MaxT Posted Friday at 05:42 PM Share Posted Friday at 05:42 PM Maybe worth trying OpenWRT - it is built with AP functionality in mind and if it works, assess whether config(s)/build options can be applied to Armbian 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted Friday at 06:36 PM Share Posted Friday at 06:36 PM 54 minutes ago, MaxT said: Maybe worth trying Its usually hardware / quality of the driver ... but ofc also "something in between". Armbian config way has been significantly improved, worth trying upcoming app: https://github.com/armbian/configng 0 Quote Link to comment Share on other sites More sharing options...
ag123 Posted Friday at 08:43 PM Share Posted Friday at 08:43 PM Imho trying OpenWRT isn't a direct 'solution' of a problem. A notion is that 'it works in A OS' and 'doesn't work in B OS' normally won't give a clue to fixing the problem in 'B OS', except for the cases of *strictly a config problem*. rather if you have A OS with a particular config that works and another A OS that has a config that doesn't work, then one'd be better comparing the 2 different configs between the 2 A OS, it would more likely find the 'config error'. in theory if it is strictly config error, then you may as well copy over the 'correct' config and it should work. my guesses as it has come this far is that it may not be simply a config problem. i.e. that there is (or at least may be) no problem with configs. there is 'something else' that cause the problem, and it may not be config. the thing is we do not know what that 'something else' is. We can't rule out hardware differences, there are different memory sizes for Orange Pi zero 3 ( 1, 1.5, 2, 4 GB) as it has not been discussed here. But even then that is just one of the possible factors. for the record, I've been using hostapd, Armbian on Orange Pi Zero 3, and it is practically my desktop WiFi hotspot, it 'just works', at least that Android connects to it flawlessly, and yes WPA2 (see prior comments) It runs for months literally without reboot and offers fast > 100 Mbps (throughput across both wifi and ethernet interfaces) WiiFi5 on 5 ghz band. And I think (or I observed) that iphones connect just fine ! (we need inputs from other iphone users who have successfully done the same that if that 'just works'. Then maybe it is easier to compare on the same basis. not easy to narrow down what that 'something else' is. For now, based on prior analysis a few comments prior (especially about the hostapd/wpa_supplicant 'discovery', perhaps rebuild the Armbian image (kernel + distribution) from source may help ! Still it is a gamble, as I do not know the root cause of it. edit: @av4625 there is one other thing, and this relates to config https://gist.github.com/ag88/de02933ba65500376d1ff48e504b1bf3 in my hostapd.conf example I specified channel=0 (that should literally should mean auto selection of channel) in actual fact, I used a specific channel # "a" simply means 5Ghz hw_mode=a # the channel to use channel=36 ieee80211ac=1 the relevant channel is selected by running sudo iw list which gives a detailed list of the frequencies / channels that can be set then simply pick a channel that is legal and that one prefers (e.g. by checking that no other AP visible is using it) and set that in the hostapd.conf as above if that is the problem, maybe it helps. it is perhaps overlooked as the assumption is that only WPA/WPA2 is the issue. 0 Quote Link to comment Share on other sites More sharing options...
MaxT Posted Friday at 10:41 PM Share Posted Friday at 10:41 PM If a feature works on the board under OS A and does not under OS B, given both are Linux based, one can rule our HW issue.By comparing kernel patches, one can rule out drivers, same with kernel configs/build options and lastly userland SWThat's all I meant.Remember, OpenWRT, DDWRT, etc. are built with networking/AP functionality in mind, have large user base using exactly feature in question and there might be hints on their forums, wiki, etc. 0 Quote Link to comment Share on other sites More sharing options...
robertoj Posted Friday at 11:03 PM Share Posted Friday at 11:03 PM I just checked the openwrt webpage. There's no mention of orange pi zero 3 working: https://openwrt.org/toh/xunlong/start The wifi chip is CDtech 20U5622 (or UWE5622) ... do you see that anywhere in openwrt? 0 Quote Link to comment Share on other sites More sharing options...
