in the documentation is written :
How to toogle verbose boot?
touch /boot/.force-verbose # enable
You need to reboot to conduct changes.
rm /boot/.force-verbose # disable
but I am returned :
rm: cannot remove ‘/boot/.force-verbose’: No such file or directory
I tried to change verbosity in boot.cmd but with no success
Can you help please ?
Thanks
In the file /boot/boot,cmd change string setenv console "ttyS0,115200" to setenv console "serial" . After changes it is necessary to execute the command mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
root@orangepipc:/boot# ls -asl /boot
total 16904
   4 drwxr-xr-x  4 root root    4096 Feb 24 19:45 .
   4 drwxr-xr-x 22 root root    4096 Feb  5 20:21 ..
   0 -rw-r--r--  1 root root       0 Feb 22 23:21 .verbose
2008 -rw-r--r--  1 root root 2053486 Feb  2 08:01 System.map-3.4.113-sun8i
   4 -rw-r--r--  1 root root     120 Feb 22 23:21 armbianEnv.txt
   4 -rw-r--r--  1 root root     162 Feb  5 21:08 armbianEnv.txt.old
   4 drwxr-xr-x  2 root root    4096 Feb  5 21:43 bin
   8 -rw-r--r--  1 root root    6944 Feb  5 20:26 boot.bmp
   4 -rw-r--r--  1 root root    2588 Feb 19 23:27 boot.cmd
   4 -rw-r--r--  1 root root    2660 Feb 19 23:28 boot.scr
  96 -rw-r--r--  1 root root   96945 Feb  2 08:01 config-3.4.113-sun8i
5040 -rw-r--r--  1 root root 5159556 Feb 19 23:24 initrd.img-3.4.113-sun8i
   4 drwxr-xr-x  2 root root    4096 Feb 19 23:28 old
   0 lrwxrwxrwx  1 root root      18 Feb  5 20:25 script.bin -> bin/orangepipc.bin
  36 -rw-r--r--  1 root root   35160 Feb  5 20:38 script.bin.bak
   0 lrwxrwxrwx  1 root root      21 Feb 19 23:24 uInitrd -> uInitrd-3.4.113-sun8i
5040 -rw-r--r--  1 root root 5159620 Feb 19 23:24 uInitrd-3.4.113-sun8i
4644 -rwxr-xr-x  1 root root 4754648 Feb  2 08:01 vmlinuz-3.4.113-sun8i
   0 lrwxrwxrwx  1 root root      21 Feb  5 20:22 zImage -> vmlinuz-3.4.113-sun8i
I have no file /boot/.force-verbose, there is a /boot/.verbose file (OS Armbian5.25)
following string does not exist in /boot/boot.cmd
I'm using armbian 5.14
5.14 is old build and those boot scripts are different, upgrade is also not recommended. Perhaps better to start with fresh image ...
I cannot use 5.25 on OPI pc plus. First boot is ok but second one i am stucked on "Hit any key to stop autoboot: 0"
I succeded to boot on 5.25 with another OPI pc plus
But I still have verbose boot after following tests:
default value is "both". I tried to change to "serial" and recompile
I get "rm: cannot remove ‘/boot/.force-verbose’: No such file or directory" when I send "rm /boot/.force-verbose"
I tried to change setenv verbosity to 7,1 and 0 in boot.cmd and recompile
>Regarding u-boot. You will need to recompile it with disabled VIDEO flag
I understand u-boot is /boot/boot.cmd. but there is no video flag in it
