How to completely disable display subsystem on OPi zero ?
Go to solution Solved by robertoj,
I want to completely disable display subsystem on Orange Pi Zero LTS (Debian 12 (Bookworm) minimal/IoT build 1 oct 2024).
I blacklisted the GPU modules (lima, gpu_sched, drm_shmem_helper), but i can't find a way to disable sun4i-drm. Is there a way to disable it completely w/o recompiling the kernel?
  • Solution
In armbianenv.txt, erase the overlay “tve” (abbreviation of tv signal encoder)
if you don’t use any analog outputs, can the pins be used as GPIO?
