usb wifi adapter is not recognized
Go to solution Solved by Igor,
I'm trying to use a TP-Link tl-wn722n with AR9271 chipset, but it only shows up in lsusb:
orange:~:% lsusb
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 0cf3:9271 Qualcomm Atheros Communications AR9271 802.11n
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
orange:~:%
There is no such device in "ip a" or "iw list". I have enabled orangepi-5-ap6275p in armbian-config and full firmware package. Also installed the "firmware-ath9k-htc" package, but nothing helps. "modprobe ath9k_htc" returns that there is no such module.
Edited by Netnax
yes ath9k-htc is not enabled .
You can also try to build your kernel and enable it.
Or build the module on your existing 5.10, I did that on the ath6k in the past.
Edited by Tony3
