Orange Pi PC = Server = Debian Jessie
Programs does not start automatically at boot,  I tested the deluge, transmission and vsftpd;
Same commands used in Raspbian Jessie: Does not start automatic:
sudo update-rc.d deluge-daemon defaults
sudo update-rc.d transmission-daemon defaults
Edited by Igor
formatting
This is very complicated for me, , I usually find tutorials ready to install programs,
I would not know how to do these boot modifications
IIRC if you install Transmission with this command:
apt install transmission-cli transmission-common transmission-daemon
you don't need to do anything else. It starts automatically. Similar goes for others ... just follow generic Debian & Ubuntu install guides and you should be fine.
It is possible that the transmission "issue" is this - wrong start order in relation to network related services:
which is not an Armbian issue since it comes from upstream releases, and AFAIK there is no proper solution for this yet, only workarounds.
I installed it now, but it does not start automatically, to start I have to use  sudo service transmission-daemon stop
command and then sudo service transmission-daemon start
29 minutes ago, Igor said:
Now add this to /etc/rc.local and it will.
open sudo nano /etc/rc.local and add this sudo service transmission-daemon start ?
