Posted (edited)
On 4/11/2025 at 10:38 AM, Keko said:
(ideally something around 10fps, for 1920x1080 frames) on the H96 max M9s.
that's really a good performance, congratulations
for comparison i do 3fps 320x240 on rk3566
Edited by Hqnicolas
Seems like I got some progress/regress with the board - I added some extra arguments in the armbianEnv.txt file - verbosity=7 and extraargs debug to try and see what the reason for the freeze might be and these three jobs were stuck, resulting in a kernel panic (end Kernel panic - not syncing: panic_On_set_idle_set) - systemd-udev-trigger.service/start, dev-ttyFIQ0.device/start and systemd-tmpfiles-setup-dev.service/start. Tried disabling the FIQ0 node in the dts (at least I think so), but the UART just stopped and it hanged again (the Armsom Sige 5 also has this in its dt). Managed to get a few times in initramfs, but it wans't helping me in the slightest. When adding init=/bin/bash, I could also avoid the hang, but it wasn't that productive.
Good news and bad news - I found the culprit for the kernel panic, but it's the GPU - once I blacklisted the panfrost module, it booted and completed the initial setup. The rknpu driver is v0.9.8, so it should be usable with the immich ML. Probably will try to investigate the GPU issue, but not anytime soon.
Hey, @xiaobao80! Sadly not - but on the upside I was able to build and use the latest kernel.
Also want to update and say that I did manage to use the NPU and the VPU successfully with Immich AI facial recognition and Jellyfin transcoding respectively.
@xiaobao80, The official use is the closed source Mali library. Panfrost is an open-source GPU library.
It should be that the Panfrost module does not yet support rk3576
hey, @cmuki!
Using the dts from the rk3576-evb1-v10 / rk3576-armsom-sige5 / rk3576-rock-4d in the https://github.com/radxa/kernel/arch/arm64/boot/dts/rockchip/ directory
After modification, they can all boot the Armbian version h96-m9s
Note: The rk3576-linux.dtsi file forcibly specifies the UUID of the rootfs device partition, which may cause system boot failure.
Adjustments might be needed.
The basic modification method is simple: disable the PCIe and GMAC1 configurations, modify the reset_pin configuration of GMAC0 to
gpio2 and PB3 to enter the system. I used rock-4d as the template for modification.
Other modifications have not been thoroughly studied yet.
Posted (edited)
I only tested the main configuration to ensure that the kernel and file system rootfs are normal, and other configurations have not been tested yet
The attachments are patch files and several modified source files.
The testing was conducted in my own buildroot project.
It has not been tested in armbian yet (there are currently some issues with the armbian compilation environment).
My buildroot project was launched based on the DTS of this post.
I believe it should be available in armbian.
add-rk3576h96-m9s-dts.patch
rk3576-linux.dtsirk3576-h96-m9s.dtsrk3576.dtsi
Edited by darcyg
Hi,
I got new H96 Max M9S and would like to ask some questions before flashing armbian on the device.
1. In this thread reset button is mentioned and I cannot find one on the case and neither on the board. Is there o photo of it or is it another name for maskrom switch?
2. I intend to flash from Linux, is the following method correct:
  - put device in maskrom mode
  - connect it to a computer by a USB A-A cable (to USB 2.0 port)
  - on a computer: rkdeveloptool ld (to list recognized devices)
  - on a computer: rkdeveloptool db RK3576_MiniLoaderAll.bin
  - on a computer: rkdeveloptool wl 0 h96_max_m9s_rk3576_20240930_1033.img
  - restart H96 Max M9S
I also have a question regarding building Armbian image: which dtb file should I use to put in directory build/packages/blobs/h96-m9/  (is it H96-RK3576-BOX.dtb)?
Best Regards and keep up the good work.
the manufacturer hates us, that's it
There is no method, they are all hobbyist experiments
Posted (edited)
Hey, @arbeiter!
It shouldn't be necessary to put the device in Maskrom mode, Loader mode should be enough - you can do that by using a toothpick to activate the reset button in the 3.5 mm jack (example photo attached) before plugging the device with the USB-A-USB-A cable.
