October 20, 20242 yr Hi guys I have been at this for a week now. I came up with an idea to use MXQ pro tv box for my 3d printers as I am running klipper. Keep in mind I have klipper installed and it works perfect. But in order to make things easier I need wifi the internal ethernet is working perfect. I have a few beaglebone blacks that i used for another project I used wifi dongles with them and tried to install the driver on the rk3228 box but keeps on getting the following error. v24.11 rolling for rk322x-box running Armbian Linux 6.11.4-edge-rockchip Packages: Debian stable (bookworm) Support: for advanced users (rolling release) IP addresses: (LAN) IPv4: 192.168.0.153 IPv6: fe80::30e0:63ff:fed2:6c71 (WAN) 192.143.2.188 Performance: Load: 6% Up time: 2 min Memory usage: 13% of 977M CPU temp: 59°C Usage of /: 70% of 7.0G Commands: System config : sudo armbian-config System monitor : htop Last login: Sun Oct 20 19:51:29 2024 from 192.168.0.148 johan@rk322x-box:~$ sudo apt-get install build-essential git dkms linux-headers-$(uname -r) [sudo] password for johan: Reading package lists... Done Building dependency tree... Done Reading state information... Done E: Unable to locate package linux-headers-6.11.4-edge-rockchip E: Couldn't find any package by glob 'linux-headers-6.11.4-edge-rockchip' E: Couldn't find any package by regex 'linux-headers-6.11.4-edge-rockchip' johan@rk322x-box:~$ This is the link I have always used to install the wifi dongle driver. https://github.com/kelebek333/rtl8188fu I'm not new to armbian but also not a pro so I have no idea hoe to install other drivers from github. Any assistance will be much appreciated
October 21, 20242 yr 17 часов назад, JOHAN VAN DER MERWE сказал: linux-headers-$(uname -r) This is an incorrect package name. Valid: linux-image-${BRANCH}-${LINUXFAMALY} BRANCH -> legacy,current or edge LINUXFAMALY -> sunxi,sunxi64,rockcip-rk3588 ... Example: leo@bananapif3:~$ echo "$(LC_ALL=C apt search linux-image | grep install)" ... linux-image-legacy-spacemit/now 24.11.0-trunk riscv64 [installed,local] And search headers: leo@bananapif3:~$ echo "$(LC_ALL=C apt search linux-headers-legacy-spacemit)" ... linux-headers-legacy-spacemit/noble 24.8.2 riscv64 Armbian Linux legacy headers 6.1.15-legacy-spacemit Please note that the version of the installed kernel and the version of the headers available from the repository do not match. That's because I built the core myself. And now the headlines are my problem.
October 21, 20242 yr Author @going First of thank you for the time invested in creating such good work from my side I do appreciate it. second im not new to linux but not completely understanding how to install the headers if im not mistaken this is the command that I should run. (johan@rk322x-box:~$ echo "$(LC_ALL=C apt search linux-image | grep install)" 3rd question I have is I used multitools to make a backup of the android but its saved as .gz file when I copy that back to multitool it does not recognize the file name to install it how do I go about getting the gz file to a img file if I want to reinstall the android. Kind Regards Johan
October 21, 20242 yr Author @going ran the scrip and this is the output: johan@rk322x-box:~$ johan@rk322x-box:~$ echo "$(LC_ALL=C apt search linux-image | grep install)" WARNING: apt does not have a stable CLI interface. Use with caution in scripts. -bash: johan@rk322x-box:~$: command not found
October 21, 20242 yr I think there are no header packages for rolling release images. However you can build a set of matching packages by yourself using the build framework. Or use these I just made: https://fi.mirror.armbian.de/.testing/rk322x-box/
October 21, 20242 yr Author @Werner Thank you but please help me by explaining how to install them. PS: by the name you sound South african (Me to ) how about if you can ssh into it and just guide me ? Regards
October 21, 20242 yr Check here for business consultation/personalized support: https://www.armbian.com/contact/ I am from Germany.
October 21, 20242 yr Author @Werner Thank you for the link I will however try to Google how to install the header as this will also teach me how for future. Can I install every packagebor just one
October 21, 20242 yr 1 час назад, JOHAN VAN DER MERWE сказал: 3rd question I have is I used multitools to make a backup of the android but its saved as .gz file when I copy that back to multitool it does not recognize the file name to install it how do I go about getting the gz file to a img file if I want to reinstall the android. zcat --help zcat file-name.img.gz
October 21, 20242 yr Author @goingThanks I do have a laptop running inh linux mint will run this command on console Is that correct?
