saljut7 Posted May 7, 2017 Posted May 7, 2017 Hello together sorry for this long description but I want to provide all information I could save. I'm running armbian since 2(?) years and had never a serious problem with it. Today the system was not reachable anymore (services, ssh, ping) so I rebooted the server. Rebooting worked but all my data is on an external encrypted harddisk which I couldn't open anymore: root@MyCubietruck:~# cryptsetup luksOpen /dev/sda1 MyEncryptedHarddisk Enter passphrase for /dev/sda1: device-mapper: reload ioctl on failed: No such file or directory Failed to setup dm-crypt key mapping for device /dev/sda1. Check that kernel supports aes-xts-plain64 cipher (check syslog for more info). journalctl said: root@MyCubietruck:~# journalctl -r May 07 13:37:11 MyCubietruck kernel: device-mapper: ioctl: error adding target to table May 07 13:37:11 MyCubietruck kernel: device-mapper: table: 254:0: crypt: Error allocating crypto tfm System and kernel info when the armbian was still working was: root@MyCubietruck:~# uname -a Linux MyCubietruck 4.10.12-sunxi #7 SMP Wed Apr 26 02:44:12 CEST 2017 armv7l GNU/Linux root@MyCubietruck:~# cat /etc/debian_version 8.8 So I tried to find similar problems amd found: The point is: I didn't upgrade the kernel and according to my logwatch mail from this morning there was no kernel upgrade. Now I made a huge mistake: I assumed a kernel problem anyway and tried to solve it with a kernel downgrade (even though I didn't try something like this before) - and I thought should use the script provided by @Igor : ...and noticed this information too late: Well, the script (choosing "Cubietruck" and "vanilla" ended up with): ┌─Armbian universal installer 2015.11───┐ │ │ │ Removing conflicting packages ... │ │ │ └───────────────────────────────────────┘ E: Unable to locate package nstall_new E: Unable to locate package "" E: Unable to locate package "Installing E: Unable to locate package packages..." The upgrade.log says: The following packages will be REMOVED: linux-dtb-next-sunxi 0 packages upgraded, 0 newly installed, 1 to remove and 0 not upgraded. Need to get 0 B of archives. After unpacking 4,163 kB will be freed. (Reading database ... ^M(Reading database ... 5%^M(Reading database ... 10%^M(Reading database ... 15%^M(Reading database ... 20%^M(Reading database ... 25%^M(Reading database ... 30%^M(Reading database ... 35%^M(Reading database ... 40%^M(Reading database ... 45%^M(Reading database ... 50%^M(Reading database ... 55%^M(Reading database ... 60%^M(Reading database ... 65%^M(Reading database ... 70%^M(Reading database ... 75%^M(Reading database ... 80%^M(Reading database ... 85%^M(Reading database ... 90%^M(Reading database ... 95%^M(Reading database ... 100%^M(Reading database ... 105718 files and directories currently installed.)^M Removing linux-dtb-next-sunxi (5.27.170427) ...^M No packages will be installed, upgraded, or removed. 