5 hours ago, Technicavolous said:
I looked at that info on the 4g. I get lost in how to form the udev rules.
I know. Help from @Stanislav Sinyagin would be awesome at this point, but I haven't saw him for some time. My experiences with 4G are limited.
With your armbian-config utility being so awesome
Thank you. It all started with a wish to script things which I use for my purpose, mainly to setup ISP config, which I still use for my personal / armbian needs. Then things get extended and I hope other people will add and maintain their part of the script. This is already quite big chunk of code and time consuming to maintain, especially at major upstream (new release) changes.
Just caught another friendly server platform called yunohost that has an Armbian-installer....   would be an easy thing to add to software packages it looks like
everyone likes curl | sudo bash right?
https://yunohost.org/en/install/hardware:arm_unsup#fa-rocket-run-the-install-script
