Igor Posted December 7, 2015 Posted December 7, 2015 OK, check my update. Not working for me. BASH issue? I think this part is critical: https://github.com/igorpecovnik/lib/blob/master/patching.sh#L54-L56
zador.blood.stained Posted December 8, 2015 Author Posted December 8, 2015 Fixed. Sorting/removing duplicates was broken. Edit: [ o.k. ] Compiling uboot. Please wait. [ 2016.01rc2 ] Looks like displaying u-boot tag is broken. Local version is based on 2015.10
Igor Posted December 8, 2015 Posted December 8, 2015 Cool ! I gave up on this "advanced" git handling, now changing kernel and u-boot sources. Each tags will have own subdir, all with shallow clone of course. u-boot-odroid/unttaged u-boot-odroid/2015.10 u-boot-odroid/2015.04 ... kernel likewise. According to this, I'll fix the compilation part so ... 1
zador.blood.stained Posted December 8, 2015 Author Posted December 8, 2015 Fixed dtb compilation (removed extra space in 0013-lamobo_r1_dts.patch at the beginning of the line). Mainline kernel compilation is working. [ o.k. ] Kernel building done [ @host ] [ o.k. ] File name [ linux-image-next-sunxi_5.00_armhf.deb ] [ o.k. ] Runtime [ 4 min ] BTW, you can add my repo as another remote and merge commits or even branches from it, this way it will be easier for me to merge your changes back into my working copy (and it may be faster and easier for you). Edit: some config names are broken after configuration update: [ o.k. ] Compiling kernel [ @host ] cp: cannot stat ‘/home/zador/armbian/lib/config/linux-sun7i-default.config’: No such file or directory 1
Igor Posted December 8, 2015 Posted December 8, 2015 This lamobo fix was "lost in the crash" together with others small fixes yet to be rediscovered BTW, you can add my repo as another remote and merge commits or even branches from it, this way it will be easier for me to merge your changes back into my working copy (and it may be faster and easier for you). Agreed. I used to merge others snippets via Github pull request. My git handling knowledge need some upgrading I see it's simple but I will do a tests before. ASAP I fixed download / patching part ... will update when I fix this .config part and made few test runs. EDIT: I added another remote to my branch and made some merging w/o problems but I got quite some conflicts which needs slow manual resolving. 1
zador.blood.stained Posted December 9, 2015 Author Posted December 9, 2015 /home/zador/armbian/lib/main.sh: line 264: [: ==: unary operator expected Line 264: [ $CLEAN_LEVEL == 4 ] && cleaning "$CLEAN_LEVEL" Line 292: [ $CLEAN_LEVEL != 4 ] && cleaning "$CLEAN_LEVEL" Something here is not right. I believe line 264 is obsolete and needs to be removed, line 292 should be changed to [ "$CLEAN_LEVEL" != "4" ] && cleaning "$CLEAN_LEVEL"
Igor Posted December 9, 2015 Posted December 9, 2015 All cleaning but removing sources must be done after git operations, right? "" is needed and 264 too
Igor Posted December 9, 2015 Posted December 9, 2015 I am done until evening. Some ideas: - I need to see new kernel features, so make olddefconfig / oldconfig must be an option and always out of dialog - this dialog on/off option would be cool also a blank, no console output, only log - when mostly done we can alter/adjust script names 1
zador.blood.stained Posted December 9, 2015 Author Posted December 9, 2015 At line 264 it complains about "==" operator, which is specific to advanced test ("[["). Hm, missed true meaning of clean level 4, "dell all output" in compile.sh is not descriptive enough in this case
zador.blood.stained Posted December 9, 2015 Author Posted December 9, 2015 My logic with oldconfig/olddefconfig is: if KERNEL_CONFIGURE is true, then process is designed to be interactive and it will ask about new options before bringing menu configuration dialog; otherwise process is not interactive, and it won't ask users about some new kernel options if they don't want to mess with kernel configuration at all, safe defaults will be assumed for new options. If you don't like this, you can change it to always be oldconfig, it's not 100% needed. Make *config right now doesn't use dialog as far as I see. - this dialog on/off option would be cool also a blank, no console output, only log I'll try to implement this next. 1
