[Framework] Build script improvement suggestions #1
Rebuilding kernel several times in a row, made some changes, that would be nice to have in build script by default, and also some thoughts on custom kernel patches.
1.Option to not overwrite kernel config before compilation.
Example: setting KERNEL_KEEP_CONFIG="yes" in build.sh
Changes (common.sh):
# use proven config
if [ "$KERNEL_KEEP_CONFIG" != "yes" ]; then cp $SRC/lib/config/$LINUXCONFIG.config $SOURCES/$LINUXSOURCE/.config; fi
2. Option to use ccache for kernel compilation (at least). ccache can be set by creating symlinks for cross-compiling tools, but having an option in build script is more useful and easier IMHO.
Example: setting USE_CCACHE="yes" in build.sh
Changes (in common.sh):
if [ "$USE_CCACHE" = "yes" ]
then
make $CTHREADS ARCH=arm CROSS_COMPILE="ccache arm-linux-gnueabihf-" all zImage 2>&1 | dialog --backtitle "$backtitle" --progressbox "Compiling kernel ..." 20 70
else
make $CTHREADS ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- all zImage 2>&1 | dialog --backtitle "$backtitle" --progressbox "Compiling kernel ..." 20 70
fi
Also here stderr of compilation process is redirected to stdout so compiler warnings do not tear dialog window (2>&1).
Compiling kernel with ccache right now, will report if it breaks anything.
Looks like it doesn't like invoking make deb-pkg after compilation and tries to compile everything again, will test later other than this 4.3 related bug compilation works.
3. Automatically pick up and apply kernel patches from custom directory.
Something like this:
# in kernel souces root dir
for patch in $SRC/patches/$KERNEL_TYPE/*.patch
do
  patch -p1 < $patch
done
KERNEL_TYPE can be "next" or "legacy" to separate patches for different kernel branches. This can be extended to using device specific directories if necessary.
Link to comment
Share on other sites
Armbian Linux community supported weekly builds download
testing ccache...
very impressive speed!
with my VM (4 cores/4GB) kernel 4.2.5 compilation + debs:
*without ccache: 40-45 minutes
*with ccache: 10 minutes
btw in "compile.sh" I have added:
export BOARD="lamobo-r1"
export BRANCH="next"
export USE_CCACHE="yes"
also I have move to CROSS_COMPILE="ccache arm-....-" in "common.sh" as often as possible (of course, not including clean-up etc...)
Link to comment
Added 1. and 2. (need to fix few other things than commit). Tnx.
Looks like it doesn't like invoking make deb-pkg after compilation and tries to compile everything again, will test later.
It's possible that deb-pkg is broken. This used to work fine?
I will also research this topic further ...
ADD #1:
We need to compile deb-pkg the same way and it's fine
ADD #2
Kernel 4.2.5 compilation + debs. Xeon E3 1231v3 @3.8Ghz, enough RAM & Crucial BX100
Compilation speed: 1 min 40s with ccache and 6 min 20s without
Link to comment
Yes, I added ccache to make deb-pkg, but for me it compiles all sources again (second run with ccache should be much faster, but I didn't have time to finish it yesterday).
It should probably be noted in documentation or near USE_CCACHE option, that users need to set up at least ccache dir and size before enabling this option.
Link to comment
Perhaps this way:
if [ "$USE_CCACHE" = "yes" ]; then USE_CCACHE="ccache"; else USE_CCACHE=""; fi
make $CTHREADS ARCH=arm CROSS_COMPILE="$USE_CCACHE arm-linux-gnueabihf-" zImage modules 2>&1 | dialog --backtitle "$backtitle" --progressbox "Compiling kernel $USE_CCACHE ..." 20 80
if [ $? -ne 0 ] || [ ! -f arch/arm/boot/zImage ]; then
		display_alert "Kernel was not built" "@host" "err"
	    exit 1
fi
make $CTHREADS ARCH=arm CROSS_COMPILE="$USE_CCACHE arm-linux-gnueabihf-" dtbs 2>&1 | dialog --backtitle "$backtitle" --progressbox "Compiling DTB $USE_CCACHE ..." 20 80
if [ $? -ne 0 ]; then
		display_alert "DTBs was not build" "@host" "err"
	    exit 1
fi
Link to comment
Using bindeb-pkg target instead of deb-pkg seems to build kernel 4.3 without recompiling (which is logical since deb-pkg target is designed for making kernel source package amongst others and it executes "make clean" at the start).
