lay Posted August 9 Share Posted August 9 Report the following error: Reversioning package [ re-version 'armbian-bsp-desktop-quartz64b-edge(deb)::1-B8091-R448a' to '24.8.0-trunk' ] [🔨] removed '/home/john/Armbian/development_armbian/build/output/packages-hashed/extra/jammy-desktop/armbian-bsp-desktop-quartz64b-edge_1-B8091-R448a_arm64.deb' [🌿] Building image [ quartz64b ] [🌱] Checking for rootfs cache [ edge quartz64b jammy desktop_tools internet gnome no ] [🌱] artifact [ rootfs :: rootfs() ] [🌱] rootfs version [ packages_hash: '50761c13748d-H01ba47-B4cac74' cache_type: 'gnome-desktop' rootfs_cache_id: '50761c13748d-H01ba47-B4cac74' ] [🌱] Getting ORAS manifest [ ORAS manifest from ghcr.io/armbian/os/rootfs-arm64-jammy-gnome-desktop:202408-50761c13748d-H01ba47-B4cac74 ] Error response from registry: failed to fetch the content of "ghcr.io/armbian/os/rootfs-arm64-jammy-gnome-desktop:202408-50761c13748d-H01ba47-B4cac74": ghcr.io/armbian/os/rootfs-arm64-jammy-gnome-desktop:202408-50761c13748d-H01ba47-B4cac74: not found [🌱] Artifact is not available in remote cache [ ghcr.io/armbian/os/rootfs-arm64-jammy-gnome-desktop:202408-50761c13748d-H01ba47-B4cac74 ] [🔨] mkdir: created directory '/home/john/Armbian/development_armbian/build/.tmp/rootfs-c5896909-a180-4b08-ae8c-92f5bdcfcb4c' [🔨] mkdir: created directory '/home/john/Armbian/development_armbian/build/.tmp/mount-c5896909-a180-4b08-ae8c-92f5bdcfcb4c' Processing triggers for dbus (1.12.20-2ubuntu4.1) ... [🌱] Checking MD5 sum of installed packages [ debsums ] [🔨] debsums: changed file /usr/share/doc/base-files/changelog.gz (from base-files package) [🔨] debsums: changed file /etc/os-release (from base-files package) [🔨] debsums: changed file /etc/issue.net (from base-files package) [🔨] debsums: changed file /etc/issue (from base-files package) [💥] Error context msg [ Check MD5 sum of installed packages failed ] [💥] Cleaning up [ please wait for cleanups to finish ] Link to comment Share on other sites More sharing options...
Werner Posted August 9 Share Posted August 9 clear your cache directory and retry Link to comment Share on other sites More sharing options...
Igor Posted August 9 Share Posted August 9 53 minutes ago, lay said: quartz64b Logs says you are compiling quartz64 ?! Link to comment Share on other sites More sharing options...
lay Posted August 10 Author Share Posted August 10 “clear your cache directory and retry” I'll try this. The compilation went smoothly before, but this issue persisted yesterday. thank you!!! Link to comment Share on other sites More sharing options...
lay Posted August 10 Author Share Posted August 10 After a compilation error occurred in khadas, I tried compiling quartz64b again, but the result was the same error!!! Link to comment Share on other sites More sharing options...
Solution Werner Posted August 10 Solution Share Posted August 10 Yes this is some generic issue. We're still investigating. Since this is an issue with the build framework please refer to the proper bug report here: https://github.com/armbian/build/issues/7054 Link to comment Share on other sites More sharing options...
