I'm running ARMBIAN 5.25 stable with kernel 4.9.12-sunxi on my Cubietruck and I mostly use it as an AP.
I've installed the "hostapd" package from the official armbian repository and it works fine until I want to connect more than 5 wireless clients. The kernel module used is "brcmfmac" provided by the armbian-firmware package.
Is it an hardware limit and how can I bypass it if possible ?
The working default config provided with hostapd package is below:
ssid=ARMBIAN
interface=wlan0
hw_mode=g
channel=5
driver=nl80211
ctrl_interface=/var/run/hostapd
ctrl_interface_group=0
logger_syslog=0
logger_syslog_level=0
wmm_enabled=1
ieee80211n=1
wpa=2
preamble=1
wpa_psk=66eb31d2b48d19ba216f2e50c6831ee11be98e2fa3a8075e30b866f4a5ccda27
wpa_passphrase=12345678
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
macaddr_acl=0
noscan=1
#country_code=SI
#ieee80211d=1
Thanks in advance for your help,
Romain
Yes, limited within firmware. Can't do it.
Thanks a lot for the answer Igor as well as for your great work on Armbian !
Can anyone recommend a wireless USB adapter (n draft or better if possible) working out of the box to use as an AP with hostapd ?
Thanks again,
Romain
Hi Edwin,
based on your advice and compatibility matrix, I've just bought the Panda Wireless PAU06.
Thank you very much!
Romain