Also tested ccache on u-boot compilation - works, but
needs to be called only once somewhere before u-boot and kernel compilation.
Link to comment
OK, I'll place it to the proper place ... and fixed pipe exit code.
if [ ${PIPESTATUS[0]} -ne 0 ] || [ ! -f arch/arm/boot/zImage ]; then
	    exit 1
fi
Link to comment
Igor, saw your commits on github.
1. KERNEL_KEEP_CONFIG definitely should be disabled by default, otherwise there will be no allwinner specific base config on fresh installations or major version upgrades. This option is for (re)building with different set of options/modules.
2. "dtbs" target is specific to Device Tree based kernels, building legacy kernels most likely will fail at this stage.
3. "bindeb-pkg" is not temporary but is a new default option for kernels that support this target: https://git.kernel.org/cgit/linux/kernel/git/next/linux-next.git/commit/scripts/package/builddeb?id=3716001bcb7f5822382ac1f2f54226b87312cc6b
I guess that having USE_CCACHE enabled by default is okay even with default config ($HOME/.ccache, limit 1G), but it has some scenarios where it won't work as expected (recompiling kernel with changed config or manually pached include files): https://lists.samba.org/archive/ccache/2014q1/001172.html
Link to comment
1. Yes, you are right. Fixed
2. I made few tests with old kernel and it does not break ...
3. Aha, so just my comment is deprecated? ;)
Let's see how things will go fuhter. I only made few runs.
Link to comment
https://github.com/igorpecovnik/lib -b master (not default yet)
1. Redesigned patching process: "per kernel family", picking patches from dirs, fixed and cleaned patches
AFTER
https://github.com/igorpecovnik/lib/blob/master/patching.sh
BEFORE
https://github.com/igorpecovnik/lib/blob/second/patching.sh
2. Added user patches dirs, one for kernel, one for u-boot, outside of /lib
https://github.com/igorpecovnik/lib/blob/master/documentation/geek-faq.md#user-patching
3. Added new devices with "WIP" status: Lemaker Guitar and H3 Orange
4. Cleaning sources (WIP)
5. Many bug fixes + probably produced new bugs ...  need help with testing & fixing  :P
Now it's time for (new) suggestions   :D
Link to comment
Just saw your commits while browsing github :)
I thought about new suggestions:
1. Renaming some scripts. Using "compile.sh" to launch process, "common.sh" to compile u-boot & kernel, "main.sh" - i have no idea where and when it is used without searching through other scripts... it is counter-intuitive  :)
2. Using apt-cacher-ng to speed up building all images (or rebuilding one image) by caching downloaded packages locally.
  • should work without extra configuration on host system
  • requires adding extra parameter to debootstrap (first stage) - mirror address, i.e.
debootstrap --include=openssh-server,debconf-utils$sysvinit --arch=armhf --foreign $RELEASE $DEST/cache/sdcard/ http://localhost:3142/httpredir.debian.org/debian
or something like this. Obviously needs separate mirror address for ubuntu.
  • requires adding extra argument to apt-get (update and install commands):
 -o Acquire::http::Proxy "http://localhost:3142"
obviously it's easier to do if number of apt-get invocations is minimal, right now there are at least 3 separate install command - locales, console packages, rest of Armbian, + there are extra for building desktop images in another script.
3. With "enough RAM" it may be beneficial to even use ramdisk instead of loop device, but I think this is not for near future...
I'll try to test kernel compilation as soon as I sort out some PC hardware issues or free enough disk space to move to another PC.
Link to comment
Was looking through changelog between branches, noticed this:
# configure MIN / MAX speed for cpufrequtils
sed -e "s/MIN_SPEED=\"0\"/MIN_SPEED=\"$CPUMIN\"/g" -i $DEST/cache/sdcard/etc/init.d/cpufrequtils
sed -e "s/MAX_SPEED=\"0\"/MAX_SPEED=\"$CPUMAX\"/g" -i $DEST/cache/sdcard/etc/init.d/cpufrequtils
I think it's not a good idea to alter init.d script because on package upgrade any changes may be lost. cpufreq settings should be defined in /etc/default/cpufrequtils
➜  ~  % cat /etc/default/cpufrequtils
ENABLE="true"
GOVERNOR="ondemand"
MAX_SPEED=960000
MIN_SPEED=720000
Also small note here:
Available frequencies on mainline for A20 based boards (sun7i-a20.dtsi):
960000, 912000, 864000, 720000, 528000, 312000, 144000
for A10 boards except A10 Lime (sun4i-a10.dtsi):
1008000, 912000, 864000, 624000
A10 Lime doesn't have 1008000 from this list.