October 21, 20242 yr 26 минут назад, JOHAN VAN DER MERWE сказал: Is that correct? Yes of course! You can also redirect the output of a command to the input of another command.
October 21, 20242 yr Author @goingso onve i run that commamd will it convert the gz file to a img file?
October 21, 20242 yr 18 минут назад, JOHAN VAN DER MERWE сказал: so onve i run that commamd will it convert the gz file to a img file? And you try to do it and see the result !!! Download packages directly on the board: wget -r -l 1 --accept=deb -np https://fi.mirror.armbian.de/.testing/rk322x-box .... mkdir debs mv fi.mirror.armbian.de/.testing/rk322x-box/* debs/ rm -rf fi.mirror.armbian.de ls debs There will be 4 files in the directory: linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb sudo dpkg -i filename.deb
October 21, 20242 yr Author @going This is my output that I get. johan@rk322x-box:~$ sudo wget -r -l 1 --accept=deb -np https://fi.mirror.armbian.de/.testing/rk322x-box [sudo] password for johan: --2024-10-21 18:57:56-- https://fi.mirror.armbian.de/.testing/rk322x-box Resolving fi.mirror.armbian.de (fi.mirror.armbian.de)... 65.21.120.247, 2a01:4f9:3b:4943::2 Connecting to fi.mirror.armbian.de (fi.mirror.armbian.de)|65.21.120.247|:443... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: https://fi.mirror.armbian.de/.testing/rk322x-box/ [following] --2024-10-21 18:57:58-- https://fi.mirror.armbian.de/.testing/rk322x-box/ Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box.tmp’ fi.mirror.armbian.d [ <=> ] 3.12K --.-KB/s in 0s 2024-10-21 18:57:58 (9.36 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box.tmp’ saved [3200] Loading robots.txt; please ignore errors. --2024-10-21 18:57:58-- https://fi.mirror.armbian.de/robots.txt Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 404 Not Found 2024-10-21 18:57:58 ERROR 404: Not Found. Removing fi.mirror.armbian.de/.testing/rk322x-box.tmp since it should be rejected. --2024-10-21 18:57:58-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=N&O=A Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=A.tmp’ fi.mirror.armbian.d [ <=> ] 3.12K --.-KB/s in 0s 2024-10-21 18:57:59 (9.99 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=A.tmp’ saved [3200] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=A.tmp since it should be rejected. --2024-10-21 18:57:59-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=N&O=D Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=D.tmp’ fi.mirror.armbian.d [ <=> ] 3.14K --.-KB/s in 0s 2024-10-21 18:57:59 (9.55 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=D.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=D.tmp since it should be rejected. --2024-10-21 18:57:59-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=S&O=A Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=A.tmp’ fi.mirror.armbian.d [ <=> ] 3.14K --.-KB/s in 0s 2024-10-21 18:57:59 (12.7 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=A.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=A.tmp since it should be rejected. --2024-10-21 18:57:59-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=S&O=D Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=D.tmp’ fi.mirror.armbian.d [ <=> ] 3.14K --.-KB/s in 0.001s 2024-10-21 18:57:59 (5.20 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=D.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=D.tmp since it should be rejected. --2024-10-21 18:57:59-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=M&O=A Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=A.tmp’ fi.mirror.armbian.d [ <=> ] 3.14K --.-KB/s in 0s 2024-10-21 18:58:00 (9.15 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=A.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=A.tmp since it should be rejected. --2024-10-21 18:58:00-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=M&O=D Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=D.tmp’ fi.mirror.armbian.d [ <=> ] 3.14K --.-KB/s in 0s 2024-10-21 18:58:00 (7.63 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=D.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=D.tmp since it should be rejected. --2024-10-21 18:58:00-- https://fi.mirror.armbian.de/.testing/ Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/index.html.tmp’ fi.mirror.armbian.d [ <=> ] 8.95K --.