64 MB less total memory on 24.2.1
Go to solution Solved by c0rnelius,
I have flashed the last 23.8 bookworm lite image to my lepotato 1GB model, and it launched with 927 MB total memory.
running apt update ; apt upgrade ; reboot it drops to 862M
How can I reclaim the remaining memory? This is mostly a headless server i do not need any GPU. just basic hdmi output for troubleshooting purposes.
before:
Welcome to Armbian 23.8.1 Bookworm with Linux 6.1.50-current-meson64
System load:   8%               Up time:       4 min
Memory usage:  13% of 927M       IP:
CPU temp:      48°C               Usage of /:    4% of 29G
After:
Welcome to Armbian 24.2.1 Bookworm with Linux 6.6.16-current-meson64
System load:   19%               Up time:       1 min
Memory usage:  13% of 862M       IP:
Edited by ovacikar
My suggestion since I assume you don't have an armbianmonitor output from before your upgrade, would be to use armbian-config and go back to a 6.1 kernel and see if it is the kernel that is causing the difference.  If so then provide an armbianmonitor output with the old kernel and look at the memory info in the output to see where the difference is.
Actually there is.
### meminfo:
MemTotal:         949752 kB
And after:
### meminfo:
MemTotal:         882904 kB
Maybe uboot issue with memory detection?
The 6.6.y kernel for reasons I have yet to figure out reads the MEM wrong. 6.7 and up is not affected by this. Nor is 6.1 to 6.5.
I would have thought after so many REVS this would have been resolved, but I have yet to see it come up as a topic of discussion. This in my experience is also not PLATFORM specific. It happens on all my boards regardless of SoC and PLATFORM.
  • ovacikar changed the title to 64 MB less total memory on 24.2.1