Link to comment
Igor,
FYI
testing a fresh install of "-b master"
got a kernel 4.4.0-rc3 to compile (I guess your target is 4.3 4.2.6)
and then
 arch/arm/boot/dts/Makefile:639: *** commands commence before first target.   x
                             x make: *** [dtbs] Error 2
EDIT:
added
BOARD="lamobo-r1"
BRANCH="next"
KERNELTAG="v4.3"
RELEASE="trusty"
BUILD_DESKTOP="No"
I don't know what it is about fresh installs but
root@server1404:~/armtest# KERNELTAG="v"`wget -qO-  https://www.kernel.org/finger_banner | grep "The latest st" | awk '{print $NF}'`
root@server1404:~/armtest# echo $KERNELTAG
v4.2.6
EDIT #2:
whatever KERNELTAG I apply (empty, v4.3, v4.2.6) I end with
error: pathspec 'v4.2.6' did not match any file(s) known to git.
[ o.k. ] Patching kernel [ sunxi-next 4.4.0rc3 ]
I can see tags from http://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git/refs/tags/
EDIT #3:
fetch_from_github (){
# Download or updates sources from Github
if [ -d "$SOURCES/$2" ]; then
        cd $SOURCES/$2
        if [[ "$3" != "" ]]; then
                PULL=$(git checkout $FORCE -q $3)
is $FORCE related to $FORCE_CHECKOUT ?
so $FORCE = "-f" ?
ok, fgrep is my friend in this puzzle
if [ "$FORCE_CHECKOUT" = "yes" ]; then FORCE="-f"; else FORCE=""; fi
ok so fetch_from_github works with
LINUXKERNEL=git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git --depth 1
LINUXSOURCE=linux-mainline
LINUXCONFIG=linux-sunxi-next
LINUXDEFAULT=master
LINUXFAMILY=sunxi
FIRMWARE=
fetch_from_github "$LINUXKERNEL" "$LINUXSOURCE" "$LINUXDEFAULT"
in my case
fetch_from_github "git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git --depth 1" "linux-mainline" "master"
what is "--depth 1" doing here ? (ok applies only to "git clone" not "git checkout")
EDIT #4:
ok there is an issue with --depth 1
http://stackoverflow.com/questions/6941889/is-it-safe-to-shallow-clone-with-depth-1-create-commits-and-pull-updates-aga
if you start a fresh install it only clone the HEAD (aka 4.4-rc3 tag)
so no other tags... including 4.2.6 and 4.3
ok an old Armbian tool mystery is solved
root@server1404:~/armtest/sources# git clone git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git linux-mainline
Cloning into 'linux-mainline'...
remote: Counting objects: 4855800, done.
remote: Compressing objects: 100% (417582/417582), done.
remote: Total 4855800 (delta 335700), reused 0 (delta 0)
Receiving objects: 100% (4855800/4855800), 1.10 GiB | 3.24 MiB/s, done.
Resolving deltas: 100% (4002996/4002996), done.
Checking connectivity... done.
Checking out files: 100% (52217/52217), done.
root@server1404:~/armtest/sources/linux-mainline# git tag
v2.6.11
v4.2
v4.2.1
v4.2.2
v4.2.3
v4.2.4
v4.2.5
v4.2.6
v4.3
v4.4-rc1
v4.4-rc2
v4.4-rc3
root@server1404:~/armtest/sources/linux-mainline# git checkout -f v4.3
Note: checking out 'v4.3'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
  git checkout -b new_branch_name
HEAD is now at 6a13feb... Linux 4.3
root@server1404:~/armtest/sources/linux-mainline# git checkout -f v4.2.6
Checking out files: 100% (10091/10091), done.