For the flashing - you should run
rkdeveloptool ld (to list recognized devices) and see if the box is in LOADER mode
rkdeveloptool write 0 Ambian-unofficial...
Here should be the latest gnome desktop verison that I compiled. Please be advised that your version is M9S and, as far as I know, the only difference is that M9 comes with Android and M9S comes with Android TV; this image hasn't been tested on M9S. Don't forget to freeze the kernel updates from armbian-config; you should be able to update the other packages normally after this.
For me the box has been stable, no hangs whatsover and, as described, the VPU and the NPU work, but the GPU doesn't (that's why it's blacklisted). Haven't tried the remote nor the LCD screen.
Edited by cmuki
Hi there!
We have some good news, a guy from the 4pda forums figured out how to make the missing SD slot work. I've replicated that on my M9s box a few days ago and it works like a charm. You can see original post in Russian here.
So, basically, this TV box uses the same reference design for that circuitry as Armsom Sige5 and other boards. You can check the diagrams for Sige5 to get an idea. You need two capacitors (10uF and 100nF, on the power line) on the SD slot side (two smaller pads) and a LPW5202ADB5F chip and some resistors and caps on the other side.
LPW5202ADB5F is a power switch chip with current limiter, can be bought on Aliexpress for like $5-6 for 20 pcs, also need these components:
1x 10k resistor - controls current limiter (this value is for 0.7A according to data sheet, lower values for higher current, or 3.6k = 2A),
2x 10uF caps on power input/output lines
1x 100k - pull down resistor on the 'enable' contact
1x 2k - limiting resistor from the CPU to the 'enable' line
6x 22 Ohm resistors for the data lines between CPU and SD card slot
In theory, it's possible to put a zero-ohm resistor between in and out instead of that switch chip, in that case SD slot will be powered all the time and won't have a current limiter.
Posted (edited)
@darcyg    @ Hqnicolas    rk3576-h96-m9s.dts     rk3576 -h96-m9s-linux.dtsi     armsom-sige5-rk3576_defconfig
1.Reset button in UBOOT OK
2. video acceleration OK  work.。kodi video acceleration  Armbian-unofficial_25.11.0-trunk_H96-m9_bookworm_vendor_6.1.115-backported-mesa.img  https://drive.google.com/drive/folders/1lzLwm9NhxZ_0_mghKG4A0XQ6NNsU9sn-?usp=drive_link
kodi   https://github.com/armsurvivors/kodi-rockchip-deb
3. When turning off the box, the lights are still on. Probably - it is not really turned off.
4. No wifi  No Bluetooth
Spoiler
1.thumb.png.a7fe56cf69a8a2c64cb5e7539404e1e6.png2.thumb.png.7a993c2702bb15236a421d95c98a84c5.png
Edited by xiaobao80
This is an H96Max Factory default work around, no TV box device really turn off,
it's the way the factory deal with the "remote control" power on function,
the device is always waiting for a IR remote control to trigger.
You can find a way around it on the pmic section from DTS.
Thats a problem caused by BOM of materials in the factory,
they start to use a new wifi card because of chip shortages.
You can work around it using this method
Modified based on nanopi-r76s.dts, both wireless and Bluetooth networks are working properly. There is no 3.5 interface fiber optic interface audio in DTS, and the standard infrared remote control cannot be used
4k hardware acceleration mpv kodi is normal
Compile-configuration.zip
h96-m9s-rk3576_defconfig rk3576-h96-m9s.dts rk3576-h96-m9s1.dts rc.local h96-m9.config rk3576-h96-m9s.dts h96-m9.tvb Compile-configuration.zip
Posted (edited)
here is my dts for android rkr7.1 sdk 6.1.141 with everything working
usb2 host
usb3 otg/host
hdmi
ethernet
3.5mm
spdif
IR + wakeup
wifi
BT
collect info for adding your remote to dts
echo 1 > /sys/module/rk_pwm_remotectl/parameters/code_print
m9.dts
Edited by RealAn
@RealAn DTS for Kernel 6.1:
Unfortunately, all boards for TV Box device are embargoed upon landing in my country's territory.