-KB/s in 0.001s 2024-10-21 18:58:00 (11.2 MB/s) - ‘fi.mirror.armbian.de/.testing/index.html.tmp’ saved [9168] Removing fi.mirror.armbian.de/.testing/index.html.tmp since it should be rejected. --2024-10-21 18:58:00-- https://fi.mirror.armbian.de/.testing/rk322x-box/linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: 135680 (132K) [application/octet-stream] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ fi.mirror.armbian.d 100%[===================>] 132.50K 151KB/s in 0.9s 2024-10-21 18:58:01 (151 KB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ saved [135680/135680] --2024-10-21 18:58:01-- https://fi.mirror.armbian.de/.testing/rk322x-box/linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: 14350648 (14M) [application/octet-stream] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ fi.mirror.armbian.d 100%[===================>] 13.69M 2.41MB/s in 12s 2024-10-21 18:58:13 (1.18 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ saved [14350648/14350648] --2024-10-21 18:58:13-- https://fi.mirror.armbian.de/.testing/rk322x-box/linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: 26321596 (25M) [application/octet-stream] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ fi.mirror.armbian.d 100%[===================>] 25.10M 3.36MB/s in 8.2s 2024-10-21 18:58:21 (3.07 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ saved [26321596/26321596] --2024-10-21 18:58:21-- https://fi.mirror.armbian.de/.testing/rk322x-box/linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: 1348720 (1.3M) [application/octet-stream] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ fi.mirror.armbian.d 100%[===================>] 1.29M 3.73MB/s in 0.3s 2024-10-21 18:58:22 (3.73 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ saved [1348720/1348720] FINISHED --2024-10-21 18:58:22-- Total wall clock time: 26s Downloaded: 12 files, 40M in 21s (1.92 MB/s) johan@rk322x-box:~$ ls debs ls: cannot access 'debs': No such file or directory johan@rk322x-box:~$ sudo ls debs ls: cannot access 'debs': No such file or directory johan@rk322x-box:~$
October 21, 20242 yr 9 минут назад, JOHAN VAN DER MERWE сказал: sudo wget The download commands are executed on behalf of a regular user. wget -r -l 1 --accept=deb -np https://fi.mirror.armbian.de/.testing/rk322x-box mkdir debs mv fi.mirror.armbian.de/.testing/rk322x-box/* debs/ rm -rf fi.mirror.armbian.de ls debs Execute sequentially line by line.
October 21, 20242 yr Author @going Im sorry im really not trying to upset you with my minimal knowledge. I copied the .gz file to my linux desktop renamed it to tvbox and run the command. this is the output Last login: Sat Oct 19 12:08:35 2024 from 192.168.0.148 pi@pi:~$ sudo zcat file-name.img.gz [sudo] password for pi: gzip: file-name.img.gz: No such file or directory pi@pi:~$ sudo zcat tvbox.img.gz gzip: tvbox.img.gz: No such file or directory pi@pi:~$
October 21, 20242 yr Author @going okay I think im somewhere now I hope: I Cd to the desktop where the .gz file is then ran zcat tvbox.img.gz told me no such directory then ran this command zcat tvbox.gz now its running in the terminal a whole lot of things im not able to read please see pictures hope its correct.
October 21, 20242 yr Author @going Im sure by now when you see a notification you dont even want to open it but please bare with me I have tried to google but nothing came up. once I understand this I will get it right next time. wget is running and download 12 file is says it saving them in a temp folder see output in console I tried to cd in it but says no such file directory I really want to install the headers to get the wifi up and running please look at the complete terminal and tell me what and where im doing it wrong. im further than a while back but stuck at sudo dpkg -i file name johan@rk322x-box:~$ sudo wget -r -l 1 --accept=deb -np https://fi.mirror.armbian.de/.testing/rk322x-box [sudo] password for johan: --2024-10-21 19:57:49-- https://fi.mirror.armbian.de/.testing/rk322x-box Resolving fi.mirror.armbian.de (fi.mirror.armbian.de)... 65.21.120.247, 2a01:4f9:3b:4943::2 Connecting to fi.mirror.armbian.de (fi.mirror.armbian.de)|65.21.120.247|:443... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: https://fi.mirror.armbian.de/.testing/rk322x-box/ [following] --2024-10-21 19:57:50-- https://fi.mirror.armbian.de/.testing/rk322x-box/ Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box.tmp’ fi.mirror.armbian.de/.testing/rk322x-box. [ <=> ] 3.12K --.