Igor Posted December 9, 2015 Posted December 9, 2015 Hm, missed true meaning of clean level 4, "dell all output" in compile.sh is not descriptive enough in this case I know. More and better comments are needed. I made few test runs and it looks good ... busy with life until evening. 1
zador.blood.stained Posted December 10, 2015 Author Posted December 10, 2015 For clean level - instead of numbers it can be a list (comma or space separated) of things to clean, i.e. CLEAN_LEVEL="debs,srcdir,make", and it can be implemented like this: if [[ $CLEAN_LEVEL == *debs* ]] ; then rm -rf "$DEST/debs/"; fi
zador.blood.stained Posted December 10, 2015 Author Posted December 10, 2015 I don't know how to implement this with the new cleaning logic # Choosing kernel if debs are present if [[ $BRANCH == "next" ]]; then MYARRAY=($(ls -1 $DEST/debs/linux-image* | awk '/next/' | sed ':a;N;$!ba;s/\n/;/g')) else MYARRAY=($(ls -1 $DEST/debs/linux-image* | awk '!/next/' | sed ':a;N;$!ba;s/\n/;/g')) fi if [[ ${#MYARRAY[@]} != "0" && $KERNEL_ONLY != "yes" ]]; then choosing_kernel; fi Either it needs separate parameter in compile.sh or it needs to be removed or reworked somehow. Edit: I left it commented in main.sh
wildcat_paris Posted December 12, 2015 Posted December 12, 2015 Guys, You have done a tremendeous update for Armbian kernel compiling on current beta "master" branch I have tested BOARD="lamobo-r1" BRANCH="dev" KERNELTAG="v4.4-rc4" PROGRESS_LOG_TO_FILE=yes Everything compiled fine. uBoot 16.01-rc2 kernel 4.4-rc4 to install, I had to remove my [patched kernel 4.3.0 uboot 15.10] *.deb files { next-sunxi } to install "Armbian 5.0 kernel" debs named { dev-sunxi } => file conflicts with the next/dev packages Reboot, I ended with no lamobo-r1 tools "swconfig"... lost the labomo-r1.dts file after a hard reboot... bad karma ok, I have my "emergency sdcard", the labomo-r1 is the heart of my fiber Internet + ethernet/fiber/wifi home network (YES! I have fiber between my bedroom and my main room) I had to extract all [ kernel 4.3 uboot 15.10 ] *.deb to replace the files. I got lucky u-boot 16.01-rc2 did not complained of the trick at reboot. then removed dev-sunxi debs and reapplied the next-sunxi... and my system is back beta testing :-)
zador.blood.stained Posted December 12, 2015 Author Posted December 12, 2015 wildcat_paris So, I didn't exactly understand, dev kernel didn't work for you?
wildcat_paris Posted December 12, 2015 Posted December 12, 2015 wildcat_paris So, I didn't exactly understand, dev kernel didn't work for you? long story short... moving from next-sunxi to dev-sunxi is missing cleaning of next-sunxi first OR just to keep deb package named as "next-sunxi" not "dev-sunxi" (I guess keeping next-sunxi in the debian package name is easier. Because dev is a a bit ahead of next and not really something different) Also for lamobo-r1 the tools in /usr/local/bin are missing (or have been relocated and network config at reboot just failed) So yes, it failed, but the on going modifications of "Armbian tools" are very promising. Kindly, Guillaume
zador.blood.stained Posted December 12, 2015 Author Posted December 12, 2015 I think it's more right to declare relationship between kernel packages so they cannot be installed at the same time. If I understand this right, it should be something like this in the kernel package control file: Provides: linux-image Conflicts: linux-image Replaces: linux-image Right now it doesn't have "Conflicts" and "Replaces" fields. ➜ ~ % apt-cache show linux-image-next-sunxi Package: linux-image-next-sunxi Status: install ok installed Priority: optional Section: kernel Installed-Size: 14180 Maintainer: Igor Pecovnik <****l.com> Architecture: armhf Source: linux-4.3.0-sunxi Version: 4.6 Provides: linux-image, linux-image-2.6, linux-modules-4.3.0-sunxi Suggests: linux-firmware-image-next-sunxi Description: Linux kernel, version 4.3.0-sunxi This package contains the Linux kernel, modules and corresponding other files, version: 4.3.0-sunxi. Description-md5: 117a3231b09bf7ccdf0ae5d4ec6b8c5f Homepage: http://www.kernel.org/ Edit: but the on going modifications of "Armbian tools" are very promising. This is only the beginning I mean, beginning of improvement, not of introducing tons of bugs, I hope 1
wildcat_paris Posted December 12, 2015 Posted December 12, 2015 Igor wrote: This lamobo fix was "lost in the crash" together with others small fixes yet to be rediscovered @Igor, no binary tools like swconfig, so yes, confirmed
