soldato Posted August 19, 2024 Posted August 19, 2024 (edited) hi all, i had a orange pi zero board that worked fine until yesterday. MY BOARD IS ORANGEPI ZERO (not 2) i upgraded the OS armbian : Linux orangepizero 6.6.31-current-sunxi #1 SMP Fri May 17 10:02:40 UTC 2024 armv7l GNU/Linux the board worked fine until the last reboot in order to test octopi startup, but before this reboot the OS was upgraded and rebooted the issue now is that the wlan0 seems to be always down i do a lot of setup but it still to remain down, i am not a very expert with these board but i am very new with this kind of issue. can anyone help me with the troubleshooting ? i can access the board via LAN (eth0) i can show some details: root@orangepizero:~# lsmod Module Size Used by xradio_wlan 110592 0 mac80211 643072 1 xradio_wlan cfg80211 606208 2 mac80211,xradio_wlan rfkill 20480 2 cfg80211 libarc4 12288 1 mac80211 sun4i_gpadc_iio 12288 0 ch341 16384 1 industrialio 57344 1 sun4i_gpadc_iio usbserial 36864 3 ch341 sun8i_thermal 12288 0 uio_pdrv_genirq 16384 0 uio 16384 1 uio_pdrv_genirq cpufreq_dt 16384 0 usb_f_acm 16384 1 u_serial 20480 3 usb_f_acm g_serial 12288 0 libcomposite 49152 2 g_serial,usb_f_acm ip_tables 20480 0 x_tables 24576 1 ip_tables autofs4 36864 2 pwrseq_simple 12288 1 sunxi 12288 0 phy_generic 16384 2 sunxi ac200_phy 12288 1 root@orangepizero:~# sudo iwlist wlan0 scan wlan0 Interface doesn't support scanning : Network is down root@orangepizero:~# nmcli dev wifi list IN-USE SSID MODE CHAN RATE SIGNAL BARS SECURITY root@orangepizero:~# ifconfig -a .................................................. wlan0: flags=4098<BROADCAST,MULTICAST> mtu 1500 ether 0a:5e:7a:3c:fa:2a txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 now i had this error but before was different: root@orangepizero:~# ifup wlan0 RTNETLINK answers: Invalid argument ifup: failed to bring up wlan0 root@orangepizero:~# rfkill list all 0: phy0: Wireless LAN Soft blocked: no Hard blocked: no the network interfaces was not touched before this issue, yesterday i only upgraded OS , python3 and octopi. i prefer don't reimage the OS..... i observed that the wlan0 MAC changes at every reboot. many thanks i pologize if i posted into orangepi zero 2 section Edited August 19, 2024 by soldato 0 Quote
SteeMan Posted August 19, 2024 Posted August 19, 2024 Board is not a supported Armbian SBC, moved to the Community Maintained forum section and reset the board tag to reflect the correct board. 2 Quote
Werner Posted August 20, 2024 Posted August 20, 2024 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
soldato Posted August 20, 2024 Author Posted August 20, 2024 i apology but for some misteryous issue i lost completly the network, using nmtui i added only the IP gateway on my wired connection and after that i lost completly the network, i also mounted the SD on a ubuntu but all seems fine. but no network. after that i reimaged a new SD card with last armbian/noble release , and wifi connection works. i need to reinstall all OctoPrint sw. without IP gateway i cannot install armbianmonitor. i think we can close this thread if i cannot resume at least the wired connection. the next steps could be to disable Network Manager , can any one has a guide to perform this task using the SD mounted on a another machine ? bye 0 Quote
robertoj Posted August 24, 2024 Posted August 24, 2024 I tried the orangepizero image from https://dl.armbian.com/orangepizero/Bookworm_current_minimal (Bookworm, Linux 6.6.44) and wifi didn't work Then I tried the image from https://armbian.tnahosting.net/archive/orangepizero/archive/Armbian_24.2.1_Orangepizero_bookworm_current_6.6.20_minimal.img.xz (bookworm, Linux 6.6.20) and wifi worked again Then I did apt update+upgrade, the kernel upgraded to 6.6.31, and the wifi connection was still working Result of armbianmonitor -u: https://paste.armbian.com/irowedahuc ^ In case someone needs a reference of how it should work I will try the 6.6.44 image again v Below is the result of the Bookworm 6.6.44 image https://paste.armbian.com/odeyapojal Also: sudo iwlist wlan0 scan wlan0 Interface doesn't support scanning : Network is down It is also missing armbian-config: sudo apt install armbian-config [sudo] password for roberto: Reading package lists... Done Building dependency tree... Done Reading state information... Done E: Unable to locate package armbian-config Then, when I tried the image from https://dl.armbian.com/orangepizero/Noble_current_server (on August 24), then Wifi works armbian-config and nmtui are included in this image, and it has a new option: Radio Here's the result of armbianmonitor -u : https://paste.armbian.com/erofizifam I will continue working with Ubuntu Server, instead of Debian Minimal 0 Quote
SteeMan Posted August 24, 2024 Posted August 24, 2024 10 hours ago, robertoj said: Minimal Minimal really means minimal. So it doesn't come installed with even basic things like Armbian-config. The minimal install is an 'expert' type build, use only if you know what you are doing and are willing to install a lot of basic things to get your system working the way you want. The standard server builds are likely what you are looking for. 0 Quote
robertoj Posted August 25, 2024 Posted August 25, 2024 I get it, that Debian Minimal comes without armbian-config, but it is the first time I can't install it with "sudo apt install armbian-config" 0 Quote
SteeMan Posted August 25, 2024 Posted August 25, 2024 What are the contents of your /etc/apt/sources.list.d/armbian.list file? 0 Quote
Werner Posted August 26, 2024 Posted August 26, 2024 Did apt update beforehand? Images do not come with pre-installed apt lists since they would be outdated the moment the image was assembled. 0 Quote
robertoj Posted August 26, 2024 Posted August 26, 2024 I think I did apt update... I will double check 0 Quote