-KB/s in 0s 2024-10-21 19:57:50 (6.66 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box.tmp’ saved [3200] Loading robots.txt; please ignore errors. --2024-10-21 19:57:50-- https://fi.mirror.armbian.de/robots.txt Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 404 Not Found 2024-10-21 19:57:51 ERROR 404: Not Found. Removing fi.mirror.armbian.de/.testing/rk322x-box.tmp since it should be rejected. --2024-10-21 19:57:51-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=N&O=A Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=A.tmp’ fi.mirror.armbian.de/.testing/rk322x-box/ [ <=> ] 3.12K --.-KB/s in 0s 2024-10-21 19:57:51 (7.84 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=A.tmp’ saved [3200] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=A.tmp since it should be rejected. --2024-10-21 19:57:51-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=N&O=D Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=D.tmp’ fi.mirror.armbian.de/.testing/rk322x-box/ [ <=> ] 3.14K --.-KB/s in 0.001s 2024-10-21 19:57:51 (5.13 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=D.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=D.tmp since it should be rejected. --2024-10-21 19:57:51-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=S&O=A Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=A.tmp’ fi.mirror.armbian.de/.testing/rk322x-box/ [ <=> ] 3.14K --.-KB/s in 0.001s 2024-10-21 19:57:52 (5.31 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=A.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=A.tmp since it should be rejected. --2024-10-21 19:57:52-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=S&O=D Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=D.tmp’ fi.mirror.armbian.de/.testing/rk322x-box/ [ <=> ] 3.14K --.-KB/s in 0s 2024-10-21 19:57:52 (7.51 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=D.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=D.tmp since it should be rejected. --2024-10-21 19:57:52-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=M&O=A Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=A.tmp’ fi.mirror.armbian.de/.testing/rk322x-box/ [ <=> ] 3.14K --.-KB/s in 0s 2024-10-21 19:57:52 (6.13 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=A.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=A.tmp since it should be rejected. --2024-10-21 19:57:52-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=M&O=D Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=D.tmp’ fi.mirror.armbian.de/.testing/rk322x-box/ [ <=> ] 3.14K --.-KB/s in 0s 2024-10-21 19:57:53 (9.37 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=D.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=D.tmp since it should be rejected. --2024-10-21 19:57:53-- https://fi.mirror.armbian.de/.testing/ Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/index.html.tmp’ fi.mirror.armbian.de/.testing/index.html. [ <=> ] 8.95K --.-KB/s in 0.001s 2024-10-21 19:57:53 (17.4 MB/s) - ‘fi.mirror.armbian.de/.testing/index.html.tmp’ saved [9168] Removing fi.mirror.armbian.de/.testing/index.html.tmp since it should be rejected. --2024-10-21 19:57:53-- https://fi.mirror.armbian.de/.testing/rk322x-box/linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: 135680 (132K) [application/octet-stream] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ fi.mirror.armbian.de/.testing/rk322x-box/ 100%[=====================================================================================>] 132.50K 185KB/s in 0.7s 2024-10-21 19:57:54 (185 KB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ saved [135680/135680] --2024-10-21 19:57:54-- https://fi.mirror.armbian.de/.testing/rk322x-box/linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: 14350648 (14M) [application/octet-stream] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ fi.mirror.armbian.de/.testing/rk322x-box/ 100%[=====================================================================================>] 13.69M 2.25MB/s in 10s 2024-10-21 19:58:04 (1.34 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ saved [14350648/14350648] --2024-10-21 19:58:04-- https://fi.mirror.armbian.de/.testing/rk322x-box/linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: 