Posted (edited)
@Igor
Thanks for b53... I nearly achieved the quick fix last night...
my mistake: b53 needs to be included in the kernel, not as a module
EDIT:
Also, as you have added the patch in "lib" & I didn't remove the same patch from "userpatches", the patch was not applied twice (same file name), cool :)
@zador : "Zador j'adore" (like Dior perfume commercial) I like Zador
Edited by wildcat_paris
silly joke
for some days already, on sunxi-dev,
after
[ o.k. ] Extracting trusty from cache [ 7 days old ]
in the "Force package update ..." box
I get plenty of
W: Failed to fetch http://ports.ubuntu.com/dists/trusty-security/Release.gpg Could not resolve 'ports.ubuntu.com'
W: Failed to fetch http://apt.armbian.com/dists/trusty/Release.gpg Could not resolve 'apt.armbian.com'
The image build does not failed but I haven't tested the image, only the debs.
NOTE: not related to local DNS because I can ping both machines
7 days old cache? Maybe something's up with /etc/resolv.conf (or /etc/nsswitch.conf) inside cached rootfs? Try building without rootfs cache.
Edit: /etc/resolv.conf is created or changed in install_kernel, so if for some reason it is not present in cached rootfs, DNS resolving in chroot won't work.
Putting this to both debootstraps should solve the issue.
Second debootstrap doesn't update file lists after extracting cached rootfs (for now at least). And now since installation of all distribution-specific and desktop-specific packages was moved into main debootstrap function, updating packages lists may not be needed at all. Anyway I'll check later if this hack is needed only for trusty or other distribution may be affected and I'll update my debootstrap code too.
@Zador
I've removed trusty.tgz (which then adds 110 minutes @home to the Armbian image making process) and *no* error messages :)
@Igor @Zador
I have my first fully running Armbian dev "4.81" (ok "next" is version "5.00"!) with kernel 4.4.0-rc6
and surprise, the patches from Corentin LABBE for AXP are working *now* http://sunxi.montjoie.ovh/patchs_current/
$ sensors
axp209-isa-0000
Adapter: ISA adapter
ACIN:          +5.05 V
VBUS:          +0.00 V
BATT:          +1.52 V
APS:           +4.91 V
CHIP:          +50.4°C
BATT:           0.00 W
ACIN:          +0.81 A
VBUS:          +0.00 A
BATT_CHRG:     +0.00 A
BATT_DISCHRG:  +0.01 A
sun4i_ts-isa-0000
SoC temperature:  +39.1°C
For me without rootfs cache this (old debootstrap)
[ o.k. ] Create and sign [ Armbian_4.81_Cubietruck_Debian_wheezy_3.4.110.zip ]
[ o.k. ] Runtime [ 73 min ]
turns into this (new debootstrap, again, no rootfs cache)
[ o.k. ] Signing and compressing [ Armbian_4.81_Cubietruck_Debian_wheezy_3.4.110.zip ]
[ o.k. ] Done building [ /home/zador/armbian/output/images/Armbian_4.81_Cubietruck_Debian_wheezy_3.4.110.zip ]
[ o.k. ] Runtime [ 16 min ]
so there may be some small improvements, depending on storage type (SSD or mechanical HDD), available RAM and internel connection speed.
Yes, resolv.conf was symlinked to /run/resolvconf/... and this dir is excluded in rootfs cache. Anyway, fixed by Igor now.
yes I am using a dedicated HDD (for the Armbian tool VM) with Virtualbox on top of Trusty/amd64, the Virtualbox VM crashes from time to time (compared to Virtualbox on Win7_64 which is quite stable)... ok I have a couple of free for use SSD @hands :ph34r: but rootfs cache is good enough!
tmpfs is faster in any case  :P But for me at this point lack of CPU power is the only thing that still makes using cached rootfs faster than making it from scratch
guys,
is it intended (bold), please ? or KERNEL_DEV ?
