totoxxx Posted July 25 Share Posted July 25 Hello Since few days, base-files is missing from armbian repository for armhf arch apt-cache policy base-files base-files: Installé : 24.5.1-12.4+deb12u5-bookworm Candidat : 24.5.1-12.4+deb12u5-bookworm Table de version : *** 24.5.1-12.4+deb12u5-bookworm 100 100 /var/lib/dpkg/status 12.4+deb12u6 500 500 http://ftp.debian.org/debian bookworm/main armhf Packages On the armbian repository http://armbian.hosthatch.com/apt/pool/bookworm/b/base-files/ only arm64 is available. Is it normal ? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 25 Share Posted July 25 10 hours ago, totoxxx said: On the armbian repository http://armbian.hosthatch.com/apt/pool/bookworm/b/base-files/ only arm64 is available. This looks like armhf: https://armbian.hosthatch.com/apt/pool/bookworm/b/base-files/base-files_24.5.1-12.4%2Bdeb12u5-bookworm_armhf__1-bookworm-1armbian1-Bbba0-U12.4--deb12u5-R55fa.deb Don't understand what is wrong? 0 Quote Link to comment Share on other sites More sharing options...
totoxxx Posted July 25 Author Share Posted July 25 (edited) Seems base-files is not referenced: grep linux-image-current-sunxi /var/lib/apt/lists/armbian.site-meganet.com_apt_dists_bookworm_* armbian.site-meganet.com_apt_dists_bookworm_main_binary-armhf_Packages:Package: linux-image-current-sunxi armbian.site-meganet.com_apt_dists_bookworm_main_binary-armhf_Packages:Filename: pool/main/l/linux-6.6.31/linux-image-current-sunxi_24.5.1_armhf__6.6.31-Se3d3-D440d-P83e6-C5047H5c21-HK01ba-V014b-Bf15a-R448a.deb armbian.site-meganet.com_apt_dists_bookworm_main_binary-armhf_Packages:Package: linux-image-current-sunxi armbian.site-meganet.com_apt_dists_bookworm_main_binary-armhf_Packages:Filename: pool/main/l/linux-6.6.16/linux-image-current-sunxi_24.2.1_armhf__6.6.16-Seb3e-D6b4a-P2359-Ce96bHfe66-HK01ba-V014b-B067e-R448a.deb grep 'Package: base-files' /var/lib/apt/lists/armbian.site-meganet.com_apt_dists_bookworm_* => return nothing Edited July 25 by totoxxx 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted July 25 Share Posted July 25 It looks like the mirror you are using was (is?) out of sync. The mirror I am routed to has the files: http://mirrors.jevincanders.net/armbian/apt/pool/bookworm/b/base-files Try apt update again to fetch current content from the mirror and if that doesn't work, try a different mirror. 0 Quote Link to comment Share on other sites More sharing options...
totoxxx Posted July 26 Author Share Posted July 26 Hello Both mirrors have the deb package but it's not referenced anymore (looking my grep in /var/lib/apt/lists). I just tested with jevincanders mirror: apt-cache policy base-files base-files: Installé : 24.5.1-12.4+deb12u5-bookworm Candidat : 24.5.1-12.4+deb12u5-bookworm Table de version : *** 24.5.1-12.4+deb12u5-bookworm 100 100 /var/lib/dpkg/status 12.4+deb12u6 500 500 http://ftp.debian.org/debian bookworm/main armhf Packages No base-files available. apt-cache policy linux-image-current-sunxi linux-image-current-sunxi: Installé : 24.5.1 Candidat : 24.5.1 Table de version : *** 24.5.1 500 500 http://mirrors.jevincanders.net/armbian/apt bookworm/main armhf Packages 100 /var/lib/dpkg/status 24.2.1 500 500 http://mirrors.jevincanders.net/armbian/apt bookworm/main armhf Packages Something is broken with armhf with armbian repository. Regards 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 27 Share Posted July 27 23 hours ago, totoxxx said: Something is broken Possible. I am still the only person behind repo management and everyone just see this as granted or not important. Even things collapsed here and there. If we want that repository function better, someone(s) must step up and and start helping. There are many people and 3rd party projects relying on its well functioning. https://github.com/armbian/build/tree/main/tools https://github.com/armbian/os/blob/main/.github/workflows/repository-update.yml https://github.com/armbian/os/blob/main/.github/workflows/repository-sync.yml 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 30 Share Posted July 30 Try now. Related: 0 Quote Link to comment Share on other sites More sharing options...
totoxxx Posted August 2 Author Share Posted August 2 Hello Check the other topic and tried your mirror but it does not work. apt-get update : Réception de :7 https://imola.armbian.com/apt bookworm InRelease [68,7 kB] Réception de :8 https://imola.armbian.com/apt bookworm/main armhf Packages [181 kB] Réception de :9 https://imola.armbian.com/apt bookworm/main all Packages [9 415 B] Réception de :10 https://imola.armbian.com/apt bookworm/main armhf Contents (deb) [4 182 kB] Réception de :11 https://imola.armbian.com/apt bookworm/main all Contents (deb) [32,5 kB] Réception de :12 https://imola.armbian.com/apt bookworm/bookworm-utils all Packages [2 624 B] Réception de :13 https://imola.armbian.com/apt bookworm/bookworm-utils armhf Packages [26,0 kB] Réception de :14 https://imola.armbian.com/apt bookworm/bookworm-utils all Contents (deb) [6 653 B] Réception de :15 https://imola.armbian.com/apt bookworm/bookworm-utils armhf Contents (deb) [12,9 kB] base-files: Installé : 24.5.1-12.4+deb12u5-bookworm Candidat : 24.5.1-12.4+deb12u5-bookworm Table de version : *** 24.5.1-12.4+deb12u5-bookworm 750 750 http://admtools.bdx.int/debian bookworm/main armhf Packages => this is my local mirror to fix the current issue on my side. 100 /var/lib/dpkg/status 12.4+deb12u6 500 500 http://ftp.debian.org/debian bookworm/main armhf Packages As you can see, your mirror does not appear in apt-cache policy. Index are still broken Regards 0 Quote Link to comment Share on other sites More sharing options...
Solution totoxxx Posted August 10 Author Solution Share Posted August 10 Repo is fixed. Thanks ! 0 Quote Link to comment Share on other sites More sharing options...
