AlexTransit Posted May 9, 2024 Posted May 9, 2024 Good afternoon. I don't know how to solve a small problem. There is Orange Pi Lite. It runs its own program. The program uses spi-dev and display. You need to compile drivers for the network card. And then a problem arose. I cannot install linux-headers-current-sunxi on a working distribution (the latest one available on the website Armbian_23.02.2 5.15.93 ). And if you set “Community maintained”, then it is impossible to enable spi-dev and the display (Arbian-Config is missing in the repository) How to solve this problem? 0 Quote
Igor Posted May 9, 2024 Posted May 9, 2024 3 hours ago, AlexTransit said: Arbian-Config is missing in the repository apt install armbian-config 0 Quote
AlexTransit Posted May 9, 2024 Author Posted May 9, 2024 Quote apt install armbian-config thanks for the hint. Arbian-Config is missing in the repository OPILite Welcome to Armbian_community 24.5.0-trunk.540 Bookworm with Linux 6.6.30-current-sunxi $ sudo apt list "armbian-*" Listing... Done armbian-bsp-cli-orangepilite-current/now 24.5.0-trunk.540 armhf [installed,local] armbian-firmware/now 24.5.0-trunk.540 all [installed,local] $ uname -a Linux vm00 6.6.30-current-sunxi #1 SMP Thu May 2 14:32:50 UTC 2024 armv7l GNU/Linux Tomorrow I'll try to compile dts into dtb and register it in overlay manually. I'll write about the results 0 Quote
AlexTransit Posted May 10, 2024 Author Posted May 10, 2024 Did not work out sudo dtc -@ -I dts -O dtb -o /boot/overlay-user/st7789.dtbo st7789.dts added user_overlays=st7789 to /boot/armbianEnv.txt after a reboot the log constantly writes May 10 08:18:48 vm00 kernel: fb_st7789v spi0.1: fbtft_update_display: write_vmem failed to update display buffer May 10 08:18:48 vm00 kernel: fb_st7789v spi0.1: write() failed and returned -22 May 10 08:18:48 vm00 kernel: fb_st7789v spi0.1: write() failed and returned -22 Probably dts running on the previous firmware is not suitable for this one. my knowledge is not enough i use one spi for external device and for display spi-dev uses cs=0 display uses cs=1 Spoiler /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&pio>; __overlay__ { st7789v_pins: st7789v_pins { pins = "PA8", "PA9", "PA10"; function = "gpio_out", "gpio_out", "gpio_out"; }; }; }; fragment@1 { target = <&spi0>; __overlay__ { #address-cells = <1>; #size-cells = <0>; status = "okay"; cs-gpios = <0>,<&pio 0 20 0>; /*cs0=no change, cs1=20 (PA20) */ st7789v: st7789v@0 { compatible = "sitronix,st7789v"; reg = <1>; /* use cs1 */ pinctrl-names = "default"; pinctrl-0 = <&st7789v_pins>; rotate = <0>; fps = <25>; buswidth = <8>; reset-gpios = <&pio 0 10 1>; dc-gpios = <&pio 0 9 0>; led-gpios = <&pio 0 8 0>; debug = <0>; }; }; }; }; 0 Quote
AlexTransit Posted May 10, 2024 Author Posted May 10, 2024 checked in detail. spi-dev - it works (in the new firmware) gpio - it works key the path by name is different ( /dev/input/by-path/platform-gpio-keys-event ) I haven't been able to launch the display on spi0.1 yet 0 Quote