                        # Kernel
                        KERNEL_DEFAULT='https://github.com/linux-sunxi/linux-sunxi'
                        KERNEL_DEFAULT_BRANCH="sunxi-3.4"
                        KERNEL_DEFAULT_SOURCE="linux-sunxi"
                        KERNEL_NEXT='git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git'
                        [ "$USE_MAINLINE_GOOGLE_MIRROR" = "yes" ] && KERNEL_NEXT='https://kernel.googlesource.com/pub/scm/linux/kernel/git/
                        KERNEL_NEXT_BRANCH="v"`wget -qO-  https://www.kernel.org/finger_banner| grep "The latest st" | awk '{print $NF}' |
                        KERNEL_NEXT_SOURCE="linux-vanilla"
                        KERNEL_DEV='git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git'
                        KERNEL_DEV_BRANCH=""
                        KERNEL_DEV_SOURCE="linux-vanilla"
btw, stable seems stalled @v4.4-rc6
I move to http://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/refs/tags/
@Igor, what do you think about moving MAINTAINER, MAINTAINERMAIL, GPG_PASS and maybe ROOTPWD to configuration.sh or to main.sh - to keep compile.sh small and simple, I don't think these options are useful to people who just want to compile new kernel.
Posted (edited)
(moved from another thread about LUKS dmcrypt)
@Igor
I enabled a bunch of missing crypto features for sunxi-dev branch, please enable those options on other branches.
As with my test on lamobo-r1, you can enable NEON and anything for Cortex A7 crypto
# At least one emulation must be selected
CONFIG_VFP=y
CONFIG_VFPv3=y
CONFIG_NEON=y
CONFIG_KERNEL_MODE_NEON=y
as well as the crypto
# Security options
CONFIG_KEYS=y
# CONFIG_PERSISTENT_KEYRINGS is not set
# CONFIG_BIG_KEYS is not set
CONFIG_ENCRYPTED_KEYS=y
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_DEFAULT_SECURITY=""
CONFIG_XOR_BLOCKS=y
CONFIG_ASYNC_CORE=m
CONFIG_ASYNC_MEMCPY=m
CONFIG_ASYNC_XOR=m
CONFIG_ASYNC_PQ=m
CONFIG_ASYNC_RAID6_RECOV=m
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_RNG_DEFAULT=y
CONFIG_CRYPTO_PCOMP=y
CONFIG_CRYPTO_PCOMP2=y
CONFIG_CRYPTO_AKCIPHER2=y
CONFIG_CRYPTO_AKCIPHER=y
CONFIG_CRYPTO_RSA=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
CONFIG_CRYPTO_USER=m
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
CONFIG_CRYPTO_GF128MUL=y
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_NULL2=y
CONFIG_CRYPTO_PCRYPT=m
CONFIG_CRYPTO_WORKQUEUE=y
CONFIG_CRYPTO_CRYPTD=y
CONFIG_CRYPTO_MCRYPTD=m
CONFIG_CRYPTO_AUTHENC=y
CONFIG_CRYPTO_TEST=m
CONFIG_CRYPTO_ABLK_HELPER=y
# Authenticated Encryption with Associated Data
CONFIG_CRYPTO_CCM=m
CONFIG_CRYPTO_GCM=m
CONFIG_CRYPTO_CHACHA20POLY1305=y
CONFIG_CRYPTO_SEQIV=y
CONFIG_CRYPTO_ECHAINIV=m
# Block modes
CONFIG_CRYPTO_CBC=y
CONFIG_CRYPTO_CTR=y
CONFIG_CRYPTO_CTS=y
CONFIG_CRYPTO_ECB=y
