premo Posted March 12, 2017 Posted March 12, 2017 dmesg log: ci_irq: highspeed device disconnect [ 1150.728627] ehci_irq: highspeed device connect [ 1151.000116] usb 3-1: new high-speed USB device number 3 using sunxi-ehci [ 1151.294344] usbcore: registered new interface driver rt2870 lsmod log: g@orangepipc:/$ lsmod Module Size Used by mt7601Usta 561549 0 rndis_host 5140 0 cdc_ether 3679 1 rndis_host usbnet 14096 2 rndis_host,cdc_ether cdc_acm 15280 0 mali_drm 2732 1 drm 178255 2 mali_drm usblp 10048 0 pcf8591 3363 0 bmp085 3487 0 mali 123146 0 ump 29379 3 mali btrfs 712409 0 g@orangepipc:/$ ip link 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436 qdisc noqueue state UNKNOWN mode DEFAULT group default link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000 link/ether 46:91:e3:79:bd:fd brd ff:ff:ff:ff:ff:ff 3: tunl0: <NOARP> mtu 1480 qdisc noop state DOWN mode DEFAULT group default link/ipip 0.0.0.0 brd 0.0.0.0 9: ra0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff Still my wifi doesnt work .It used to work by making my own by cloning from git in debian jessy but in xenial , it is not working at all. I clone it from here : sudo apt-get install linux-headers-generic build-essential git sudo apt-get install git git clone https://github.com/flexiti/mt7601.git cd mt7601 make clean make sudo make install sudo mkdir -p /etc/Wireless/RT2870STA/ sudo cp RT2870STA.dat /etc/Wireless/RT2870STA/ sudo modprobe mt7601Usta my /etc/network/interfaces/ gives # Wireless adapter #1 allow-hotplug ra0 #auto ra0 #iface ra0 inet static # wpa-ssid SSID # wpa-psk xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx # to generate proper encrypted key: wpa_passphrase yourSSID yourpassword g@orangepipc:~$ ifconfig ra0 ra0 Link encap:Ethernet HWaddr 00:00:00:00:00:00 BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) whats wrong with me ? in nmtui it is not visible . Iam using orange pi pc. kindly help.
zgoda_j Posted March 13, 2017 Posted March 13, 2017 Network Manager manages only interfaces not configured elsewhere. Remove it from /etc/network/interfaces first if you want it to be managed by NM.
premo Posted March 13, 2017 Author Posted March 13, 2017 You mean all of this ? # Wired adapter #1 allow-hotplug eth0 no-auto-down eth0 iface eth0 inet dhcp #address 192.168.0.100 #netmask 255.255.255.0 #gateway 192.168.0.1 #dns-nameservers 8.8.8.8 8.8.4.4 # hwaddress ether # if you want to set MAC manually # pre-up /sbin/ifconfig eth0 mtu 3838 # setting MTU for DHCP, static just: mtu 3838 # Wireless adapter #1 allow-hotplug ra0 #auto ra0 #iface ra0 inet dhcp # wpa-ssid mijlu # wpa-psk queens123 # to generate proper encrypted key: wpa_passphrase mijlu queens123 # Local loopback auto lo iface lo inet loopback
Igor Posted March 13, 2017 Posted March 13, 2017 (edited) allow-hotplug ra0 and this (actually irrelevant). Edited March 13, 2017 by Igor ()
premo Posted March 13, 2017 Author Posted March 13, 2017 @Igor so now I should remove everything in /etc/network/interfaces
tkaiser Posted March 13, 2017 Posted March 13, 2017 4 minutes ago, premo said: I should remove everything in /etc/network/interfaces Exactly, the best interfaces file with recent Armbian builds on all boards except Lamobo R1 looks like this: https://github.com/igorpecovnik/lib/blob/master/config/network/interfaces.network-manager 1
premo Posted March 13, 2017 Author Posted March 13, 2017 looks like doesnt work with my already maked mt7601Usta module . I will do it again after removing.
premo Posted March 13, 2017 Author Posted March 13, 2017 @tkaiser Do you want me to put the file in lib/config/network/interfaces.network-manager coz the file is in /etc/network/ ?
premo Posted March 13, 2017 Author Posted March 13, 2017 clone again but doesnt work my nmcli : @orangepipc:~$ sudo nmtui [sudo] password for g: (nmtui:878): libnm-CRITICAL **: nm_utils_ssid_to_utf8: assertion 'ssid != NULL' failed g@orangepipc:~$ sudo nmtui g@orangepipc:~$ sudo nmcli Usage: nmcli [OPTIONS] OBJECT { COMMAND | help } OPTIONS -t[erse] terse output -p[retty] pretty output -m[ode] tabular|multiline output mode -c[olors] auto|yes|no whether to use colors in output -f[ields] <field1,field2,...>|all|common specify fields to output -e[scape] yes|no escape columns separators in values -a[sk] ask for missing parameters -s[how-secrets] allow displaying passwords -w[ait] <seconds> set timeout waiting for finishing operations -v[ersion] show program version -h[elp] print this help OBJECT g[eneral] NetworkManager's general status and operations n[etworking] overall networking control r[adio] NetworkManager radio switches c[onnection] NetworkManager's connections d[evice] devices managed by NetworkManager a[gent] NetworkManager secret agent or polkit agent m[onitor] monitor NetworkManager changes g@orangepipc:~$ sudo nmcli g STATE CONNECTIVITY WIFI-HW WIFI WWAN-HW WWAN disconnected none enabled enabled enabled enabled g@orangepipc:~$ sudo nmcli c NAME UUID TYPE DEVICE Wifi1 26a2722c-e968-4e8e-89b4-e01de9e43944 802-11-wireless -- g@orangepipc:~$ sudo nmcli r WIFI-HW WIFI WWAN-HW WWAN enabled enabled enabled enabled g@orangepipc:~$ sudo nmcli c NAME UUID TYPE DEVICE Wifi1 26a2722c-e968-4e8e-89b4-e01de9e43944 802-11-wireless -- g@orangepipc:~$ sudo nmcli d DEVICE TYPE STATE CONNECTION eth0 ethernet disconnected -- lo loopback unmanaged -- tunl0 unknown unmanaged -- g@orangepipc:~$ sudo nmcli ds Error: Object 'ds' is unknown, try 'nmcli help'. g@orangepipc:~$ sudo nmcli a nmcli successfully registered as a NetworkManager's secret agent. ** (process:927): WARNING **: Unable to register authentication agent: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: An authentication agent already exists for the given subject
tkaiser Posted March 13, 2017 Posted March 13, 2017 1 hour ago, premo said: Do you want me to put the file in lib/config/network/interfaces.network-manager No, just use an empty /etc/network/interfaces or comment at least the ra0 line out. Then restart the board, run TERM=linux sudo nmtui and in case it still doesn't work follow the usual procedure: https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-provide-boot-logs-for-inspection
premo Posted March 18, 2017 Author Posted March 18, 2017 doesn't work so Im back to Debian, but Debian 2.25 desktop is not available for download so 2.20 will suffice
mariuszb Posted March 18, 2017 Posted March 18, 2017 Eg. try etc/network/interfaces/: Quote auto ra0 alow-hotplug ra0 iface ra0 inet static address 192.168.0.100 netmask 255.255.255.0 gateway 192.168.0.1 wpa-ssid 'name of wlan ssid you are connected to' wpa-psk 'Your wlan password you are connected to' dns-nameservers 8.8.8.8 end restart