If any Golden Knight wants to do the development, I believe this is a good time.
Quote
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
 * Copyright (c) 2024 Rockchip Electronics Co., Ltd.
 * Copyright (c) 2024 Radxa Computer (Shenzhen) Co., Ltd.
/dts-v1/;
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/pinctrl/rockchip.h>
#include <dt-bindings/input/rk-input.h>
#include <dt-bindings/display/rockchip_vop.h>
#include "rk3576.dtsi"
#include "rk3576-android.dtsi"
#include "rk3576-rk806.dtsi"
#include "rk3576-virtual-poweroff.dtsi"
	model = "Rockchip RK3576 EVB1 V10 Board";
	compatible = "rockchip,rk3576-evb1-v10", "rockchip,rk3576";
	vcc_sys: vcc5v0-sys {
		compatible = "regulator-fixed";
		regulator-name = "vcc_sys";
		regulator-always-on;
		regulator-boot-on;
		regulator-min-microvolt = <5000000>;
		regulator-max-microvolt = <5000000>;
	vcc_2v0_pldo_s3: vcc-2v0-pldo-s3 {
		regulator-name = "vcc_2v0_pldo_s3";
		regulator-boot-on;
		regulator-min-microvolt = <2000000>;
		regulator-max-microvolt = <2000000>;
		vin-supply = <&vcc_sys>;
	vcc_1v1_nldo_s3: vcc-1v1-nldo-s3 {
		regulator-name = "vcc_1v1_nldo_s3";
		regulator-boot-on;
		regulator-min-microvolt = <1100000>;
		regulator-max-microvolt = <1100000>;
	vcc_1v8_s0: vcc-1v8-s0 {
		regulator-name = "vcc_1v8_s0";
		regulator-boot-on;
		regulator-min-microvolt = <1800000>;
		regulator-max-microvolt = <1800000>;
		vin-supply = <&vcc_1v8_s3>;
	vcc_3v3_s0: vcc-3v3-s0 {
		regulator-name = "vcc_3v3_s0";
		regulator-boot-on;
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		vin-supply = <&vcc_3v3_s3>;
	vcc5v0_host: vcc5v0-host {
		regulator-name = "vcc5v0_host";
		regulator-boot-on;
		enable-active-high;
		gpio = <&gpio0 RK_PC7 GPIO_ACTIVE_HIGH>;
		pinctrl-names = "default";
		pinctrl-0 = <&usb_host_pwren>;
	vcc5v0_otg: vcc5v0-otg {
		regulator-name = "vcc5v0_otg";
		enable-active-high;
		gpio = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>;
		pinctrl-0 = <&usb_otg_pwren>;
	hdmi_sound: hdmi-sound {
		compatible = "rockchip,hdmi";
		rockchip,mclk-fs = <128>;
		rockchip,card-name = "rockchip-hdmi";
		rockchip,cpu = <&sai6>;
		rockchip,codec = <&hdmi>;
		rockchip,jack-det;
	gpio-keys {
		compatible = "gpio-keys";
		autorepeat;
		power {
			debounce-interval = <100>;
			gpios = <&gpio0 RK_PD3 GPIO_ACTIVE_LOW>;
			label = "GPIO Key Power";
			linux,code = <KEY_POWER>;
			wakeup-source;
	leds: leds {
		compatible = "gpio-leds";
		work-green {
			gpios = <&gpio0 RK_PD1 GPIO_ACTIVE_LOW>;
			linux,default-trigger = "backlight";
			default-state = "on";
			retain-state-suspended;
			retain-state-shutdown;
		work-red {
			gpios = <&gpio0 RK_PD0 GPIO_ACTIVE_HIGH>;
		pwr-wifi {
			gpios = <&gpio1 RK_PC6 GPIO_ACTIVE_HIGH>;
			linux,default-trigger = "none";
	sdio_pwrseq: sdio-pwrseq {
		compatible = "mmc-pwrseq-simple";
		pinctrl-0 = <&wifi_poweren_gpio>;