MaxT Posted Friday at 11:59 PM Share Posted Friday at 11:59 PM I just checked the openwrt webpage. There's no mention of orange pi zero 3 working: https://openwrt.org/toh/xunlong/start The wifi chip is CDtech 20U5622 (or UWE5622) ... do you see that anywhere in openwrt?See last two lineshttps://openwrt.org/toh/views/toh_single-board-computersSeems snapshots are available 0 Quote Link to comment Share on other sites More sharing options...
ag123 Posted Saturday at 05:07 AM Share Posted Saturday at 05:07 AM I'd guess that channel=36 specifier in hostapd.conf 2 comments above would likely make a difference. prior, i stated channel=0 and I'm assuming ACS (automatic channel selection). I think ACS may not be working after all, hence, it is necessary to specify the channel manually. the easiest way to list all channels and frequencies is sudo iw list and to list APs that are visible accordingly it is nmcli dev wifi or sudo iw dev wlan0 scan I think iw dev wlan0 scan and nmcli dev wifi needs to be done without hostapd or an AP (e.g. on Network Manager) running I think on Android (and/or iphone?) there are also apps available to list visible WiFi APs and their frequencies / channels even if it conflicts (e.g. 2 AP on the same channel) I'd guess it'd still work, just that there'd be 'interference' and possibly lower throughput. --- blurb: yes OpenWRT, Armbian, ... are among the earliest 3rd party open sourced implementations to run on Orange Pi Zero 3. using Armbian (vs OpenWRT) is just my personal preference, partly as it is a complete linux distribution (e.g. debian). One can run various other things in addition to simply using it as a 'router'. And that deban, ubuntu style apt update ; apt upgrade or apt install xxyy is very mature and setting up many different apps is simply a one liner apt install xxyy. And not least Ambian build framework is one of the highlights https://github.com/armbian/build one can catch up to the (bleeding) 'edge' of Linux if one wants to. another blurb, using SBC (Single board computers) as WiFi hotspot running open sourced implementations e.g Armbian, OpenWRT etc is 'very significant'. Well, these days there are dedicated 'mesh' routers, those are likely faster e.g. WiFi 6 etc (cost wise may actually be equal) but that running Armbian (etc) means one can literally customize the use including setting it up as a router / WiFi hotspot and customize the network setup to work around problems that may not be possible on 'standard' consumer box routers. And in addition running apps, e.g. file server (lan based storage) , web server with apps, stream media, databases (mysql?) etc in addition. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted Saturday at 07:23 AM Share Posted Saturday at 07:23 AM 8 hours ago, MaxT said: given both are Linux based, one can rule our HW issue. I wish this would be that simple First, all distros are (usually) re-building packages at different time, thus by default bringing different code base. That change can be small (using same main version of kernel) or big (6.1 vs. 6.10 for example). Then. Armbian adds (ATM) 436 general patches to the kernel and we add several 3rd party drivers to the kernel. We actively maintain this kernel, unlike others. Some distributions are using our kernel, while OpenWRT AFAIK not. Which means they use some version of mainline Linux kernel with their own patches. Their focus is networking (protocols), so I would assume they are fixing those things. I doubt they are doing anything related to this hardware (wifi chip) besides adding device tree (if not yet in mainline). Fixing wireless drivers in its core is done by very few people that are not tied to any distribution in particular https://github.com/morrownr/USB-WiFi https://github.com/kimocoder ... experience will be different, especially in area of this particular hardware. 0 Quote Link to comment Share on other sites More sharing options...
Michael Robinson Posted Sunday at 03:36 AM Share Posted Sunday at 03:36 AM https://github.com/garywill/linux-router 1 Quote Link to comment Share on other sites More sharing options...
av4625 Posted Monday at 07:39 PM Author Share Posted Monday at 07:39 PM Lots of replies here, thanks everyone! I tried specifying the channel, but it didn't help. I also tried 5GHz instead of 2.4GHz "just incase", but that didn't help either. You can see my config here: cat /etc/NetworkManager/system-connections/access_point.nmconnection [connection] id=access_point uuid=4eba9c88-d36f-40bb-a740-a9eeb903ca75 type=wifi interface-name=wlan0 mdns=2 timestamp=1728918559 [wifi] band=a channel=36 mode=ap ssid=TEST_TEST [wifi-security] key-mgmt=wpa-psk psk=password [ipv4] method=shared [ipv6] addr-gen-mode=default method=auto [proxy] One thing I noticed is that wpa_supplicant is showing UNKNOWN as the key management type which I thought was weird. sudo wpa_cli status Selected interface 'wlan0' bssid=44:fa:6d:94:c1:36 freq=5180 ssid=TEST_TEST id=0 mode=AP pairwise_cipher=CCMP+TKIP group_cipher=TKIP key_mgmt=UNKNOWN wpa_state=COMPLETED ip_address=10.42.0.1 p2p_device_address=46:fa:6d:94:c1:36 address=44:fa:6d:94:c1:36 uuid=82ce0d53-c98a-5bf8-b8a7-89759b194923 Haven't had time to try anything else yet 0 Quote Link to comment Share on other sites More sharing options...
