November 19, 20241 yr It was the only image I could get working. The 25.02 doesn't boot, the older versions from the archive 23.8.1 don't work either for some reason. Unfortunately I deleted the image and the rolling release moved on to 25.02.
November 19, 20241 yr 20 minutes ago, ArmOnJetson said: the older versions from the archive 23.8.1 don't work either for some reason. Unfortunately I deleted the image Try here: https://rsync.armbian.com/oldarchive/ We can't possibly maintain this further, sorry.
November 19, 20241 yr Author I understand that, it's just that the release from 3 weeks ago: 24.11.0-trunk.351 was working fine on the jetson nano. I just deleted the image and upgraded to 25.02 by accident. So I was wondering, if someone still had an image saved somewhere.
November 21, 20241 yr On 11/19/2024 at 2:58 PM, ArmOnJetson said: it's just that the release from 3 weeks ago: 24.11.0-trunk.351 was working fine on the jetson nano We are cleaning those builds as they have very little value. But you were lucky: https://github.com/armbian/community/releases/tag/24.11.0-trunk.351
April 3, 20251 yr Thank you for the github release link Igor, and bringing attention to the issue ArmOnJetson! Using 24.11.0-trunk.351 also solved my boot issue (originally I tried with 25.5.0 -- which was leading to a black screen after the Nvidia logo).
October 23, 20251 yr Can I still find the image somewhere? I would like to run Armbian on my Jetson Nano 2 GB, but Armbian_community_25.11.0-trunk.367_Jetson-nano_trixie_current_6.12.54_minimal.img and older images won't boot. I have tried images repeatedly over the past six weeks, but none of them will boot. It would be a shame if the Jetson Nano 2 GB ended up as electronic waste.
November 7, 2025Nov 7 Well, the source code is still on github so you could try building it. I can't find that tag in `armbian/build`, but did find `v24.11.0-trunk.303` It does build [I guessed at jammy, maybe it should be noble] time ./compile.sh build BOARD=jetson-nano BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes RELEASE=jammy KERNEL_CONFIGURE=no KERNEL_GIT=full ARTIFACT_IGNORE_CACHE=yes [🐳|🌱] Fast-moving file to output/images [ -> Armbian-unofficial_24.11.0-trunk_Jetson-nano_jammy_current_6.6.116_minimal.img (4.07GiB) ] [🐳|🌱] Fast-moving file to output/images [ -> Armbian-unofficial_24.11.0-trunk_Jetson-nano_jammy_current_6.6.116_minimal.img.sha (202.00B) ] [🐳|🌱] Fast-moving file to output/images [ -> Armbian-unofficial_24.11.0-trunk_Jetson-nano_jammy_current_6.6.116_minimal.img.txt (19.29KiB) ]
November 7, 2025Nov 7 5 hours ago, tabrisnet said: I can't find that tag in `armbian/build`, but did find `v24.11.0-trunk.303` https://github.com/armbian/os/commits/25.11.0-trunk.367/git_sources.json This file determine state (hash) of sources. It's not a straightforward process, but one can recreate exact image (except userspace packages, which versions are not stored) This file has to be here https://github.com/armbian/build/commit/31e82512cc60a74f56b710aa2971d7dc2beec9b9 One day, this will be done better On 10/23/2025 at 8:45 PM, lyevod79 said: It would be a shame if the Jetson Nano 2 GB ended up as electronic waste. Sadly there is too much of such e-waste and way way too little people willing to maintain them in their limited private time. I am sure you can find a working image somewhere in our archives so you don't need to throw it away, but we cannot fool you & ourselves to be able to keep this board maintained.
July 10Jul 10 Does anyone have an image version 24.11.0-trunk.351? It seems they have been purged. Also, what is the latest working image for jetson nano? Edited July 10Jul 10 by Vlad Maglasu
6 hours ago6 hr On 7/10/2026 at 3:45 PM, Vlad Maglasu said:Also, what is the latest working image for jetson nano? It has latest kernel support with good hw support.https://armbian.com/boards/jetson-nano