		 * On the module itself this is one of these (depending
		 * on the actual card populated):
		 * - SDIO_RESET_L_WL_REG_ON
		 * - PDN (power down when low)
		post-power-on-delay-ms = <200>;
		reset-gpios = <&gpio0 RK_PD2 GPIO_ACTIVE_LOW>;
		status = "okay";
	wireless_bluetooth: wireless-bluetooth {
		compatible = "bluetooth-platdata";
		uart_rts_gpios = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>;
		pinctrl-names = "default", "rts_gpio";
		pinctrl-0 = <&uart4m1_rtsn>;
		pinctrl-1 = <&uart4m1_rts_gpio>;
		BT,wake_gpio = <&gpio1 RK_PD4 GPIO_ACTIVE_HIGH>;
//		BT,reset_gpio    = <&gpio1 RK_PC7 GPIO_ACTIVE_HIGH>;
		BT,wake_host_irq = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>;
		status = "okay";
	wireless_wlan: wireless-wlan {
		compatible = "wlan-platdata";
		pinctrl-0 = <&wifi_host_wake_irq>;
		WIFI,host_wake_irq = <&gpio0 RK_PB0 GPIO_ACTIVE_HIGH>;
		status = "okay";
	ht5010_sound_out: ht5010_sound-out {
		compatible = "rockchip,dummy-codec";
		clocks = <&mclkout_sai1>;
		clock-names = "mclk";
		pinctrl-0 = <&sai1m0_mclk>;
		#sound-dai-cells = <0x00>;
		status = "okay";
	ht5010-sound {
		compatible = "simple-audio-card";
		simple-audio-card,mclk-fs = <256>;
		simple-audio-card,name = "rockchip,es8388";
		simple-audio-card,format = "i2s";
		status = "okay";
		simple-audio-card,cpu {
			sound-dai = <&sai1>;
		simple-audio-card,codec {
			sound-dai = <&ht5010_sound_out>;
	spdif_tx0_dc: spdif-tx0-dc {
                compatible = "linux,spdif-dit";
                status = "okay";
        spdif-tx0-sound {
                simple-audio-card,mclk-fs = <128>;
                simple-audio-card,name = "rockchip,spdif-tx1";
                status = "okay";
                simple-audio-card,dai-link@0 {
                        cpu {
                                sound-dai = <&spdif_tx1>;
                        codec {
                                sound-dai = <&spdif_tx0_dc>;
&cpu_l0 {
	cpu-supply = <&vdd_cpu_lit_s0>;
&cpu_b0 {
	cpu-supply = <&vdd_cpu_big_s0>;
&crypto {
	status = "okay";
&gpu {
	mali-supply = <&vdd_gpu_s0>;
	status = "okay";
&iep {
	status = "okay";
&iep_mmu {
	status = "okay";
&jpegd {
	status = "okay";
&jpege {
	status = "okay";
&jpeg_mmu {
	status = "okay";
&mpp_srv {
	status = "okay";
&rga2_core0 {
	status = "okay";
&rga2_core0_mmu {
	status = "okay";
&rga2_core1 {
	status = "okay";
&rga2_core1_mmu {
	status = "okay";
&rknpu {
	rknpu-supply = <&vdd_npu_s0>;
	status = "okay";
&rknpu_mmu {
	status = "okay";
&rkvenc_ccu {
	status = "okay";
&rkvenc0 {
	status = "okay";
&rkvenc0_mmu {
	status = "okay";
&rkvenc1 {
	status = "okay";
&rkvenc1_mmu {
	status = "okay";
&rkvdec {
	status = "okay";
&rkvdec_mmu {
	status = "okay";
&saradc {
	status = "okay";
	vref-supply = <&vcca_1v8_s0>;
&tsadc {
	status = "okay";
&vdpp {
	status = "okay";
&vop {
	status = "okay";
	disable-win-move;
	vop-supply = <&vdd_logic_s0>;