# CONFIG_CRYPTO_LRW is not set
CONFIG_CRYPTO_PCBC=m
CONFIG_CRYPTO_XTS=y
CONFIG_CRYPTO_KEYWRAP=m
# Hash modes
CONFIG_CRYPTO_CMAC=y
CONFIG_CRYPTO_HMAC=y
CONFIG_CRYPTO_XCBC=m
CONFIG_CRYPTO_VMAC=m
# Digest
CONFIG_CRYPTO_CRC32C=y
CONFIG_CRYPTO_CRC32=m
CONFIG_CRYPTO_CRCT10DIF=m
CONFIG_CRYPTO_GHASH=m
CONFIG_CRYPTO_POLY1305=y
CONFIG_CRYPTO_MD4=y
CONFIG_CRYPTO_MD5=y
CONFIG_CRYPTO_MICHAEL_MIC=m
CONFIG_CRYPTO_RMD128=y
CONFIG_CRYPTO_RMD160=y
CONFIG_CRYPTO_RMD256=y
CONFIG_CRYPTO_RMD320=y
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=y
CONFIG_CRYPTO_SHA512=y
CONFIG_CRYPTO_TGR192=y
CONFIG_CRYPTO_WP512=y
# Ciphers
CONFIG_CRYPTO_AES=y
CONFIG_CRYPTO_ANUBIS=y
CONFIG_CRYPTO_ARC4=y
CONFIG_CRYPTO_BLOWFISH=y
CONFIG_CRYPTO_BLOWFISH_COMMON=y
CONFIG_CRYPTO_CAMELLIA=y
CONFIG_CRYPTO_CAST_COMMON=y
CONFIG_CRYPTO_CAST5=y
CONFIG_CRYPTO_CAST6=y
CONFIG_CRYPTO_DES=y
CONFIG_CRYPTO_FCRYPT=y
CONFIG_CRYPTO_KHAZAD=y
CONFIG_CRYPTO_SALSA20=y
CONFIG_CRYPTO_CHACHA20=y
CONFIG_CRYPTO_SEED=y
CONFIG_CRYPTO_SERPENT=y
CONFIG_CRYPTO_TEA=y
CONFIG_CRYPTO_TWOFISH=y
CONFIG_CRYPTO_TWOFISH_COMMON=y
# Compression
CONFIG_CRYPTO_DEFLATE=y
CONFIG_CRYPTO_ZLIB=y
CONFIG_CRYPTO_LZO=y
CONFIG_CRYPTO_842=y
CONFIG_CRYPTO_LZ4=y
CONFIG_CRYPTO_LZ4HC=y
# Random Number Generation
CONFIG_CRYPTO_ANSI_CPRNG=y
CONFIG_CRYPTO_DRBG_MENU=y
CONFIG_CRYPTO_DRBG_HMAC=y
CONFIG_CRYPTO_DRBG_HASH=y
CONFIG_CRYPTO_DRBG_CTR=y
CONFIG_CRYPTO_DRBG=y
CONFIG_CRYPTO_JITTERENTROPY=y
CONFIG_CRYPTO_USER_API=m
CONFIG_CRYPTO_USER_API_HASH=m
CONFIG_CRYPTO_USER_API_SKCIPHER=m
CONFIG_CRYPTO_USER_API_RNG=m
CONFIG_CRYPTO_USER_API_AEAD=m
CONFIG_CRYPTO_HASH_INFO=y
CONFIG_CRYPTO_HW=y
CONFIG_CRYPTO_DEV_SUN4I_SS=y
CONFIG_CRYPTO_DEV_SUN4I_SS_PRNG=y
CONFIG_ASYMMETRIC_KEY_TYPE=m
CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=m
CONFIG_PUBLIC_KEY_ALGO_RSA=m
CONFIG_X509_CERTIFICATE_PARSER=m
# CONFIG_PKCS7_MESSAGE_PARSER is not set
# Certificates for signature checking
CONFIG_SYSTEM_TRUSTED_KEYRING=y
CONFIG_SYSTEM_TRUSTED_KEYS=""
CONFIG_ARM_CRYPTO=y
CONFIG_CRYPTO_SHA1_ARM=y
CONFIG_CRYPTO_SHA1_ARM_NEON=y
CONFIG_CRYPTO_SHA1_ARM_CE=m
CONFIG_CRYPTO_SHA2_ARM_CE=m
CONFIG_CRYPTO_SHA256_ARM=y
CONFIG_CRYPTO_SHA512_ARM=y
CONFIG_CRYPTO_AES_ARM=y
CONFIG_CRYPTO_AES_ARM_BS=y
CONFIG_CRYPTO_AES_ARM_CE=m
CONFIG_CRYPTO_GHASH_ARM_CE=m
# CONFIG_BINARY_PRINTF is not set
# Library routines
CONFIG_RAID6_PQ=y
CONFIG_BITREVERSE=y
CONFIG_HAVE_ARCH_BITREVERSE=y
CONFIG_RATIONAL=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_GENERIC_IO=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
CONFIG_CRC_CCITT=y
CONFIG_CRC16=y
CONFIG_CRC_T10DIF=m
CONFIG_CRC_ITU_T=y
CONFIG_CRC32=y
CONFIG_CRC32_SELFTEST=y
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
CONFIG_CRC7=m
CONFIG_LIBCRC32C=y
CONFIG_CRC8=m
# CONFIG_AUDIT_ARCH_COMPAT_GENERIC is not set
CONFIG_RANDOM32_SELFTEST=y
CONFIG_842_COMPRESS=y
