Tony3 Posted June 23, 2024 Posted June 23, 2024 (edited) Dear All, I have a USB wifi device that has always been working fine at boot with linux 5.1, now I upgraded to 6.1 gnome/vendor and I got a strange behavior on my OPI 5: - If I have wifi device plugged and power on the PI5, the USB device is not seen (no trace of it with lsusb). - If I have wifi device plugged and power on the PI5, the USB device is not seen (no trace of it with lsusb). But, with the PI 5 still running, If I unplug it and re-plug it, it is recognized and works fine. Also after that, if I issue a sudo reboot, the wifi device will be seen and work properly. (it does not matter what usb port I use white, or blue, same behavior on all) - If I plug the usb device on an external usb hub (with no external power source) with the USB-C and power On the PI5 the wifi usb is recognized at boot and works fine. What could this be due? Regards, Edited June 23, 2024 by Tony3 improved description of the issue 0 Quote
Werner Posted June 23, 2024 Posted June 23, 2024 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Tony3 Posted June 23, 2024 Author Posted June 23, 2024 (edited) ok, so I booted the PI5 with the Wifi usb connected. There was no network I unplugged it, replugged it run armbianmonitor -u The URL is: https://paste.armbian.com/onufowuwox Not sure if it helps, but the device not recognised at boot is (of course message below appeared when i unplugged replugged the wifi device): 81.480055] usb 7-1: new high-speed USB device number 2 using xhci-hcd [ 81.621038] usb 7-1: New USB device found, idVendor=27d5, idProduct=0001, bcdDevice= 1.00 [ 81.621095] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 81.621126] usb 7-1: Product: USBWLAN [ 81.621151] usb 7-1: Manufacturer: Qualcomm Atheros. [ 81.621177] usb 7-1: SerialNumber: 12345678 Edited June 23, 2024 by Tony3 0 Quote
Tony3 Posted July 10, 2024 Author Posted July 10, 2024 I bought the WiFi dongle as attached, works pretty well and fixed my issue 0 Quote