zador.blood.stained Posted December 12, 2015 Author Posted December 12, 2015 @wildcat_parisI'm kind of lost, are you talking about sunxi tools (bin2fex, fex2bin, nand-part, meminfo) or swconfig only?swconfig is supposed to be extracted from archive, it's precompiled, as far as I see.I tested new changes in my branch today before pushing it, and sunxi tools (or some other tools, I didn't bother to check) failed to compile, but I managed to fix it by installing libc6-dev-armhf-crossPlease check if you have it installed on your build host and install it if it's missing.Edit: Since I made some changes to installing packages on host system and I was testing on minimal Trusty running in a container, I'm not sure if those build errors weren't caused by me. Edit 2: Nevermind, checked it on "normal" desktop Trusty, it's installed by default. Edit 3: Still it was installed by "Recommends" relationship, not by "Depends"
wildcat_paris Posted December 13, 2015 Posted December 13, 2015 @zador.blood.stained all of the binary tools in /usr/local/bin/ brought by armbian including bin2fex, fex2bin, nand-part, swconfig gr@server1404:~$ sudo apt-get install libc6-dev-armhf-cross [...] libc6-dev-armhf-cross is already the newest version. I will be testing the "next" tool instead of "dev", keep you in touch. I will extract the *.deb to check the files before applying the packages.
zador.blood.stained Posted December 13, 2015 Author Posted December 13, 2015 Then it must be packaging error, not compiling. I didn't touch it (yet) and so didn't test it. Maybe will check later. 1
wildcat_paris Posted December 13, 2015 Posted December 13, 2015 btw I would have suggested to add in lib/patching.sh in advanced_patch () mkdir -p "$SRC/userpatches/$dest/$family/$device" mkdir -p "$SRC/userpatches/$dest/$family" so next-time the user can fill the proper directory with the patches without having to add logs and read patching.sh
zador.blood.stained Posted December 13, 2015 Author Posted December 13, 2015 I already did something like that, prepare_host function duplicates directory structure from lib/patch to userpatches 1
wildcat_paris Posted December 13, 2015 Posted December 13, 2015 btw I would suggest to add in main.sh if [ "$USEALLCORES" = "yes" ]; then CTHREADS="-j$(($CPUS + $CPUS/2))"; else if [ "$USEALLCORES" = "single" ]; then CTHREADS="-j1"; else CTHREADS="-j${CPUS}"; fi fi because when there is an compil error, you don't need to look upper in the logs to find the problemand with ccache, it is as fast as possible edit: also in configuration.sh, else it cannot be used by [ -z $USEALLCORES ] && USEALLCORES="yes" # Use all CPU cores for compiling EDIT 2:I mean a quick switch between ALLCORES and a single core is useful to catch compile errorr faster. CCACHE is here to help with single core compile... if possible
wildcat_paris Posted December 13, 2015 Posted December 13, 2015 I already did something like that, prepare_host function duplicates directory structure from lib/patch to userpatches I my mind, userpatches is to avoid messing with lib/patch (minimizing changes in lib directory, so being more "portable" / configurable, I don't like much git conflit when "git pull" the armbian lib (git saying "save your changes" or you cannot update)
zador.blood.stained Posted December 13, 2015 Author Posted December 13, 2015 It doesn't duplicate files, it creates only empty directories. In my mind it is one of the reasons too. 1
wildcat_paris Posted December 14, 2015 Posted December 14, 2015 little suggestion (bash only): trap '{ echo "Hey, you pressed Ctrl-C. Time to quit." ; exit 1; }' INT would be useful as CTRL-C can break one script and the others can keep going on.
zador.blood.stained Posted December 14, 2015 Author Posted December 14, 2015 Yes, thanks. I already have this on my todo list for unmounting loop devices after debootstrap process. 1
wildcat_paris Posted December 14, 2015 Posted December 14, 2015 I already did something like that, prepare_host function duplicates directory structure from lib/patch to userpatches one more detail @zador.blood.stained you think like one of the "Armbian lib" tool writer/dev I think like an end user wishing to patch the kernel as quickly as possible, messing as little as possible with "lib" *.sh and folders, getting my kernel debian files to update my device. So having as little as possible to understand the internal of the "Armbian lib" Thanks for you help
