Jason Rogers Posted July 10, 2017 Share Posted July 10, 2017 Any advice for building for the H5 flavor of the Zero Plus? I am not new to kernal compiling or embedded systems dev but am rather new to compiling linux kernals FOR embedded systems. Currently using the H5 image from here: https://www.armbian.com/orange-pi-zero-2-h5/ but there is no easy option to target this board when building from source. Link to comment Share on other sites More sharing options...
Igor Posted July 10, 2017 Share Posted July 10, 2017 10 hours ago, Jason Rogers said: but there is no easy option to target this board when building from source. Add EXPERT="yes" parameter to compile.sh and you will be able to make WIP images & kernels. 2 Link to comment Share on other sites More sharing options...
Jason Rogers Posted July 10, 2017 Author Share Posted July 10, 2017 7 hours ago, Igor said: Add EXPERT="yes" parameter to compile.sh and you will be able to make WIP images & kernels. Perfect, much appreciated. Link to comment Share on other sites More sharing options...