Previous HEAD position was 6a13feb... Linux 4.3
HEAD is now at 1c02865... Linux 4.2.6
So for a fresh install of linux-mainline
I guess --depth 20 is probably needed to have kernel 4.2 4.3 and 4.4-rcX
EDIT #5:
probably a smarter proposal "--depth 1 --no-single-branch" so the tags are retrieved and the checkout can move from tag to tag
root@server1404:~/armtest/sources# git clone git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git linux-mainline-test --depth 1 --no-single-branch
Cloning into 'linux-mainline-test'...
remote: Counting objects: 808871, done.
remote: Compressing objects: 100% (350845/350845), done.
remote: Total 808871 (delta 690067), reused 551343 (delta 451473)
Receiving objects: 100% (808871/808871), 431.61 MiB | 3.60 MiB/s, done.
Resolving deltas: 100% (690067/690067), done.
root@server1404:~/armtest/sources# cd linux-mainline-test
root@server1404:~/armtest/sources/linux-mainline-test# git checkout -f v4.2.6
Checking out files: 100% (16472/16472), done.
Note: checking out 'v4.2.6'.
root@server1404:~/armtest/sources/linux-mainline-test# git checkout -f v4.3
Previous HEAD position was 1c02865... Linux 4.2.6
cool, I have learnt something with git :-)
EDIT #6:
so I am compiling kernel 4.2.6 as planned
I am ending with
arch/arm/boot/dts/Makefile:586: *** commands commence before first target.   x
EDIT #7:
deleted "lib" directory and re-launched compiler.sh
=> DTS compiles ok but it is the "stable" lib tree
so again
git clone https://github.com/igorpecovnik/lib-b master
same issue
 Compiling DTB ccache ...                                                     x
                                           xqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqx
                                           x   CHK     include/config/kernel.release                                      x
                                           x   CHK     include/generated/uapi/linux/version.h                             x
                                           x   CHK     include/generated/utsrelease.h                                     x
                                           x make[1]: `include/generated/mach-types.h' is up to date.                     x
                                           x   CHK     include/generated/timeconst.h                                      x
                                           x   CHK     include/generated/bounds.h                                         x
                                           x   CHK     include/generated/asm-offsets.h                                    x
                                           x   CALL    scripts/checksyscalls.sh                                           x
                                           x arch/arm/boot/dts/Makefile:586: *** commands commence before first target.   x
Link to comment
I solve this git handling part other way. Will submit changes today.
That's due to one broken patch. Already fixed.
Tnx!
Link to comment
Igor,
"--depth 1 --no-single-branch" seems far better than "--depth 20" because the download is faster (>1 MB/s but more files to download vs. 100kB/s) and there is less computation to do (as seen while testing the 2 options)
ok, I will retry "-b master" thanks!
Link to comment
the "userpatches" feature is pretty promising...
branch "second" is working fine with fresh install + "--depth 1 --no-single-branch" +
BOARD="lamobo-r1"
BRANCH="next"
KERNELTAG="v4.2.6"
BUILD_DESKTOP="No"
and RELEASE="trusty" or "wheezy" or "jessie"
branch "master" still choke on "arch/arm/boot/dts/Makefile:586: *** commands commence before first target. "
Link to comment
I finally managed to make separate "build server" for myself  :)
Ready to test master branch as soon as Igor updates it (I installed Ubuntu 15.04, so only mainline kernel for now). Also want to propose some enhancements (I'll make a pull request):
Adding user patches is cool, but I think I can make some changes so you can override (apply user patch instead of existing in lib/patch) or "mask" (prevent patch in lib/patch from applying) them.
Also I want to add make-style parameters handling, so you can run for example "sudo ./compile.sh KERNEL_ONLY=yes BOARD=cubietruck BRANCH=next" and avoid selecting board and branch manually or editing compile.sh each time.
Link to comment
There will be no updates, at least not for a while.
I just accidentally delete the work of the whole week :( a hundred hours went to trash.  :( :( :(
I was playing too much with git handling that I completely crashed my working git. Of course I had no backup for this and I only could salvage few files which I just pushed up.