&vop_mmu {
	status = "okay";
&vp0 {
	rockchip,plane-mask = <(1 << ROCKCHIP_VOP2_CLUSTER0 | 1 << ROCKCHIP_VOP2_ESMART0 |
				1 << ROCKCHIP_VOP2_CLUSTER1 | 1 << ROCKCHIP_VOP2_ESMART1)>;
	rockchip,primary-plane = <ROCKCHIP_VOP2_ESMART0>;
	cursor-win-id = <ROCKCHIP_VOP2_ESMART1>;
&vp1 {
	status = "disabled";
&vp2 {
&display_subsystem {
	clocks = <&hdptxphy_hdmi>;
	clock-names = "hdmi0_phy_pll";
&hdmi {
	status = "okay";
	cec-enable = <1>;
	audio-no-capture;
	enable-gpios = <&gpio2 RK_PB0 GPIO_ACTIVE_HIGH>;
&hdmi_in_vp0 {
	status = "okay";
&hdmi_in_vp1 {
&hdmi_in_vp2 {
&hdptxphy_hdmi {
	status = "okay";
&route_hdmi {
	status = "okay";
	connect = <&vp0_out_hdmi>;
&gmac0 {
	/* Use rgmii-rxid mode to disable rx delay inside Soc */
	phy-mode = "rgmii-rxid";
	clock_in_out = "output";
	snps,reset-gpio = <&gpio2 RK_PB3 GPIO_ACTIVE_LOW>;
	snps,reset-active-low;
	snps,reset-delays-us = <0 20000 100000>;
	pinctrl-0 = <&eth0m0_miim
		     &eth0m0_tx_bus2
		     &eth0m0_rx_bus2
		     &eth0m0_rgmii_clk
		     &eth0m0_rgmii_bus
		     &ethm0_clk0_25m_out>;
	tx_delay = <0x1b>;
	/* rx_delay = <0x3f>; */
	phy-handle = <&rgmii_phy0>;
	status = "okay";
&mdio0 {
	rgmii_phy0: phy@1 {
		compatible = "ethernet-phy-ieee802.3-c22";
		reg = <0x1>;
		clocks = <&cru REFCLKO25M_GMAC0_OUT>;
&sai1 {
	status = "okay";
	pinctrl-0 = <&sai1m0_lrck
		     &sai1m0_sclk
		     &sai1m0_sdi0
		     &sai1m0_sdo2>;
&sai6 {
	status = "okay";
&sdmmc {
	max-frequency = <200000000>;
	no-sdio;
	no-mmc;
	bus-width = <4>;
	cap-mmc-highspeed;
	cap-sd-highspeed;
	disable-wp;
	sd-uhs-sdr104;
	vqmmc-supply = <&vccio_sd_s0>;
	status = "okay";
&combphy0_ps {
	status = "okay";
&combphy1_psu {
	status = "okay";
&u2phy0 {
	status = "okay";
&u2phy0_otg {
	phy-supply = <&vcc5v0_otg>;
	status = "okay";
&usb_drd0_dwc3 {
	extcon = <&u2phy0>;
	dr_mode = "otg";
	status = "okay";
&usbdp_phy {
	rockchip,dp-lane-mux = <2 3>;
	status = "okay";
&usbdp_phy_dp {
&usbdp_phy_u3 {
	status = "okay";
&u2phy1 {
	status = "okay";
&u2phy1_otg {
	phy-supply = <&vcc5v0_host>;
	status = "okay";
&usb_drd1_dwc3 {
	dr_mode = "host";
	status = "okay";
&pinctrl {
	usb {
		usb_host_pwren: usb-host-pwren {
			rockchip,pins = <0 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>;
		usb_otg_pwren: usb-otg-pwren {
			rockchip,pins = <0 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>;
		uart4m1_rts_gpio: uart4m1-rts-gpio {
			rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>;
	wireless-wlan {
		wifi_host_wake_irq: wifi-host-wake-irq {
			rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_down>;
		wifi_poweren_gpio: wifi-poweren-gpio {
			rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>;
&sdhci {
	bus-width = <8>;
	no-sdio;
	no-sd;
	non-removable;
	mmc-hs400-1_8v;
	mmc-hs400-enhanced-strobe;
	full-pwr-cycle-in-suspend;
	status = "okay";
&sdio {
	no-sd;
	no-mmc;
	bus-width = <4>;