AlexTransit Posted May 16, 2024 Author Posted May 16, 2024 I found out what the problem was. in the st7789v driver. need to indicate something. that I don’t know. $ uname -a Linux vm00 6.6.30-current-sunxi #1 SMP Thu May 2 14:32:50 UTC 2024 armv7l GNU/Linux I connected ili9341 - everything works. initialized the controller via DTS - works. I'll try to launch st7789v through custom initialization I'll write about the results PS there were already problems with the st7789v driver on kernel 5.4 (initialized incorrectly) on kernel 6.6 there are also some problems. 0 Quote
Solution AlexTransit Posted May 18, 2024 Author Solution Posted May 18, 2024 solved. the display on the ST7789V use spi0.1 spidev use spi0.0 Could not run on the built-in driver. I get st7789v spi0.1: error -EINVAL: Failed to setup spi fb_st7789v spi0.1: write() failed and returned -22 did the ST7789V initialization manually /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&pio>; __overlay__ { st7789v_pins: st7789v_pins { pins = "PA8", "PA9", "PA10", "PA20"; function = "gpio_out", "gpio_out", "gpio_out", "gpio_out"; }; }; }; fragment@1 { target = <&spi0>; __overlay__ { #address-cells = <1>; #size-cells = <0>; status = "okay"; cs-gpios = <&pio 2 3 1>,<&pio 0 20 1>; spidev@0 { compatible = "armbian,spi-dev"; reg = <0>; spi-max-frequency = <1000000>; }; display: display@1 { /* compatible = "sitronix,st7789v"; */ compatible = "samsung,s6d02a1"; reg = <1>; /* use cs1. required 1 in section display@1 */ pinctrl-names = "default"; pinctrl-0 =<&st7789v_pins>; spi-max-frequency = <16000000>; rotate = <180>; /* in init rotate 0x1000036 0xXX 0(XX=00) 90(XX=a0) 180(XX=36 c0) 270(XX=60) */ width = <240>; height = <320>; spi-cpol; buswidth = <8>; txbuflen = <153600>; reset-gpios = <&pio 0 10 1>; dc-gpios = <&pio 0 9 0>; led-gpios = <&pio 0 8 0>; debug = <0>; init = < 0x1000001 0x2000096 0x1000011 0x100003a 0x05 0x10000b2 0x05 0x05 0x00 0x33 0x33 0x10000b7 0x75 0x10000c2 0x01 0xff 0x10000c3 0x13 0x10000c4 0x20 0x10000bb 0x22 0x10000c5 0x20 0x10000d0 0xa4 0xa1 0x1000029 0x1000021 0x1000036 0xc0 0x100002a 0x00 0x00 0x00 0xef 0x100002b 0x00 0x00 0x01 0x3f 0x100002c 0x10000e0 0xd0 0x05 0x0a 0x09 0x08 0x05 0x2e 0x44 0x45 0x0f 0x17 0x16 0x2b 0x33 0x10000e1 0xd0 0x05 0x0a 0x09 0x08 0x05 0x2e 0x43 0x45 0x0f 0x16 0x16 0x2b 0x33 0x2000064 >; }; }; }; }; everything works perfectly. PS I don't know how to fix the topic header. problem solved 0 Quote
Bryan Mehall Posted February 3, 2025 Posted February 3, 2025 Hi, I'm having the exact same error: st7789v spi0.0: error -EINVAL: Failed to setup spi st7789v: probe of spi0.0 failed with error -22 but haven't been able to solve it. I noticed that you commented out the compatible = "sitronix,st7789v"; line and replaced it with a samsung device. Did you get it to work with the st7789? What do you mean by that you did the st7789 initialization manually? Any other advice for getting it to work? Any help is much appreciated. Thanks! 0 Quote
AlexTransit Posted February 4, 2025 Author Posted February 4, 2025 (edited) 11 hours ago, Bryan Mehall said: line and replaced it with a samsung device. Did you get it to work with the st7789? yes 11 hours ago, Bryan Mehall said: What do you mean by that you did the st7789 initialization manually? yes. 100% works on v24.11.1 for Orange Pi Lite running Armbian Linux 6.6.62-current-sunxi and Orange Pi PC2 (23.05.1 Bookworm with Linux 6.1.30-sunxi64) Perhaps not to change the front of the SPI signal. remove or comment this /*spi-cpol;*/ Edited February 4, 2025 by AlexTransit 0 Quote