CONFIG_842_DECOMPRESS=y
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_COMPRESS=y
CONFIG_LZ4HC_COMPRESS=y
CONFIG_LZ4_DECOMPRESS=y
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
CONFIG_XZ_DEC_TEST=m
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_TEXTSEARCH=y
CONFIG_TEXTSEARCH_KMP=m
CONFIG_TEXTSEARCH_BM=m
CONFIG_TEXTSEARCH_FSM=m
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
CONFIG_CPUMASK_OFFSTACK=y
CONFIG_CPU_RMAP=y
CONFIG_DQL=y
CONFIG_GLOB=y
# CONFIG_GLOB_SELFTEST is not set
just in case my whole config for 4.4-rc8 (needs the PRNG patch for A20)
EDIT: NEON related
[   0.013562] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
[    0.014834] xor: measuring software checksum speed
[    0.110001]    arm4regs  :  1243.600 MB/sec
[    0.210054]    8regs     :   772.000 MB/sec
[    0.310110]    32regs    :   792.400 MB/sec
[    0.410166]    neon      :  1162.400 MB/sec
[    0.410175] xor: using function: arm4regs (1243.600 MB/sec)
[    0.650868] raid6: int32x1  gen()   138 MB/s
[    0.820707] raid6: int32x1  xor()   111 MB/s
[    0.990812] raid6: int32x2  gen()   185 MB/s
[    1.160982] raid6: int32x2  xor()   120 MB/s
[    1.331052] raid6: int32x4  gen()   197 MB/s
[    1.501242] raid6: int32x4  xor()   122 MB/s
[    1.671257] raid6: int32x8  gen()   179 MB/s
[    1.841357] raid6: int32x8  xor()   116 MB/s
[    2.011385] raid6: neonx1   gen()   436 MB/s
[    2.181466] raid6: neonx1   xor()   324 MB/s
[    2.351636] raid6: neonx2   gen()   577 MB/s
[    2.521708] raid6: neonx2   xor()   423 MB/s
[    2.691842] raid6: neonx4   gen()   707 MB/s
[    2.861897] raid6: neonx4   xor()   480 MB/s
[    3.032095] raid6: neonx8   gen()   640 MB/s
[    3.202164] raid6: neonx8   xor()   451 MB/s
[    3.202172] raid6: using algorithm neonx4 gen() 707 MB/s
[    3.202179] raid6: .... xor() 480 MB/s, rmw enabled
[    3.202185] raid6: using intx1 recovery algorithm
neon stuff added
@Igor @Zador
Igor : I decided to drop idea to put an AC card into the board since it's simply too problematic and expensive (66USD). This card doesn't have support in legacy kernel, in 4.4 have no idea if everything else already works + I have only one AC device in the lab.
todo? it would not cost much to activate the kernel next/dev the "Minstrel 802.11ac support" (I tested it once with my dummy Alfa "AC")
Posted (edited)
Kernel 4.x for ClearFog is not quite ready yet. I built 4.3.3 yesterday and yes PCI is working but haven't saw Ethernet phy which is somehow essential for a router board :D 60 euros for this AC card is also too much in beer fresh expensive Zadorland bottled sparkling water, otherwise named "free-alcohol beer" or Perrier.  :lol:
Edit: This AC card, even I would get it working in Linux, is a dead meat for me since my other wireless equipment is basic.
