fscii Posted July 22, 2024 Posted July 22, 2024 Running ODroid HC4 on Armbian bookworm with Openmediavault 7 with docker compose plugin. I've done 2 clean installs to ensure the problem is reproducable and not something I meddled with. I spent time on Docker's forums running sample containers I was asked to try, they viewed my settings logs for docker and were at a loss. The containers go up fine and are running. They just cannot be accessed even from the host machine e.g. curl http://localhost:8080 fails when running a sample container docker hub forums supplied me with as a 'surefire' test. --- services: test_default_bridge: image: nginx:latest network_mode: bridge ports: - 8080:80 Is anyone else having this issue and how do I get it working? 0 Quote
Werner Posted July 23, 2024 Posted July 23, 2024 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
fscii Posted July 23, 2024 Author Posted July 23, 2024 (edited) Ok here it is -- it also generated an error running the script. root@omv:~# armbianmonitor -u Collecting info and sending to paste.armbian.com, wait... /usr/bin/armbianmonitor: line 976: iostat: command not found https://paste.armbian.com/huqolomoku Edited July 24, 2024 by fscii 0 Quote
mrNobody Posted July 29, 2024 Posted July 29, 2024 I have the same issue on an Odroid M1. Also installed twice to make sure it wasn't the installation. I can access the container if I attach it to the host instead of the bridge, but since I'm going to be running multiple containers with the same internal ports, that is not a solution. Output of armbianmonitor -u: Collecting info and sending to paste.armbian.com, wait... /usr/bin/armbianmonitor: line 976: iostat: command not found https://paste.armbian.com/vuzemedifu 0 Quote
fscii Posted July 29, 2024 Author Posted July 29, 2024 I have finally got mine to work. run these two commands and post the results ip a networkctl list 0 Quote
fscii Posted July 29, 2024 Author Posted July 29, 2024 Short answer is follow this guide to the letter and it should work. https://wiki.omv-extras.org/doku.php?id=omv7:armbian_bookworm_install 0 Quote
Igor Posted July 30, 2024 Posted July 30, 2024 12 hours ago, mrNobody said: I can access the container if I attach it to the host instead of the bridge, but since I'm going to be running multiple containers with the same internal ports, that is not a solution. What about this? Should already be fixed if you make image from sources. 0 Quote
mrNobody Posted July 30, 2024 Posted July 30, 2024 It seems Dziekon's solution in that topic did the trick for me as well, although I would've rather used the clean way in the link you posted, but I couldn't find the template file mentioned: Quote Add IPMasquerade=yes to the eth0.network file. Thanks to a recent pull request, this is trivial to add to /etc/systemd/network/template/dosync-eth0.network.tail. 0 Quote
Igor Posted July 30, 2024 Posted July 30, 2024 1 hour ago, mrNobody said: I would've rather used the clean way I don't know if hat is a cleaner way. This is just a suggestion / idea based on a quick search. Didn't test it while @dziekon did. As I understand it, but didn't really study it deep, that DHCPing on all devices is a trouble. But there could be more (border) problems. 0 Quote
