lay Posted September 5, 2024 Posted September 5, 2024 May I ask where to add and place the background image?? help..... 0 Quote
Werner Posted September 5, 2024 Posted September 5, 2024 background image for? boot process? desktop? If latter which one? gnome? kde? xfce? Lacking information. 0 Quote
lay Posted September 5, 2024 Author Posted September 5, 2024 desktop gnome and Enter the file system process. Could you please tell me? thank you 0 Quote
Werner Posted September 5, 2024 Posted September 5, 2024 15 minutes ago, lay said: Enter the file system process. The what? 0 Quote
lay Posted September 5, 2024 Author Posted September 5, 2024 Expert, please tell me how to add desktop background picture to "desktop gnome " 0 Quote
Solution Werner Posted September 5, 2024 Solution Posted September 5, 2024 3 hours ago, lay said: System startup logo There is no simple way to do this. Look at the code and modify. Start looking here: https://github.com/armbian/build/tree/dd6300d4cce9056eb5efa16ce3b656c16734bbe7/packages/plymouth-theme-armbian 2 hours ago, lay said: "desktop gnome " Gnome DE config is here: https://github.com/armbian/build/tree/main/config/desktop/common/environments/gnome If this is too complicated for you I suggest to book professional consultation: https://calendly.com/armbian/consultation 0 Quote