Armbian is alcohol free by design, btw it doesn't reply my "Minstrel 802.11ac support" remark... Igor has his new baby board -- signed: zealous moderator
@AnyFox
is debootstrap-ng ready for 2 partitions yet? several tests, removed all the files
dpkg-deb: building package `linux-firmware-image-odroidxu4' in `../linux-firmware-image-odroidxu4_4.83_armhf.deb'.
dpkg-deb: building package `linux-dtb-odroidxu4' in `../linux-dtb-odroidxu4_4.83_armhf.deb'.
dpkg-deb: building package `linux-headers-odroidxu4' in `../linux-headers-odroidxu4_4.83_armhf.deb'.
dpkg-deb: building package `linux-image-odroidxu4' in `../linux-image-odroidxu4_4.83_armhf.deb'.
[ o.k. ] Creating board support package. [ odroidxu4 ]
[ o.k. ] Fingerprinting. [ Armbian 4.83 Odroidxu4 Ubuntu trusty default Linux 3.10.94 ]
[ o.k. ] Building deb package. [ linux-trusty-root-odroidxu4_4.83_armhf.deb ]
[ o.k. ] Starting build process for [ odroidxu4 trusty ]
[ o.k. ] Extracting trusty-ng.tgz [ 0 days old ]
trusty-ng.tgz:  176MB [51.2MB/s] [===================================================================================================>] 100%
[ o.k. ] Fixing release custom applications. [ trusty ]
[ o.k. ] Installing kernel, u-boot and board specific [ trusty odroidxu4 ]
[ o.k. ] Install kernel [ linux-image-odroidxu4_4.83_armhf.deb ]
[ o.k. ] Install u-boot [ linux-u-boot-odroidxu4_4.83_armhf.deb ]
[ o.k. ] Install headers [ linux-headers-odroidxu4_4.83_armhf.deb ]
[ o.k. ] Install firmware [ linux-firmware-image-odroidxu4_4.83_armhf.deb ]
[ o.k. ] Install DTB [ linux-dtb-odroidxu4_4.83_armhf.deb ]
(Reading database ... 39326 files and directories currently installed.)
Removing lirc (0.9.0-0ubuntu5) ...
runlevel:/var/run/utmp: No such file or directory
invoke-rc.d: policy-rc.d denied execution of stop.
[ o.k. ] Creating boot scripts [ odroidxu4 ]
[ o.k. ] Adjusting boot scripts [ odroidxu4 ]
[ o.k. ] Installing external applications [ USB redirector ]
[ o.k. ] Installing external applications [ RT8192 driver ]
[ o.k. ] Calling image customization script [ customize-image.sh ]
[ o.k. ] Preparing image file for rootfs [ odroidxu4 trusty ]
[ o.k. ] Current rootfs size [ 673 MiB ]
[ o.k. ] Creating blank image for rootfs [ 1025 MiB ]
   1GB [93.7MB/s] [==================================================================================================================>] 100%
[ o.k. ] Creating partitions [ /boot: fat root: ext4 ]
losetup: invalid option -- 'P'
Usage:
 losetup loop_device                             give info
 losetup -a | --all                              list all used
 losetup -d | --detach <loopdev> [<loopdev> ...] delete
 losetup -f | --find                             find unused
 losetup -c | --set-capacity <loopdev>           resize
 losetup -j | --associated <file> [-o <num>]     list all associated with <file>
 losetup [options] {-f|--find|loopdev} <file>    setup
Options:
 -e, --encryption <type> enable data encryption with specified <name/num>
 -h, --help              this help
 -o, --offset <num>      start at offset <num> into file
     --sizelimit <num>   loop limited to only <num> bytes of the file
 -p, --pass-fd <num>     read passphrase from file descriptor <num>
 -r, --read-only         setup read-only loop device
     --show              print device name (with -f <file>)
 -N | --nohashpass       Do not hash the given password (Debian hashes)
 -k | --keybits <num>    specify number of bits in the hashed key given
                         to the cipher.  Some ciphers support several key
                         sizes and might be more efficient with a smaller
                         key size.  Key sizes < 128 are generally not
                         recommended
 -v, --verbose           verbose mode
mkfs.fat 3.0.26 (2014-03-07)
mkfs.fat: warning - lowercase labels might not work properly with DOS or Windows
/dev/loop0p1: No such file or directory
Could not stat /dev/loop0p2 --- No such file or directory
The device apparently does not exist; did you specify it correctly?
