kavaika Posted April 1, 2017 Posted April 1, 2017 Hello, I'm interested in how to run the application calculated for a normal computer x86_64 (ubuntu), since the architecture arm is not supported, you need to do it as a bypass, in the application I post the script that I need to install. This is a radio bot. help me please sinusbot_installer.sh
gnasch Posted April 1, 2017 Posted April 1, 2017 Programs compiled for AMD64 will not execute on ARM CPU's under armbian. This is not the problem of armbian, you would have to emulate the AMD64 CPU for doing this. Easier to select another program or look for an Intel NUC. hth, gnasch
kavaika Posted May 24, 2017 Author Posted May 24, 2017 Hello, please tell me how to install 16 or 17 version of Kodi for bananapi m2+ is first set 15.2
renaudrenaud Posted May 26, 2017 Posted May 26, 2017 Reading your messages it seems you have few little knowledge in computers and computer science. Maybe you would better to buy a Raspberry Pi and install Kodi on it: it will work with zero problem and you will save a huge amount of time. And also you would find with Raspberry more documentation and a huge community more patient than... https://www.raspberrypi.org/downloads/
Igor Posted May 26, 2017 Posted May 26, 2017 Kodi with Openelec from @jernej on M2+ also works o.k. http://down.nu/images