0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B of archives. After unpacking 0 B will be used. Note: selecting "linux-image-dev-rockchip" instead of the virtual package "linux-image-4.10.0-rockchip" Note: selecting "linux-image-sun8i" instead of the virtual package "linux-image-3.4.113-sun8i" "linux-image-3.4.112-sun8i" exists in the package database, but it is not a real package and no package provides it. "linux-image-4.8.3-sun8i" exists in the package database, but it is not a real package and no package provides it. "linux-image-4.7.3-sun8i" exists in the package database, but it is not a real package and no package provides it. Note: selecting "linux-image-dev-sun8i" instead of the virtual package "linux-image-4.10.0-sun8i" "linux-image-4.9.4-sun8i" exists in the package database, but it is not a real package and no package provides it. The following packages will be REMOVED: linux-image-next-sunxi 0 packages upgraded, 0 newly installed, 1 to remove and 0 not upgraded. Need to get 0 B of archives. After unpacking 48.8 MB will be freed. (Reading database ... ^M(Reading database ... 5%^M(Reading database ... 10%^M(Reading database ... 15%^M(Reading database ... 20%^M(Reading database ... 25%^M(Reading database ... 30%^M(Reading database ... 35%^M(Reading database ... 40%^M(Reading database ... 45%^M(Reading database ... 50%^M(Reading database ... 55%^M(Reading database ... 60%^M(Reading database ... 65%^M(Reading database ... 70%^M(Reading database ... 75%^M(Reading database ... 80%^M(Reading database ... 85%^M(Reading database ... 90%^M(Reading database ... 95%^M(Reading database ... 100%^M(Reading database ... 105562 files and directories currently installed.)^M Removing linux-image-next-sunxi (5.27.170427) ...^M update-initramfs: Deleting /boot/initrd.img-4.10.12-sunxi^M "linux-headers-2.6" is a virtual package provided by: linux-headers-sun7i linux-headers-sun5i linux-headers-sun4i You must choose one to install. Note: selecting "linux-headers-sun8i" instead of the virtual package "linux-headers-3.4.113-sun8i" "linux-headers-3.4.112-sun8i" exists in the package database, but it is not a real package and no package provides it. The following packages will be REMOVED: linux-headers-next-sunxi 0 packages upgraded, 0 newly installed, 1 to remove and 0 not upgraded. Need to get 0 B of archives. After unpacking 73.0 MB will be freed Yes, I know it is stupid but I rebooted again and ended up with: *** ERROR: 'serverip' not set missing encironment variable: bootfile Retrieving file: pxelinux.cfg/default-arm Speed: 1000, full duplex *** ERROR: 'serverip' not set missing encironment variable: bootfile Retrieving file: pxelinux.cfg/default-arm Speed: 1000, full duplex *** ERROR: 'serverip' not set Config file not found Speed: 1000, full duplex BOOTP boradcast 1 BOOTP boradcast 2 DHCP client bound to address 192.168.1.3 (2189 ms) Zsubg tgerber q01c50000 decie TFTP from server 0.0.0.0; our IP address is 192.168.1.3; sending through gateway 192.168.1.1 Filename 'boot.scr.uing'. Load address: 0x43100000 Loading: T T T T T T T T T T Retry cound exceeded; starting again sunxi# For the case it is already to late to fix this with "two or three commands" I would at least try to understand what was causing the problem: why "Failed to setup dm-crypt key mapping" today? Thx a lot for all helping comments and sorry again for the long description. sj7
