cibomato Posted July 16, 2017 Share Posted July 16, 2017 Hi, haven't touched my system for quite a long time, now I'm running into problems while trying to uprade system: Err http://apt.armbian.com trusty/main armhf Packages 404 Not Found ... W: Failed to fetch http://apt.armbian.com/dists/trusty/main/binary-armhf/Packages: 404 Not Found W: Failed to fetch http://nginx.org/packages/mainline/ubuntu/dists/trusty/nginx/binary-armhf/Packages: 404 Not Found [IP: 95.211.80.227 80] E: Some index files failed to download. They have been ignored, or old ones used instead. E: Couldn't rebuild package cache aptitude upgrade The following packages will be upgraded: linux-trusty-root-next-cubietruck 1 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 363 kB of archives. After unpacking 0 B will be used. Do you want to continue? [Y/n/?] WARNING: untrusted versions of the following packages will be installed! Untrusted packages could compromise your system's security. You should only proceed with the installation if you are certain that this is what you want to do. linux-trusty-root-next-cubietruck Do you want to ignore this warning and proceed anyway? To continue, enter "Yes"; to abort, enter "No": Yes Err http://apt.armbian.com/ trusty/main linux-trusty-root-next-cubietruck armhf 5.23 404 Not Found 0% [Working]E: Failed to fetch http://apt.armbian.com/pool/main/l/linux-trusty-root-next-cubietruck/linux-trusty-root-next-cubietruck_5.23_armhf.deb: 404 Not Found Any idea? Thanks in advance and best regards, Jochen Link to comment Share on other sites More sharing options...
cibomato Posted July 16, 2017 Author Share Posted July 16, 2017 Maybe I'll just do a whole new setup with latest image... Link to comment Share on other sites More sharing options...
Igor Posted July 17, 2017 Share Posted July 17, 2017 Nothing is wrong - we don't make updates for Ubuntu Trusty since some time. Upgrading to Xenial or better installing new Xenial image is the way to go. Link to comment Share on other sites More sharing options...
cibomato Posted July 17, 2017 Author Share Posted July 17, 2017 Hi Igor, thanks for your answer. Upgrade to Xenial didn't work either but now I've set up a whole new system image. Cheers, Jochen 1 Link to comment Share on other sites More sharing options...