mount: special device /dev/loop0p2 does not exist
mount: special device /dev/loop0p1 does not exist
[ o.k. ] Copying files to image [ tmprootfs.raw ]
        620.37M  99%   72.26MB/s    0:00:08 (xfr#34740, to-chk=0/43498)
sent 622.99M bytes  received 698.87K bytes  73.38M bytes/sec
total size is 623.97M  speedup is 1.00
sed: can't read /home/gr/armbian/output/cache/mount/boot/boot.cmd: No such file or directory
mkimage: Can't stat /home/gr/armbian/output/cache/mount/boot/boot.cmd: No such file or directory
tmpfs           1.2G  673M  528M  57% /home/gr/armbian/output/cache/sdcard
[ o.k. ] Writing bootloader [ /dev/loop0 ]
[ error ] U-boot failed to install [ @host ]
I see... losetup -P option must be missing in Trusty  -_- Will fix in a moment
Edit: Fixed
Edit 2: Tested. Should work if boot partition size is increased to 32M to have enough space for 2 copies of zImage (I mean for all devices that have FAT /boot partition).
@wildcat_paris
sudo apt-get install wine
not exactly, since you can add some wine to it   :lol:
@AnyFox
I guess you already know about uboot 16.01-rc4 and lamobo-r1
https://github.com/db260179/openwrt-bpi-r1/releases/tag/v1.1-stable-bpi-r1-openwrt
@Zador
already too much wine for Armbian :(
I wanted to test but I am stuck @
[ o.k. ] ... updating [ linux-vanilla ]
remote: Counting objects: 4421354, done.
remote: Compressing objects: 100% (733075/733075), done.
Receiving objects:   3% (154000/4421354), 65.41 MiB | 10.00 KiB/s
@wildcat_paris
try
USE_MAINLINE_GOOGLE_MIRROR=yes
for me git.kernel.org is painfully slow (with any protocol) comparing to github or googlesource.com
Edit: Probably you'll have to delete partially downloaded mainline kernel sources
Posted (edited)
@Zador
sure! you are right.
but I forgot to config my favorite git in configuration.sh
#KERNEL_DEV='git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git'
KERNEL_DEV='git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git'
it is slow but limited to the latest tags for DEV
too slow... thanks Zador KERNEL_DEV='https://kernel.googlesource.com/pub/scm/linux/kernel/git/torvalds/linux'
Posted (edited)
@Zador
googlesource/torvard works like a charm (RX=5MB/s). thanks!
I have applied your configuration-ng patch, some polish needed for trusty??? ("losetup: invalid option -- 'P'"???)
dpkg-deb: building package `linux-firmware-image-dev-sunxi' in `../linux-firmware-image-dev-sunxi_4.83_armhf.deb'.
dpkg-deb: building package `linux-dtb-dev-sunxi' in `../linux-dtb-dev-sunxi_4.83_armhf.deb'.
dpkg-deb: building package `linux-headers-dev-sunxi' in `../linux-headers-dev-sunxi_4.83_armhf.deb'.
dpkg-deb: building package `linux-image-dev-sunxi' in `../linux-image-dev-sunxi_4.83_armhf.deb'.