zador.blood.stained Posted May 7, 2017 Posted May 7, 2017 41 minutes ago, saljut7 said: For the case it is already to late to fix this with "two or three commands" I would at least try to understand what was causing the problem: why "Failed to setup dm-crypt key mapping" today? As it was stated in one of the threads you linked, an untested kernel was pushed to the stable repository by mistake, and since your initial kernel version was 4.10.12, this updated kernel was installed on your device before you tried to downgrade it. For the reference "upgrade.armbian.com" is obsolete and I am surprised that it is still not disabled. 1
Igor Posted May 7, 2017 Posted May 7, 2017 7 minutes ago, zador.blood.stained said: For the reference "upgrade.armbian.com" is obsolete and I am surprised that it is still not disabled. Done. 2
saljut7 Posted May 7, 2017 Author Posted May 7, 2017 Thx @zador.blood.stained and @Igor: is there a way to to get a working kernel back on my system? I mean: as long there is a prompt (sunxi# ?) there is hope, isn't it?
Igor Posted May 8, 2017 Posted May 8, 2017 https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-unbrick-the-system 1
saljut7 Posted May 8, 2017 Author Posted May 8, 2017 (edited) Thx @Igor. Here is my complete "how I fixed it log" because the "How to unbrick the system" didn't work for me completely because in my case uInitrd-4.9.7-sunxi and initrd.img-4.9.7-sunxi were not provided by the download links. Here is how I fixed my armbian kernel step by step (originally in markdown, sorry for some format issues). Hope it will help other users fixing a similar problem: ### Backup sd-card Create a backup with `dd`, example: # pv /dev/sdb | dd of=/home/YourUser/backups/YourServerHostname2017-05-08.img && sync ### Extract kernel DEBs to sd-card > Mount SD card and extract all those deb files to it’s mount point: dpkg -x linux-???.deb /media/...???.../mnt Example: root@YourRescueSystems:/path/to/your/downloaded/armbian_kernel_DEBs# ls -la total 25912 drwxr-xr-x 2 YourUser YourUser 4096 May 8 19:36 . drwxr-xr-x 5 YourUser YourUser 12288 May 8 18:16 .. -rw-r--r-- 1 YourUser YourUser 141466 May 8 19:35 linux-dtb-next-sunxi_5.25_armhf.deb -rw-r--r-- 1 YourUser YourUser 58860 May 8 19:35 linux-firmware-image-next-sunxi_5.25_armhf.deb -rw-r--r-- 1 YourUser YourUser 10267140 May 8 19:36 linux-headers-next-sunxi_5.25_armhf.deb -rw-r--r-- 1 YourUser YourUser 15415128 May 8 19:36 linux-image-next-sunxi_5.25_armhf.deb -rw-r--r-- 1 YourUser YourUser 362732 May 8 18:02 linux-jessie-root-next-cubietruck_5.25_armhf.deb -rw-r--r-- 1 YourUser YourUser 211868 May 8 17:56 linux-u-boot-next-cubietruck_5.25_armhf.deb root@YourRescueSystems:/path/to/your/downloaded/armbian_kernel_DEBs# dpkg -x linux-dtb-next-sunxi_5.25_armhf.deb /media/YourUser/SD-cardIDofYourBrokenArmbian/ root@YourRescueSystems:/path/to/your/downloaded/armbian_kernel_DEBs# dpkg -x linux-firmware-image-next-sunxi_5.25_armhf.deb /media/YourUser/SD-cardIDofYourBrokenArmbian/ root@YourRescueSystems:/path/to/your/downloaded/armbian_kernel_DEBs# dpkg -x linux-headers-next-sunxi_5.25_armhf.deb /media/YourUser/SD-cardIDofYourBrokenArmbian/ root@YourRescueSystems:/path/to/your/downloaded/armbian_kernel_DEBs# dpkg -x linux-image-next-sunxi_5.25_armhf.deb /media/YourUser/SD-cardIDofYourBrokenArmbian/ root@YourRescueSystems:/path/to/your/downloaded/armbian_kernel_DEBs# dpkg -x linux-jessie-root-next-cubietruck_5.25_armhf.deb /media/YourUser/SD-cardIDofYourBrokenArmbian/ root@YourRescueSystems:/path/to/your/downloaded/armbian_kernel_DEBs# dpkg -x linux-u-boot-next-cubietruck_5.25_armhf.deb /media/YourUser/SD-cardIDofYourBrokenArmbian/ ### Symlink vmlinuz-4.x.x-sunxi > Go to /mnt/boot and link (or copy) `vmlinuz-4.x.x-sunxi` kernel file to `zImage`: Example: root@YourRescueSystems:/path/to/your/downloaded/armbian_kernel_DEBs# cd /media/YourUser/SD-cardIDofYourBrokenArmbian/ root@YourRescueSystems:/media/YourUser/SD-cardIDofYourBrokenArmbian# cd boot/ root@YourRescueSystems:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# ls -la total 13100 drwxr-xr-x 6 root root 4096 Feb 2 03:20 . drwxr-xr-x 22 root root 4096 Feb 2 02:21 .. drwxr-xr-x 2 root root 4096 Feb 2 03:20 bin drwxr-xr-x 2 root root 4096 Oct 24 2016 bin.old -rwxr-xr-x 1 root root 6944 Sep 16 2015 boot.bmp -rwxr-xr-x 1 root root 1698 May 7 14:30 boot.cmd -rwxr-xr-x 1 root root 1749 May 7 14:30 boot.cmd.backup -rw-r--r-- 1 root root 1770 May 7 14:30 boot.scr -rw-r--r-- 1 root root 144620 Feb 2 01:53 config-4.9.7-sunxi lrwxrwxrwx 1 root root 17 Apr 30 14:30 dtb -> dtb-4.10.12-sunxi drwxr-xr-x 2 root root 4096 Sep 24 2016 dtb-4.6.3-sunxi drwxr-xr-x 2 root root 4096 Feb 2 01:53 dtb-4.9.7-sunxi lrwxrwxrwx 1 root root 16 Feb 25 01:06 dtb.old -> dtb-4.9.12-sunxi -rw-r--r-- 1 root root 0 Apr 30 14:31 .next lrwxrwxrwx 1 root root 24 Sep 16 2015 script.bin -> /boot/bin/cubietruck.bin -rw-r--r-- 1 root root 2695178 Feb 2 01:53 System.map-4.9.7-sunxi lrwxrwxrwx 1 root root 21 May 7 12:49 uInitrd -> uInitrd-4.10.12-sunxi -rw-r--r-- 1 root root 4484597 May 7 12:49 uInitrd-4.10.12-sunxi -rw-r--r-- 1 root root 0 Jan 1 1970 .verbose -rwxr-xr-x 1 root root 6037368 Feb 2 01:53 vmlinuz-4.9.7-sunxi lrwxrwxrwx 1 root root 21 Apr 30 14:31 zImage -> vmlinuz-4.10.12-sunxi root@YourRescueSystems:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# rm zImage root@YourRescueSystems:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# ln -s vmlinuz-4.9.7-sunxi zImage root@YourRescueSystems:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# ls -la total 13100 drwxr-xr-x 6 root root 4096 May 8 20:41 . drwxr-xr-x 22 root root 4096 Feb 2 02:21 .. drwxr-xr-x 2 root root 4096 Feb 2 03:20 bin drwxr-xr-x 2 root root 4096 Oct 24 2016 bin.old -rwxr-xr-x 1 root