	disable-wp;
	cap-sd-highspeed;
	cap-sdio-irq;
	keep-power-in-suspend;
	mmc-pwrseq = <&sdio_pwrseq>;
	non-removable;
	pinctrl-0 = <&sdmmc1m0_bus4 &sdmmc1m0_clk &sdmmc1m0_cmd>;
	sd-uhs-sdr104;
	status = "okay";
&spdif_tx1 {
	pinctrl-0 = <&spdifm1_tx1>;
	status = "okay";
&uart4 {
	status = "okay";
	pinctrl-0 = <&uart4m1_xfer &uart4m1_ctsn>;
&pwm0_2ch_0 {
	compatible = "rockchip,remotectl-pwm-v4";
	pinctrl-0 = <&pwm0m0_ch0>;
	remote_pwm_id = <0>;
	handle_cpu_id = <1>;
	remote_support_psci = <0>;
	wakeup-source;
	status = "okay";
                ir_key1 {
                        rockchip,usercode = <0xfeaa>;
                        rockchip,key_table = <0xec 0xe8 0xe6 0x9e 0xe9 0x67 0xe5 0x6c 0xae 0x69 0xaf 0x6a 0xee 0x66 0xe7 0x73 0xef 0x72 0xbf 0x74 0xbe 0x71 0xb3 0x8b 0xff 0x184 0xb1 0x18e 0xf2 0x18f 0xf3 0x04 0xb5 0x05 0xf6 0x06 0xf7 0x07 0xb9 0x190 0xfa 0x191 0xfb 0x0a 0xfe 0x0b 0xbd 0x0e 0xbc 0xb7 0xf0 0xba 0xb4 0x19c 0xb8 0x1e 0xb0 0x197>;
                ir_key2 {
                        rockchip,usercode = <0xff00>;
                        rockchip,key_table = <0xf1 0x69 0xe5 0x6a 0xfc 0x67 0xfd 0x6c 0xf8 0xe8 0xf9 0xb8>;
                ir_key3 {
                        rockchip,usercode = <0x1dcc>;
                        rockchip,key_table = <0xee 0xe8 0xf0 0x9e 0xf8 0x67 0xbb 0x6c 0xef 0x69 0xed 0x6a 0xfc 0x66 0xf1 0x73 0xfd 0x72 0xb7 0xd9 0xff 0x74 0xf3 0x71 0xbf 0x8b 0xf9 0x191 0xf5 0x192 0xb3 0x184 0xbe 0x02 0xba 0x03 0xb2 0x04 0xbd 0x05 0xf9 0x06 0xb1 0x07 0xfc 0x08 0xf8 0x09 0xb0 0x0a 0xb6 0x0b 0xb5 0x0e>;
                ir_key4 {
                        rockchip,usercode = <0x7f80>;
                        rockchip,key_table = <0xec 0xe8 0xd8 0x9e 0xc7 0x67 0xbf 0x6c 0xc8 0x69 0xc6 0x6a 0x8c 0x66 0x78 0x73 0x76 0x72 0x7e 0x74 0x7c 0x8b 0xb7 0x184>;
                ir_key5 {
                        rockchip,usercode = <0xfe01>;
                        rockchip,key_table = <0xec 0xe8 0xe6 0x9e 0xe9 0x67 0xe5 0x6c 0xae 0x69 0xaf 0x6a 0xee 0x66 0xe7 0x73 0xef 0x72 0xbf 0x74 0xbe 0x71 0xb3 0x8b 0xff 0x184 0xb1 0x02 0xf2 0x03 0xf3 0x04 0xb5 0x05 0xf6 0x06 0xf7 0x07 0xb9 0x08 0xfa 0x09 0xfb 0x0a 0xfe 0x0b 0xbd 0x0e 0xbc 0xb7 0xf0 0xba 0xb4 0x19c 0xb8 0x1e 0xb0 0x197>;
                ir_key6 {
                        rockchip,usercode = <0xfd01>;
                        rockchip,key_table = <0x31 0xe8 0x2f 0x9e 0x35 0x67 0x2d 0x6c 0x66 0x69 0x3e 0x6a 0x6a 0x66 0x5e 0x73 0x47 0x72 0x23 0x74 0x3a 0x184 0x0d 0x40>;
                ir_key6 {
                        rockchip,usercode = <0xfb04>;
                        rockchip,key_table = <0xf7 0x74 0xd0 0x184 0xb5 0x8b 0x5b 0xb8 0x4d 0xb7 0xba 0x67 0xb9 0x6c 0xb8 0x69 0xb7 0x6a 0xbb 0xe8 0xe5 0x9e 0xe4 0x0e 0xd2 0x66 0xfd 0x73 0xfc 0x72 0xf6 0x71 0xff 0x192 0xfe 0x193 0x04 0x40 0x14 0x41 0x4c 0x42 0x4b 0x43>;
		ir_key8 {
			rockchip,usercode = <0xe619>;
				<0x8b	KEY_POWER>,
