Build Armbian in Distro box?
Go to solution Solved by Werner,
Zitat
The officially supported compilation environment is Ubuntu Jammy 22.04.x amd64 only!
Ubuntu Focal can be used for building Bionic, Focal and Buster images as well, unsupported though
Noble Numbat is unsupported?
3 minutes ago, Myron said:
so is the recommendation not to do a do-release-upgrade just yet?
Ubuntu only started supporting jammy to noble upgrades with the .1 release that come out not that long ago.  So the upgrade to noble has only been available for a short time.
But in general, Armbian doesn't test distribution upgrades.  So Armbian will never recommend you do such an upgrade as it isn't supported.
However, if you know what you are doing you should be able to upgrade from jammy to noble.  I've done a couple of my own boxes and they have generally gone smoothly.