26321596 (25M) [application/octet-stream] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ fi.mirror.armbian.de/.testing/rk322x-box/ 100%[=====================================================================================>] 25.10M 3.11MB/s in 8.7s 2024-10-21 19:58:13 (2.88 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ saved [26321596/26321596] --2024-10-21 19:58:13-- https://fi.mirror.armbian.de/.testing/rk322x-box/linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: 1348720 (1.3M) [application/octet-stream] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ fi.mirror.armbian.de/.testing/rk322x-box/ 100%[=====================================================================================>] 1.29M 3.35MB/s in 0.4s 2024-10-21 19:58:14 (3.35 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ saved [1348720/1348720] FINISHED --2024-10-21 19:58:14-- Total wall clock time: 25s Downloaded: 12 files, 40M in 20s (2.01 MB/s) johan@rk322x-box:~$ sudo mkdir debs mkdir: cannot create directory ‘debs’: File exists johan@rk322x-box:~$ sudo mv fi.mirror.armbian.de/.testing/rk322x-box/* debs/ johan@rk322x-box:~$ sudo rm -rf fi.mirror.armbian.de johan@rk322x-box:~$ sudo ls debs linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb johan@rk322x-box:~$ sudo dpkg -i linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb dpkg: error: cannot access archive 'linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb': No such file or directory johan@rk322x-box:~$ sudo dpkg -i linux-headers-edge-rockchip_24.11.0-trunk_armhf __6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb dpkg: error: cannot access archive 'linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb': No such file or directory johan@rk322x-box:~$ ls debs linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H 5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb johan@rk322x-box:~$ sudo dpkg -i linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb dpkg: error: cannot access archive 'linux-dtb-edge-rockchip_24.11.0-trunk_armhf _6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb': No such file or directory johan@rk322x-box:~$
October 22, 20242 yr Author @Werner @going Hi buddy i have done the exactly line by line that you have said I should run. however im stuck at the last part where I should run sudo dpkg -i it says no such file or directory. see terminal output. FINISHED --2024-10-22 14:17:35-- Total wall clock time: 1m 54s Downloaded: 12 files, 40M in 1m 48s (380 KB/s) johan@rk322x-box:~$ mkdir debs mkdir: cannot create directory ‘debs’: File exists johan@rk322x-box:~$ mv fi.mirror.armbian.de/.testing/rk322x-box/* debs/ mv: replace 'debs/linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb', overriding mode 0644 (rw-r--r--)? mv: replace 'debs/linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb', overriding mode 0644 (rw-r--r--)? yes mv: replace 'debs/linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb', overriding mode 0644 (rw-r--r--)? ^C johan@rk322x-box:~$ rm -rf fi.mirror.armbian.de johan@rk322x-box:~$ ls debs linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb johan@rk322x-box:~$ sudo dpkg -i linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb [sudo] password for johan: dpkg: error: cannot access archive 'linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb': No such file or directory johan@rk322x-box:~$ sudo dpkg -i linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb dpkg: error: cannot access archive 'linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb': No such file or directory
October 22, 20242 yr Author @going can you maybe tell me if there is a legacy img for the rk322x thanks
October 22, 20242 yr Author @MaxT thank you this helped: But seems there's a conflict of interest see output johan@rk322x-box:~/debs$ sudo dpkg -i linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb dpkg: regarding linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb containing linux-libc-dev-edge-rockchip:armhf: linux-libc-dev-edge-rockchip conflicts with linux-libc-dev linux-libc-dev:armhf (version 6.8.0-47.47) is present and installed. dpkg: error processing archive linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb (--install): conflicting packages - not installing linux-libc-dev-edge-rockchip:armhf Errors were encountered while processing: linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb
October 22, 20242 yr Guess conflicted packages should be removed first.These are quite basic Linux matters, probably worth googling first for alike.
October 22, 20242 yr @JOHAN VAN DER MERWE Today, when I reread what I wrote for you, I realized that I was wrong. I did not understand your level of knowledge of Linux commands and the ability to use the system help. I apologize. Now again and in order: filename.gz - The gzip archive and the command of the same name for operations with files of this archiver. Team Help: gzip --help Extract files from the archive: gzip -dk filename.img.gz Unzip, that is, the files will be extracted from the archive and the archive will be deleted: gzip -d filename.img.gz zcat - Uncompress FILEs to standard output. The output of this command is used as the input for another command: zcat filename.img.gz | another-program For some reason, I thought that's what you need. filename.img.gz - This always implies the path to the file. You seem to have figured out the dpkg command. You don't have to install this file: linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb For you, the difference between the system package and this one doesn't matter. With respect
October 22, 20242 yr Author @going Thank you so much for the indepth explanation I will gove it a go tonight again. My level of linux especially command is very beginners I have always just used linux to install klipper for my 3d printers but I do believe with time it will come and I will understand it. I have been a Windows user all my life and this is a whole new venture
October 22, 20242 yr Author @going okay okay what am I doing why cant I get this im thinking of quitting. But thats not me managed to run dpkg and this was the outcome. FINISHED --2024-10-22 20:22:13-- Total wall clock time: 37s Downloaded: 12 files, 40M in 32s (1.26 MB/s) johan@rk322x-box:~/debs$ mkdir debs johan@rk322x-box:~/debs$ mv fi.mirror.armbian.de/.testing/rk322x-box/* debs/ johan@rk322x-box:~/debs$ rm -rf fi.mirror.armbian.de johan@rk322x-box:~/debs$ ls debs linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb johan@rk322x-box:~/debs$ cd debs johan@rk322x-box:~/debs/debs$ sudo dpkg -i linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Selecting previously unselected package linux-headers-edge-rockchip. (Reading database ... 152034 files and directories currently installed.) Preparing to unpack linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb ... Armbian 'linux-headers-edge-rockchip' for '6.11.4-edge-rockchip': 'preinst' starting. Armbian 'linux-headers-edge-rockchip' for '6.11.4-edge-rockchip': 'preinst' finishing. Unpacking linux-headers-edge-rockchip (24.11.0-trunk) ... Setting up linux-headers-edge-rockchip (24.11.0-trunk) ... Armbian 'linux-headers-edge-rockchip' for '6.11.4-edge-rockchip': 'postinst' starting. Compiling kernel-headers tools (6.11.4-edge-rockchip) using 4 CPUs - please wait ... HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o HOSTCC scripts/kconfig/confdata.o HOSTCC scripts/kconfig/expr.o LEX scripts/kconfig/lexer.lex.c YACC scripts/kconfig/parser.tab.[ch] HOSTCC scripts/kconfig/lexer.lex.o HOSTCC scripts/kconfig/menu.o HOSTCC scripts/kconfig/parser.tab.o HOSTCC scripts/kconfig/preprocess.o HOSTCC scripts/kconfig/symbol.o HOSTCC scripts/kconfig/util.o HOSTLD scripts/kconfig/conf * * Restart config... * * * Kernel Features * Symmetric Multi-Processing (SMP) [Y/n/?] y Allow booting SMP kernel on uniprocessor systems (SMP_ON_UP) [Y/n/?] y Support cpu topology definition (ARM_CPU_TOPOLOGY) [Y/n/?] y Multi-core scheduler support (SCHED_MC) [N/y/?] n SMT scheduler support (SCHED_SMT) [N/y/?] n Architected timer support (HAVE_ARM_ARCH_TIMER) [Y/?] y Multi-Cluster Power Management (MCPM) [N/y/?] n big.LITTLE support (Experimental) (BIG_LITTLE) [N/y/?] n Memory split 1. 3G/1G user/kernel split (VMSPLIT_3G) > 2. 3G/1G user/kernel split (for full 1G low memory) (VMSPLIT_3G_OPT) 3. 2G/2G user/kernel split (VMSPLIT_2G) 4. 1G/3G user/kernel split (VMSPLIT_1G) choice[1-4?]: 2 Maximum number of CPUs (2-32) (NR_CPUS) [4] 4 Support for hot-pluggable CPUs (HOTPLUG_CPU) [Y/?] y Support for the ARM Power State Coordination Interface (PSCI) (ARM_PSCI) [Y/n/?] y Timer frequency 1. 