Stefanita Vilcu Posted April 26 Posted April 26 Hello, I have a bunch of boards (rpi4b, rpi5, orangepi5, orangepi5-plus, nanopct6, rock3a, rock5b, vim4) in a Kubernetes cluster using Cilium. Cilium requires CONF_SCHEDSTATS=y in the kernel, which is dependent on CONFIG_DEBUG_KERNEL=y but... in build/lib/functions/compilation/armbian-kernel.sh we have # DONE: Disable: debug option kernel_config_set_n DEBUG_KERNEL # Armbian doesn't know how to package a debug kernel. Which invalidates the option I enabled during ./compile.sh BOARD=... BRANCH=... kernel-config Except for the VIM4, with DEBUG_KERNEL enabled in build/config/sources/families/meson-s4t7.conf Is there a way to enable DEBUG_KERNEL for the rest of the boards? Thank you! Stefanita Vilcu 0 Quote
Werner Posted April 26 Posted April 26 Well you can try to disable the mentioned switch and see what goes wrong when packaging happens. Then you need to figure out how to fix it. 0 Quote
going Posted April 26 Posted April 26 4 часа назад, Stefanita Vilcu сказал: Which invalidates the option I enabled during ./compile.sh BOARD=... BRANCH=... kernel-config Except for the VIM4, with DEBUG_KERNEL enabled in build/config/sources/families/meson-s4t7.conf Is there a way to enable DEBUG_KERNEL for the rest of the boards? The developers of Armbian have signed their own impotence with this. They cannot or do not want to add support for creating an additional package with debugging symbols. If we look at simple scripts for creating debian packages directly in the kernel source codes, we will see that the debugging package is created automatically when the configuration option is selected: CONFIG_DEBUG_INFO The only way is to change the script of the build system itself by removing these lines and adding 10 lines to the script to create a debugging package. With respect to all free software developers. Leonid. 0 Quote
going Posted April 26 Posted April 26 15 минут назад, going сказал: The developers of Armbian have signed their own impotence with this. @Igor This line may sound rude, but you are probably waiting for the developers of the source code to take some action to improve patches or kernel settings. As long as this heresy is present in the build system (bad package build scripts), the project will receive crumbs from what developers can and do locally. 0 Quote
Stefanita Vilcu Posted April 26 Author Posted April 26 Since what I need is only /proc/schedstats and not a debug package probably my task will be a little simple. I will let you know about the result. Thank you very much! Stefanita Vilcu 0 Quote
Stefanita Vilcu Posted April 26 Author Posted April 26 Hello, I am happy to report that after I commented the lines from the build/lib/functions/compilation/armbian-kernel.sh script and manually doing a "pip install pylibfdt" (because it was complaining that it cannot compile it due to a missing "ld" which was there, in /usr/bin/ld), I was able to compile the edge kernel for rpi5b. No other steps were required. Now I have /proc/schedstats which will make cilium happy, I hope. Probably there will be no problems with the rest of the boards. Thank you very much for the great work you are doing! Stefanita Vilcu 0 Quote