jimg Posted 11 hours ago Share Posted 11 hours ago (edited) FWIW, here's the ansible script I use to set up the Orange Pi Zero 2W we use as our home wireless access point running in 5 Ghz (AC) mode. It is currently on Armbian 24.11 Debian Bookworm using kernel 6.6.54. This should work on an Orange Pi Zero 3 since it uses the same CPU and wifi chip. Note I am using systemd-networkd that netplan uses by default in Armbian's minimal/IOT images, not nmcli. --- - name: Install networking packages apt: name: - hostapd - dnsmasq state: present # setup access point - name: configure dnsmasq file: src: dnsmasq.conf dest: /etc/dnsmasq.conf mode: 0644 tags: - dnsmasq - name: create dnsmasq.service.d directory if non-existent file: path: /etc/systemd/system/dnsmasq.service.d recurse: true state: directory tags: - dnsmasq - name: copy fix for systemd-resolved conflict when: - ansible_facts.services['systemd-networkd.service'] is defined - ansible_facts.services['systemd-networkd.service']['status'] == 'enabled' copy: src: systemd-resolved-fix.conf dest: /etc/systemd/system/dnsmasq.service.d/systemd-resolved-fix.conf mode: 0644 tags: - dnsmasq - name: activate dnsmasq service command: systemctl enable dnsmasq.service tags: - dnsmasq - name: Set up IPv4 forwarding ansible.builtin.copy: src: routed-ap.conf dest: /etc/sysctl.d/10-routed-ap.conf mode: 0644 - name: copy hostapd.conf file: src: hostapd.conf dest: /etc/hostapd/hostapd.conf mode: 0644 tags: - hostapd - name: copy hostapd.service file: src: hostapd.service dest: /etc/systemd/system/hostapd.service mode: 0644 tags: - hostapd # hostapd is masked by default after installation - name: unmask hostapd.service command: systemctl unmask hostapd.service tags: - hostapd - name: activate hostapd service command: systemctl enable hostapd.service tags: - hostapd Here's the /etc/dnsmasq.conf file: # disables dnsmasq reading any other files like /etc/resolv.conf # for nameservers no-resolv #IGNORE_RESOLVCONF=yes #DNSMASQ_EXCEPT="lo" interface=wlan0 log-queries log-facility=/var/log/dnsmasq.log addn-hosts=/etc/hosts no-dhcp-interface=lo domain-needed bogus-priv dhcp-range=10.10.1.50,10.10.1.199,12h dhcp-option=3,10.10.1.1 server=1.1.1.1 The /etc/systemd/system/dnsmasq.service.d/systemd-resolved-fix.conf file mentioned in the script stops systemd-resolved when dnsmasq is started so it doesn't conflict with dnsmasq: [Unit] After=systemd-resolved.service [Service] ExecStartPre=/usr/bin/systemctl stop systemd-resolved.service ExecStartPost=/usr/bin/systemctl start systemd-resolved.service The /etc/sysctl.d/10-routed-ap.conf file enables iPv4 and IPv6 address forwarding. This is required since hostapd is running in routed mode, not bridged: # https://www.raspberrypi.org/documentation/configuration/wireless/access-point-routed.md # Enable IPv4 routing net.ipv4.ip_forward=1 # Enable IPv6 routing #net.ipv6.conf.default.forwarding=1 The /etc/hostapd/hostapd.conf file, configured for the wifi chips' capabilities: ssid=<YOUR SSID GOES HERE> interface=wlan0 hw_mode=g channel=40 driver=nl80211 logger_syslog=0 logger_syslog_level=0 wpa=2 preamble=1 # Wifi Multi-Media support, also required for full speed on 802.11n/ac/ax wmm_enabled=1 wpa_passphrase=<YOUR PASSWORD GOES HERE> wpa_key_mgmt=WPA-PSK wpa_pairwise=TKIP rsn_pairwise=CCMP auth_algs=1 macaddr_acl=0 ## IEEE 802.11n ieee80211n=1 ht_capab=[LDPC][HT40-][HT40+][SHORT-GI-20][SHORT-GI-40][RX-STBC1] country_code=US ieee80211d=1 ## IEEE 802.11n ## IEEE 802.11a hw_mode=a ## IEEE 802.11a ## IEEE 802.11ac ieee80211ac=1 vht_capab=[MAX-MPDU-7991][RXLDPC][SHORT-GI-80][SU-BEAMFORMEE][MU-BEAMFORMEE][VHT-TXOP-PS][MAX-A-MPDU-LEN-EXP3] vht_oper_chwidth=1 vht_oper_centr_freq_seg0_idx=42 ## IEEE 802.11ac # controlling enabled ctrl_interface=/var/run/hostapd ctrl_interface_group=0 The /etc/systemd/system/hostapd.service file: [Unit] Description=Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator Documentation=man:hostapd(8) After=network.target Before=dnsmasq.service ConditionFileNotEmpty=/etc/hostapd/hostapd.conf #Wants=dhcpcd.service #Before=network.target dhcpcd.service wpa_supplicant.service [Service] Type=forking PIDFile=/run/hostapd.pid Restart=on-failure RestartSec=2 Environment=DAEMON_CONF=/etc/hostapd/hostapd.conf EnvironmentFile=-/etc/default/hostapd ExecReload=/bin/kill -s HUP $MAINPID ExecStartPre=/usr/bin/ip link set wlan0 down ExecStartPre=/usr/bin/ip address flush dev wlan0 ExecStartPre=/usr/bin/ip link set wlan0 up ExecStartPre=/usr/bin/ip addr add 10.10.1.1/24 dev wlan0 ExecStart=/usr/sbin/hostapd -B -P /run/hostapd.pid $DAEMON_OPTS $DAEMON_CONF [Install] WantedBy=multi-user.target Hope this helps. Edited 11 hours ago by jimg 0 Quote Link to comment Share on other sites More sharing options...
av4625 Posted 4 hours ago Author Share Posted 4 hours ago I downloaded the latest image which has the same versions as you. This seemed to get a little bit further. I set it up manually using the exact files above just changing ssid and password as I havent used ansible before and couldn't get it to work. I am able to select the AP and type in the password and it seems to connect. But I get a no Wi-Fi symbol, this is no drama as I only want to be able to talk to the OPi using this hotspot to access a server it hosts. But, when I look at the connection, it doesn't seem to have a router/gateway IP. On my OPi Zero LTS where the hotspot works, I can SSH to the gateway IP (10.42.0.1 by default). Another weird thing the IP that my Mac got after connecting started with 169, I would have expected this to be in the range specified in /etc/dnsmasq.conf (dhcp-range=10.10.1.50,10.10.1.199,12h). I'm not sure if its just how this specific hotspot is configured but I guess yours works better than this. I dunno why, but I find hostapd and dnsmasq a lot more complicated and harder to understand. But I wonder, because this hotspot seemed to accept a password and my Mac showed it as WPA2/WPA3, is it just an option that needs to be set for the nmcli hotspot. Because without a password it works perfectly like I expect and I can SSH to the gateway IP etc etc. I also tried my own nmcli commands on the new image "just incase" but no luck. 0 Quote Link to comment Share on other sites More sharing options...
ag123 Posted 2 hours ago Share Posted 2 hours ago if this is based on hostapd try journalctl -u hostapd to check the connect logs, normally successful connection attempts is quite 'intuitive' e.g. that there is normally a WPA / authentication related message other things that possibly matters include ip address, that should be provided by dhcp (e.g. dnsmasq) dns server, i think some os (e.g. android at least) tries to connect to some internet web sites (google?) and complains that there is no internet if is not accessible. if there is after all no internet, you may need to run a dns to resolve the ap itself if you are accessing it via domain names. For accessing the host itself, i'm not too sure if dnsmasq can work as dns and resolve its own domain. Otherwise, accessing the host would likely need to be based on ip address. alternatively, I'd think install and configure avahi (MDNS) which may help to resolve the ap itself as host.local (e.g. orangepizero3.local) interfaces and routing, we normally assume that it is configured and working? but nevertheless it may help to check e.g. ip link ip -4 add ip route 0 Quote Link to comment Share on other sites More sharing options...
