sicxnull Posted July 25, 2024 Posted July 25, 2024 (edited) Hello Everyone I have added Armbian for the Heltec HT-M2808 Helium Miner https://github.com/armbian/build/pull/6989#event-13647037453 https://heltec.org/project/ht-m2808/ To Compile ./compile.sh build BOARD=rk3328-heltec BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=no EXPERT=no KERNEL_CONFIGURE=yes KERNEL_GIT=shallow RELEASE=bookworm You can obviously decide to go with a desktop environment (board has no HDMI) or use a different release. How to Flash 1) Install Rockchip Flash Tools 2) Download bootloader (rk3328_loader_ddr333_v1.16.250.bin) attached here. 3) Boot device into LOADER mode. Plug USB Cable in to back of the unit, powered off. On the back of the device. Use a small pin and hold the reset button (unit powered off) THEN insert the power cable while the reset button is pressed 4) Follow the flash procedure found here. Maskrom Pin If you get stuck and need to reflash, there's a good chance holding the reset button will not work to get back into LOADER mode. To boot directly to MASKROM, you can short this pin Needed 1) Wifi/BT does not work currently 2) SPI not recognized 3) LEDs not working 4) Likely other things, but the OS is 90% functional. rk3328_loader_ddr333_v1.16.250.bin Edited July 25, 2024 by sicxnull 0 Quote
mci Posted December 4, 2024 Posted December 4, 2024 Hi @sicxnull thank you very much for your efforts! Since it's been a while, have you had any success in getting the SPI up and running in the meantime? I've already tried various approaches but haven't really got any further. 0 Quote
sicxnull Posted December 5, 2024 Author Posted December 5, 2024 Yes it works by enabling the spi overlay in armbian-config Totally missed that at first. 0 Quote
proxynetul Posted 17 hours ago Posted 17 hours ago Tested and worked Thank you for your contribution ! 0 Quote