dpkg-genchanges: warning: package linux-libc-dev-dev-sunxi in control file but not in files list
dpkg-genchanges: binary-only upload - not including any source code
[ o.k. ] Creating board support package. [ lamobo-r1 ]
[ o.k. ] Fingerprinting. [ Armbian 4.83 Lamobo-r1 Ubuntu trusty dev Linux 4.4.0-rc8 ]
[ o.k. ] Building deb package. [ linux-trusty-root-lamobo-r1_4.83_armhf.deb ]
[ o.k. ] Starting build process for [ lamobo-r1 trusty ]
trusty-ng.tgz:  176MB [45.3MB/s] [===================================================================================================>] 100%
[ o.k. ] Installing kernel, u-boot and board specific [ trusty lamobo-r1 ]
[ o.k. ] Install kernel [ linux-image-dev-sunxi_4.83_armhf.deb ]
[ o.k. ] Install u-boot [ linux-u-boot-dev-sunxi_4.83_armhf.deb ]
[ o.k. ] Install headers [ linux-headers-dev-sunxi_4.83_armhf.deb ]
[ o.k. ] Install firmware [ linux-firmware-image-dev-sunxi_4.83_armhf.deb ]
[ o.k. ] Install DTB [ linux-dtb-dev-sunxi_4.83_armhf.deb ]
[ o.k. ] Creating boot scripts [ lamobo-r1 ]
[ o.k. ] Preparing image file for rootfs [ lamobo-r1 trusty ]
[ o.k. ] Creating blank image for rootfs [ 1004 MiB ]
1e+03MB [ 102MB/s] [=================================================================================================================>] 100%
[ o.k. ] Creating partitions [ root: ext4 ]
Usage:
Options:
                         recommended
        617.72M  99%   60.90MB/s    0:00:09 (xfr#35708, to-chk=0/44798)
sent 620.41M bytes  received 718.69K bytes  59.16M bytes/sec
total size is 621.32M  speedup is 1.00
/dev/loop0p1    972M  699M  208M  78% /home/gr/armbian/output/cache/mount
[ o.k. ] Signing and compressing [ Armbian_4.83_Lamobo-r1_Ubuntu_trusty_4.4.0-rc8.zip ]
[ o.k. ] Done building [ /home/gr/armbian/output/images/Armbian_4.83_Lamobo-r1_Ubuntu_trusty_4.4.0-rc8.zip ]
[ o.k. ] Runtime [ 6 min ]
Zador : patch badly applied
Posted (edited)
@Zador
:P  I just forgot to remove/comment the line with "losetup -P" otherwise the process is fine -- my BAD
trusty-ng.tgz:  176MB [  52MB/s] [===================================================================================================>] 100%
1e+03MB [79.2MB/s] [=================================================================================================================>] 100%
        617.72M  99%   62.20MB/s    0:00:09 (xfr#35708, to-chk=0/44798)
sent 620.41M bytes  received 718.65K bytes  65.38M bytes/sec
edit : like a charm => spoiler
@all
FYI, kernel 4.4.0 is out
Tested USB OTG on cubietruck; OTG autodetect and vbus (automatically enabling power on OTG port when OTG cable is plugged in) works with some extra kernel modules, will upload my kernel config later.
As a side-effect, I can use onboard miniUSB port as a serial console (only after systemd starts necessary getty service, of course).
Onboard audio works if DMA driver is loaded via /etc/modules or if it's compiled as built-in.
Edit: extras for /etc/modules:
# sunxi musb OTG
sunxi
# serial gadget (old) driver - required
g_serial
# ACM - for serial port emulation
usb_f_acm
Edit 2: For Debian Jessie (or stretch) gadget serial device name is /dev/ttyGS0, so command to enable it would be
sudo systemctl enable getty@ttyGS0.service
@Igor
I switched to using (and editing if needed) "standart" boot.cmd, since using "next" would break images for all boards that don't use mainline u-boot or use extra kernel parameters, even if no change to boot script is needed in the first place.
Those are needed to boot u-boot and they are *must be* present in u-boot package.