root 6944 Sep 16 2015 boot.bmp -rwxr-xr-x 1 root root 1698 May 7 14:30 boot.cmd -rwxr-xr-x 1 root root 1749 May 7 14:30 boot.cmd.backup -rw-r--r-- 1 root root 1770 May 7 14:30 boot.scr -rw-r--r-- 1 root root 144620 Feb 2 01:53 config-4.9.7-sunxi lrwxrwxrwx 1 root root 17 Apr 30 14:30 dtb -> dtb-4.10.12-sunxi drwxr-xr-x 2 root root 4096 Sep 24 2016 dtb-4.6.3-sunxi drwxr-xr-x 2 root root 4096 Feb 2 01:53 dtb-4.9.7-sunxi lrwxrwxrwx 1 root root 16 Feb 25 01:06 dtb.old -> dtb-4.9.12-sunxi -rw-r--r-- 1 root root 0 Apr 30 14:31 .next lrwxrwxrwx 1 root root 24 Sep 16 2015 script.bin -> /boot/bin/cubietruck.bin -rw-r--r-- 1 root root 2695178 Feb 2 01:53 System.map-4.9.7-sunxi lrwxrwxrwx 1 root root 21 May 7 12:49 uInitrd -> uInitrd-4.10.12-sunxi -rw-r--r-- 1 root root 4484597 May 7 12:49 uInitrd-4.10.12-sunxi -rw-r--r-- 1 root root 0 Jan 1 1970 .verbose -rwxr-xr-x 1 root root 6037368 Feb 2 01:53 vmlinuz-4.9.7-sunxi lrwxrwxrwx 1 root root 19 May 8 20:41 zImage -> vmlinuz-4.9.7-sunxi root@YourRescueSystems:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# ### Test your (maybe) unbricked system cd / umount /media/YourUser/SD-cardIDofYourBrokenArmbian Problem: armbian still doesn't boot. :/ #### Comparison FreshInstalledArmbian <-> BrokenArmbian root@YourRescueSystem:/media/YourUser/SD-cardIDofYourFreshInstalledArmbian/boot# ls -la total 16656 drwxr-xr-x 4 root root 4096 May 8 21:51 . drwxr-xr-x 22 root root 4096 Feb 5 22:54 .. -rw-r--r-- 1 root root 114 May 8 21:51 armbianEnv.txt drwxr-xr-x 2 root root 4096 Feb 5 22:58 bin -rw-r--r-- 1 root root 6944 Feb 5 22:59 boot.bmp -rw-r--r-- 1 root root 2580 Feb 5 22:53 boot.cmd -rw-r--r-- 1 root root 2652 Feb 5 23:00 boot.scr -rw-r--r-- 1 root root 144620 Feb 2 01:53 config-4.9.7-sunxi lrwxrwxrwx 1 root root 15 Feb 5 22:58 dtb -> dtb-4.9.7-sunxi drwxr-xr-x 2 root root 4096 Feb 5 22:58 dtb-4.9.7-sunxi -rw-r--r-- 1 root root 4065438 Feb 5 22:59 initrd.img-4.9.7-sunxi -rw-r--r-- 1 root root 0 Feb 5 22:54 .next lrwxrwxrwx 1 root root 18 Feb 5 22:58 script.bin -> bin/cubietruck.bin -rw-r--r-- 1 root root 2695178 Feb 2 01:53 System.map-4.9.7-sunxi lrwxrwxrwx 1 root root 19 Feb 5 22:59 uInitrd -> uInitrd-4.9.7-sunxi -rw-r--r-- 1 root root 4065502 Feb 5 22:59 uInitrd-4.9.7-sunxi -rwxr-xr-x 1 root root 6037368 Feb 2 01:53 vmlinuz-4.9.7-sunxi lrwxrwxrwx 1 root root 19 Feb 5 22:54 zImage -> vmlinuz-4.9.7-sunxi root@YourRescueSystems:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# ls -la total 13100 drwxr-xr-x 6 root root 4096 May 8 20:41 . drwxr-xr-x 22 root root 4096 Feb 2 02:21 .. drwxr-xr-x 2 root root 4096 Feb 2 03:20 bin drwxr-xr-x 2 root root 4096 Oct 24 2016 bin.old -rwxr-xr-x 1 root root 6944 Sep 16 2015 boot.bmp -rwxr-xr-x 1 root root 1698 May 7 14:30 boot.cmd -rwxr-xr-x 1 root root 1749 May 7 14:30 boot.cmd.backup -rw-r--r-- 1 root root 1770 May 7 14:30 boot.scr -rw-r--r-- 1 root root 144620 Feb 2 01:53 config-4.9.7-sunxi lrwxrwxrwx 1 root root 17 Apr 30 14:30 dtb -> dtb-4.10.12-sunxi drwxr-xr-x 2 root root 4096 Sep 24 2016 