Link to comment
                                            ┌───────────────────────┤ Choose a board ├────────────────────────┐
                                            │  Supported:                                                     │
                                            │    cubieboard4           A80 octa core 2Gb SoC Wifi             │
                                            │    aw-som-a20            A20 dual core SoM                      │
                                            │    cubieboard            A10 single core 1Gb SoC                │
                                            │    cubieboard2           A20 dual core 1Gb SoC                  │
                                            │    cubietruck            A20 dual core 2Gb SoC Wifi             │
                                            │    lime-a10              A10 single core 512Mb SoC              │
                                            │    lime                  A20 dual core 512Mb SoC                │
                                            │    lime2                 A20 dual core 1Gb SoC                  │
                                            │    micro                 A20 dual core 1Gb SoC                  │
                                            │    pcduino3nano          A20 dual core 1Gb SoC                  │
                                            │    bananapim2            A31 quad core 1Gb SoC Wifi             │
                                            │    bananapi              A20 dual core 1Gb SoC                  │
                                            │    bananapipro           A20 dual core 1Gb SoC Wifi             │
                                            │    lamobo-r1             A20 dual core 1Gb SoC Switch           │
                                            │    orangepi              A20 dual core 1Gb SoC Wifi USB hub     │
                                            │    orangepimini          A20 dual core 1Gb SoC Wifi             │
                                            │    orangepiplus          H3 quad core 1Gb SoC Wifi USB hub      │
                                            │    cubox-i               Freescale iMx dual/quad core Wifi      │
                                            │    udoo                  Freescale iMx dual/quad core Wifi      │
                                            │    udoo-neo              Freescale iMx singe core Wifi          │
                                            │    guitar                S500 Lemaker Guitar Action quad core   │
                                            │    odroid                Exynos5422 XU3/XU4 octa core           │
                                            │                <Ok>                    <Cancel>                 │
This far I got:
- added few new boards
- proper git sources switching
- completely reorganized configuration
- legacy / next / dev versions
- 80% of code cleaned.
Starting tomorrow from here:
Link to comment
A break would be the best / most productive. I'll see how I'll feel in the morning ;)
If you wants to jump in - I'll work on the configuration.sh + few things in main.sh for a while.
... better sources handling is a open part or even only the code cleaning, where is needed, cpu speed fixes ... $GOVERNOR will be now in config.
Link to comment
Just a thought about install_packet function...
I think installing packages all at once should be faster than installing them one by one (extra dependencies calculation, reading/writing dpkg database, processing pre/postinstall triggers). Maybe rework it to display progress from apt-get in simple dialog text box?
Only downside is - if one package cannot be installed (wrong package name for example), whole process fails.
Link to comment
Changelog:
Restarting script with sudo if needed (compile.sh)
Check for superuser rights is no longer needed (main.sh)
Script parameters handling (main.sh)
Handling BUILD_ALL option needs extra refactoring, so for now this parameter is not supported
Better handling of KERNEL_KEEP_CONFIG option (common.sh)
Run make oldconfig before make menuconfig (common.sh)
Handling of KERNEL_CONFIGURE option for oldconfig (common.sh)
Advanced patching is now more advanced than it probably needs to be (patching.sh)
TODO:
install_packet iteration to batch, better displaying of progress ?
renaming common.sh -> compilation.sh, compile.sh -> make.sh, updating source and documentation for this change
Edit: made some fixes
Testing patching process: for mainline stable kernel "$LINUXFAMILY-$BRANCH" parses to "sun7i-next" or "sun4i-next" instead of "sunxi-next". Is this a bug or a feature?  :)
Edit 2: pushed advanced_patching changes. Mainline patches are still broken due to wrong $LINUXFAMILY
Link to comment
A bug ;)
This is also an exception. When added to configuration it should work properly, like for .configs
https://github.com/igorpecovnik/lib/blob/master/configuration.sh#L269-L270
https://github.com/zador-blood-stained/lib/blob/master/patching.sh#L147
This part can be dumped. I made patches, fbtft sources are not changing anymore. It has been merged into mainline for some time.
Tnx.
I'll try later to merge this together
EDIT:
adv.patches doesn't collect my custom patches even they are in proper dir.
Link to comment
Hm. I tested it briefly on cubietruck sun7i kernel, it got all patches from /lib and it skipped fbtft patch when I created empty file userpatches/kernel/sun7i-default/fbtft_for_older.patch
I'm waiting for your solution to passing correct LINUXFAMILY to patching function to do proper tests.
What exactly did you test?
Edit: Just checked. Works like intended for me
➜  ~  % cd armbian/userpatches/kernel/sun7i-default
➜  sun7i-default  % _ cp ~/armbian/lib/patch/kernel/small_lcd_drivers.patch test-patch.patch
➜  sun7i-default  % ~
➜  ~  % armbian
➜  armbian  % ./compile.sh BOARD=cubietruck KERNEL_ONLY=yes BRANCH=default
[ o.k. ] ... test-patch.patch sun7i-default 3.4.104 [ succeeded ]
Link to comment