100 Hz (HZ_100) 2. 200 Hz (HZ_200) > 3. 250 Hz (HZ_250) 4. 300 Hz (HZ_300) 5. 500 Hz (HZ_500) 6. 1000 Hz (HZ_1000) choice[1-6?]: 3 Compile the kernel in Thumb-2 mode (THUMB2_KERNEL) [N/y/?] n Runtime patch udiv/sdiv instructions into __aeabi_{u}idiv() (ARM_PATCH_IDIV) [Y/n/?] y High Memory Support (HIGHMEM) [Y/n/?] y Allocate 2nd-level pagetables from highmem (HIGHPTE) [N/y/?] n Enable privileged no-access (ARM_PAN) [Y/n/?] y Use PLTs to allow module memory to spill over into vmalloc area (ARM_MODULE_PLTS) [Y/n/?] y Order of maximal physically contiguous allocations (ARCH_FORCE_MAX_ORDER) [11] 11 Use kernel mem{cpy,set}() for {copy_to,clear}_user() (UACCESS_WITH_MEMCPY) [N/y/?] n Enable paravirtualization code (PARAVIRT) [N/y/?] n Paravirtual steal time accounting (PARAVIRT_TIME_ACCOUNTING) [N/y/?] n Xen guest support on ARM (XEN) [N/y/?] n Use a unique stack canary value for each task (STACKPROTECTOR_PER_TASK) [Y/n/?] (NEW) * * Memory initialization * Initialize kernel stack variables at function entry > 1. no automatic stack variable initialization (weakest) (INIT_STACK_NONE) 2. pattern-init everything (strongest) (INIT_STACK_ALL_PATTERN) (NEW) 3. zero-init everything (strongest and safest) (INIT_STACK_ALL_ZERO) (NEW) choice[1-3?]: Enable heap memory zeroing on allocation by default (INIT_ON_ALLOC_DEFAULT_ON) [N/y/?] n Enable heap memory zeroing on free by default (INIT_ON_FREE_DEFAULT_ON) [N/y/?] n Enable register zeroing on function exit (ZERO_CALL_USED_REGS) [N/y/?] n # # configuration written to .config # SYNC include/config/auto.conf.cmd HOSTCC scripts/dtc/dtc.o HOSTCC scripts/dtc/flattree.o HOSTCC scripts/dtc/fstree.o HOSTCC scripts/dtc/data.o HOSTCC scripts/dtc/livetree.o HOSTCC scripts/dtc/treesource.o HOSTCC scripts/dtc/srcpos.o HOSTCC scripts/dtc/checks.o HOSTCC scripts/dtc/util.o LEX scripts/dtc/dtc-lexer.lex.c YACC scripts/dtc/dtc-parser.tab.[ch] HOSTCC scripts/dtc/libfdt/fdt.o HOSTCC scripts/dtc/libfdt/fdt_ro.o HOSTCC scripts/dtc/libfdt/fdt_wip.o HOSTCC scripts/dtc/libfdt/fdt_sw.o HOSTCC scripts/dtc/libfdt/fdt_rw.o HOSTCC scripts/dtc/libfdt/fdt_strerror.o HOSTCC scripts/dtc/libfdt/fdt_empty_tree.o HOSTCC scripts/dtc/libfdt/fdt_addresses.o HOSTCC scripts/dtc/libfdt/fdt_overlay.o HOSTCC scripts/dtc/fdtoverlay.o HOSTCC scripts/dtc/dtc-lexer.lex.o HOSTCC scripts/dtc/dtc-parser.tab.o HOSTLD scripts/dtc/fdtoverlay HOSTLD scripts/dtc/dtc HOSTCC scripts/kallsyms HOSTCC scripts/sorttable HOSTCC scripts/asn1_compiler CC scripts/mod/empty.o HOSTCC scripts/mod/mk_elfconfig CC scripts/mod/devicetable-offsets.s UPD scripts/mod/devicetable-offsets.h MKELF scripts/mod/elfconfig.h HOSTCC scripts/mod/modpost.o HOSTCC scripts/mod/file2alias.o HOSTCC scripts/mod/sumversion.o HOSTCC scripts/mod/symsearch.o HOSTLD scripts/mod/modpost MODPOST scripts/mod/Module.symvers Done compiling kernel-headers tools (6.11.4-edge-rockchip). Done compiling kernel-headers tools (6.11.4-edge-rockchip). And this is still my output johan@rk322x-box:~$ sudo apt-get install build-essential git dkms linux-headers-$(uname -r) git clone https://github.com/kelebek333/rtl8188fu sudo dkms install ./rtl8188fu sudo cp ./rtl8188fu/firmware/rtl8188fufw.bin /lib/firmware/rtlwifi/ [sudo] password for johan: Reading package lists... Done Building dependency tree... Done Reading state information... Done E: Unable to locate package linux-headers-6.11.0-edge-rockchip E: Couldn't find any package by glob 'linux-headers-6.11.0-edge-rockchip' E: Couldn't find any package by regex 'linux-headers-6.11.0-edge-rockchip' fatal: destination path 'rtl8188fu' already exists and is not an empty directory. Error! Your kernel headers for kernel 6.11.0-edge-rockchip cannot be found at /lib/modules/6.11.0-edge-rockchip/build or /lib/modules/6.11.0-edge-rockchip/source. Please install the linux-headers-6.11.0-edge-rockchip package or use the --kernelsourcedir option to tell DKMS where it's located.
October 22, 20242 yr 4 минуты назад, JOHAN VAN DER MERWE сказал: sudo apt-get install build-essential git dkms Just this command. You have already install the headers.
October 22, 20242 yr 13 минут назад, JOHAN VAN DER MERWE сказал: linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb These three packages must be installed. Then reboot.