dtb-4.6.3-sunxi drwxr-xr-x 2 root root 4096 Feb 2 01:53 dtb-4.9.7-sunxi lrwxrwxrwx 1 root root 16 Feb 25 01:06 dtb.old -> dtb-4.9.12-sunxi -rw-r--r-- 1 root root 0 Apr 30 14:31 .next lrwxrwxrwx 1 root root 24 Sep 16 2015 script.bin -> /boot/bin/cubietruck.bin -rw-r--r-- 1 root root 2695178 Feb 2 01:53 System.map-4.9.7-sunxi lrwxrwxrwx 1 root root 21 May 7 12:49 uInitrd -> uInitrd-4.10.12-sunxi -rw-r--r-- 1 root root 4484597 May 7 12:49 uInitrd-4.10.12-sunxi -rw-r--r-- 1 root root 0 Jan 1 1970 .verbose -rwxr-xr-x 1 root root 6037368 Feb 2 01:53 vmlinuz-4.9.7-sunxi lrwxrwxrwx 1 root root 19 May 8 20:41 zImage -> vmlinuz-4.9.7-sunxi root@YourRescueSystems:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# So in my case some symlinks still point on ^4.10.*^ files: dtb -> dtb-4.10.12-sunxi (should point on ^dtb-4.9.7-sunxi^) uInitrd -> uInitrd-4.10.12-sunxi (should point on ^uInitrd-4.9.7-sunxi^ which is missing) And `initrd.img-4.9.7-sunxi` is missing. To get `uInitrd-4.9.7-sunxi` and `initrd.img-4.9.7-sunxi` I flashed `Armbian_5.25_Cubietruck_Debian_jessie_next_4.9.7.img` on another sd-card copied the missing files from `/media/YourUser/SD-cardIDofYourFreshInstalledArmbian/boot/uInitrd-4.9.7-sunxi` to `/media/YourUser/SD-cardIDofYourBrokenArmbian/boot/`. Then I fixed `dtb` and `uInitrd` symlinks in `/media/YourUser/SD-cardIDofYourBrokenArmbian/boot` and deleted all `4.10.12` files via: rm dtb rm uInitrd ln -s dtb-4.9.7-sunxi dtb ln -s uInitrd-4.9.7-sunxi uInitrd rm *4.10.12* Example: root@YourRescueSystem:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# ls -la total 17072 drwxr-xr-x 6 root root 4096 May 8 22:01 . drwxr-xr-x 22 root root 4096 Feb 2 02:21 .. drwxr-xr-x 2 root root 4096 Feb 2 03:20 bin drwxr-xr-x 2 root root 4096 Oct 24 2016 bin.old -rwxr-xr-x 1 root root 6944 Sep 16 2015 boot.bmp -rwxr-xr-x 1 root root 1698 May 7 14:30 boot.cmd -rwxr-xr-x 1 root root 1749 May 7 14:30 boot.cmd.backup -rw-r--r-- 1 root root 1770 May 7 14:30 boot.scr -rw-r--r-- 1 root root 144620 Feb 2 01:53 config-4.9.7-sunxi lrwxrwxrwx 1 root root 17 Apr 30 14:30 dtb -> dtb-4.10.12-sunxi drwxr-xr-x 2 root root 4096 Sep 24 2016 dtb-4.6.3-sunxi drwxr-xr-x 2 root root 4096 Feb 2 01:53 dtb-4.9.7-sunxi lrwxrwxrwx 1 root root 16 Feb 25 01:06 dtb.old -> dtb-4.9.12-sunxi -rw-r--r-- 1 root root 4065438 May 8 22:13 initrd.img-4.9.7-sunxi -rw-r--r-- 1 root root 0 Apr 30 14:31 .next lrwxrwxrwx 1 root root 24 Sep 16 2015 script.bin -> /boot/bin/cubietruck.bin -rw-r--r-- 1 root root 2695178 Feb 2 01:53 System.map-4.9.7-sunxi lrwxrwxrwx 1 root root 21 May 7 12:49 uInitrd -> uInitrd-4.10.12-sunxi -rw-r--r-- 1 root root 4484597 May 7 12:49 uInitrd-4.10.12-sunxi -rw-r--r-- 1 root root 4065502 May 8 22:01 uInitrd-4.9.7-sunxi -rw-r--r-- 1 root root 0 Jan 1 1970 .verbose -rwxr-xr-x 1 root root 6037368 Feb 2 01:53 vmlinuz-4.9.7-sunxi lrwxrwxrwx 1 root root 19 May 8 20:41 zImage -> vmlinuz-4.9.7-sunxi root@YourRescueSystem:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# rm dtb