSD cage, I don't know if it is allowed to post links, not to be considered as advertising.
I hope this is useful to someone.
Regards,
13.03 image of what?
That is how Armbian works.  There is not option to change that behavior.
I have the same version.
root@nanopct6:~# uname -a
Linux nanopct6 6.8.1-edge-rockchip-rk3588 #1 SMP PREEMPT Fri Mar 15 18:19:29 UTC 2024 aarch64 GNU/Linux
root@nanopct6:~# fdisk -l
Disk /dev/mmcblk0: 232.96 GiB, 250139901952 bytes, 488554496 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 2C6E7417-4E9E-4651-A5E6-A6A4833C8ADF
Device         Start       End   Sectors   Size Type
/dev/mmcblk0p1 32768 483655679 483622912 230.6G Linux filesystem
Should be visible even on 6.8.1-edge (listing above is from Debian).
So bottom line:
  1. There is an error in menu of compile.sh stating that NanoPC-T6 is based on 3588(should be without S)
  2. Recent builds (above vendor) have issues with cpu frequency scheduling
  3. cpu-info incorrectly shows all cores as ARM Cortex-A55 on NanoPC-T6. But at the same time lscpu shows correct info. And yes, bigger cache is expected due to different processor version.
Any other issues?
Hello,
My mistake.
The image I use was published on 13.03.2024. Up until this point I was working with a personal kernel build based on armbian. From personal memory, I think it is 24.5.0-trunk.211
This is bad news for me. Apparently I won't touch the kernel. I already had a case, in a personal build, I used armbian-config to see a 5.10 kernel version, then I also put 6.1.43.
Then the script removed kernel 5.10 and did not install 6.1.43.
And everything started anew. That's how I found out that it was posted on 13.03.2024 image :)
Disklabel type: gpt
For me, it's more important to have a working CPU than an internal drive.
Otherwise, I use the built-in disk to backup boot and the OS.
In the source of the Edge version, at least until recently, most of the governors were missing. Now I've run and see that's fixed.
I can't use Edge because of ZFS.
I use https://github.com/armbian/community/releases/download/24.5.0-trunk.211/Armbian_community_24.5.0-trunk.211_Nanopct6_bookworm_vendor_6.1.43_minimal.img.xz - have no issues with CPU. Frequency scales up and down well. cpu-info has a bug but lscpu shows correct info.
Hello,
I don't have any issues with the CPU, I'm saying if I had to choose I'd go with the CPU, not the internal drive.
Otherwise, I'm currently with kernel linux-image-vendor-rk35xx:arm64 24.5.0-trunk.231 and everything works fine.
This kernel was installed via apt dist-upgrade.
lscpu says everything normal but cpu-info keeps seeing things wrong. I'm not sure where the problem is.
Regards,
Hello,
Today I upgraded from 24.5.0-trunk.231 to 24.5.0-trunk.318, for now everything is working normally. But I had to recompile the zfs module again.
It has zfs-dkms installed, shouldn't it just recompile the module?
If there is a need to upload a log or provide other information, I am available.
Regards,