				<0x98	KEY_UP>,
				<0x93	KEY_DOWN>,
				<0x96	KEY_LEFT>,
				<0x95	KEY_RIGHT>,
				<0x9e	KEY_ENTER>,
				<0x61	KEY_BACK>;
Hello, I'm from China. I bought an H96 Max M9S (8GB+128GB) for 500 RMB. After reading your discussions, I've learned how to use RKDevTool to flash the Android system via USB. However, I've been struggling for several days and still cannot boot the Armbian system. Could you please tell me how to boot Armbian? Is it possible to flash the Armbian system directly to the eMMC of my M9S using RKDevTool? I really need your help. Thank you very much!
I've successfully booted Armbian from USB following the tutorial above, and I've managed to write Armbian from the USB drive to the eMMC. Now I want to create an Armbian firmware that can be directly flashed to the H96 M9/S eMMC using RKDevTool.exe, but I'm not very smart - even simple things take me a very long time to figure out. If any of you have this, please share it. If I manage to figure it out, I'll also share my findings.
keep pushing, this device is not brickable, you can make your trip worry-free
@xiaobao80I did manage to get 3.5mm working with the help of ChatGPT. The box is using HT5010. ChatGPT told me to disable the es8388 nodes, but it still works with them enabled.
My sai@2a61000 looks like this:
Spoiler
    sai@2a610000 {
        compatible = "rockchip,rk3576-sai\0rockchip,sai-v1";
        reg = <0x00 0x2a610000 0x00 0x1000>;
        interrupts = <0x00 0xbc 0x04>;
        clocks = <0x02 0x4d 0x02 0x4e>;
        clock-names = "mclk\0hclk";
        dmas = <0x6f 0x02 0x6f 0x03>;
        dma-names = "tx\0rx";
        power-domains = <0x03 0x0a>;
        resets = <0x02 0x85 0x02 0x86>;
        reset-names = "m\0h";
        pinctrl-0 = <0x125 0x126 0x127 0x128>;
        sound-name-prefix = "SAI1";
        status = "okay";
        phandle = <0x1a6>;
        rockchip,tx-output = <0x00>;
        rockchip,tx-path = <0x00>;
        rockchip,clk-auto = <0x01>;
My ht5010-sound node looks like this:
Spoiler
    ht5010-sound {
        status = "okay";
        simple-audio-card,mclk-fs = <0x100>;
        phandle = <0x533>;
            sound-dai = <0x1a6>;
            sound-dai = <0x1ab>;
I got bluetooth working with a hack from the Radxa forums here (creating a shell script and adding it to the root's crontab):
Spoiler
#/bin/bash
hciattach -s 1500000 /dev/ttyS4 any 1500000 flow nosleep
rfkill unblock bluetooth
hciconfig hci0 up
I tried to send audio from a TV to the rk3576 box - it did work, but the latency is too much for me.
The brown box has beefier cooling than the purple one.
I haven't recompiled, used my "stable" image from before to fix the 3.5mm issue, might need to recompile to try the GPU driver. Tried the rkr7.1 dts, but couldn't get it to work (might need additional time to look at it); armbian / linux-rockchip is still at rkr5.1.