root@YourRescueSystem:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# rm uInitrd root@YourRescueSystem:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# ln -s dtb-4.9.7-sunxi dtb root@YourRescueSystem:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# ln -s uInitrd-4.9.7-sunxi uInitrd root@YourRescueSystem:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# rm *4.10.12* root@YourRescueSystem:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# ls -la total 16664 drwxr-xr-x 6 root root 4096 May 8 22:16 . drwxr-xr-x 22 root root 4096 Feb 2 02:21 .. drwxr-xr-x 2 root root 4096 Feb 2 03:20 bin drwxr-xr-x 2 root root 4096 Oct 24 2016 bin.old -rwxr-xr-x 1 root root 6944 Sep 16 2015 boot.bmp -rwxr-xr-x 1 root root 1698 May 7 14:30 boot.cmd -rwxr-xr-x 1 root root 1749 May 7 14:30 boot.cmd.backup -rw-r--r-- 1 root root 1770 May 7 14:30 boot.scr -rw-r--r-- 1 root root 144620 Feb 2 01:53 config-4.9.7-sunxi lrwxrwxrwx 1 root root 15 May 8 22:04 dtb -> dtb-4.9.7-sunxi drwxr-xr-x 2 root root 4096 Sep 24 2016 dtb-4.6.3-sunxi drwxr-xr-x 2 root root 4096 Feb 2 01:53 dtb-4.9.7-sunxi lrwxrwxrwx 1 root root 16 Feb 25 01:06 dtb.old -> dtb-4.9.12-sunxi -rw-r--r-- 1 root root 4065438 May 8 22:13 initrd.img-4.9.7-sunxi -rw-r--r-- 1 root root 0 Apr 30 14:31 .next lrwxrwxrwx 1 root root 24 Sep 16 2015 script.bin -> /boot/bin/cubietruck.bin -rw-r--r-- 1 root root 2695178 Feb 2 01:53 System.map-4.9.7-sunxi lrwxrwxrwx 1 root root 19 May 8 22:04 uInitrd -> uInitrd-4.9.7-sunxi -rw-r--r-- 1 root root 4065502 May 8 22:01 uInitrd-4.9.7-sunxi -rw-r--r-- 1 root root 0 Jan 1 1970 .verbose -rwxr-xr-x 1 root root 6037368 Feb 2 01:53 vmlinuz-4.9.7-sunxi lrwxrwxrwx 1 root root 19 May 8 20:41 zImage -> vmlinuz-4.9.7-sunxi root@YourRescueSystem:/media/YourUser/SD-cardIDofYourBrokenArmbian/boot# Comparison with FreshInstalledArmbian: root@YourRescueSystem:/media/YourUser/SD-cardIDofYourFreshInstalledArmbian/boot# ls -la total 16656 drwxr-xr-x 4 root root 4096 May 8 21:51 . drwxr-xr-x 22 root root 4096 Feb 5 22:54 .. -rw-r--r-- 1 root root 114 May 8 21:51 armbianEnv.txt drwxr-xr-x 2 root root 4096 Feb 5 22:58 bin -rw-r--r-- 1 root root 6944 Feb 5 22:59 boot.bmp -rw-r--r-- 1 root root 2580 Feb 5 22:53 boot.cmd -rw-r--r-- 1 root root 2652 Feb 5 23:00 boot.scr -rw-r--r-- 1 root root 144620 Feb 2 01:53 config-4.9.7-sunxi lrwxrwxrwx 1 root root 15 Feb 5 22:58 dtb -> dtb-4.9.7-sunxi drwxr-xr-x 2 root root 4096 Feb 5 22:58 dtb-4.9.7-sunxi -rw-r--r-- 1 root root 4065438 Feb 5 22:59 initrd.img-4.9.7-sunxi -rw-r--r-- 1 root root 0 Feb 5 22:54 .next lrwxrwxrwx 1 root root 18 Feb 5 22:58 script.bin -> bin/cubietruck.bin -rw-r--r-- 1 root root 2695178 Feb 2 01:53 System.map-4.9.7-sunxi lrwxrwxrwx 1 root root 19 Feb 5 22:59 uInitrd -> uInitrd-4.9.7-sunxi -rw-r--r-- 1 root root 4065502 Feb 5 22:59 uInitrd-4.9.7-sunxi -rwxr-xr-x 1 root root 6037368 Feb 2 01:53 vmlinuz-4.9.7-sunxi lrwxrwxrwx 1 root root 19 Feb 5 22:54 zImage -> vmlinuz-4.9.7-sunxi Magic moment... ...armbian is booting again. Edited May 8, 2017 by saljut7 markdown -> html
