Bas Posted 19 hours ago Posted 19 hours ago Hello OPI5 users. Running Joshua Riek's Ubuntu distro, I keep getting stability issues. Perhaps because I keep using Xorg. Perhaps because hardware acceleration is buggy. In the past I used super stable Armbian OPI5 distro's without hardware acceleration. Infact I still use Armbian on another RK3588 box, I don't think it has EVER crashed, running docker, Mosquito, HomeAssistant, and a buch of other things. Now that my Orange Pi 5 gets a slightly more serious use as webserver, I really like to get rid of the unpredictable Xorg crashes, and gladly would sacrifice HW acceleration for stability. My situation is this: Using JR Ubuntu Because I want to use headless RealVNC (runs only under Xorg) for several devices I switched off Wayland Using a slightly hacked RealVNC server originating from Raspberry Pi Want to use OPI5 as a NodeJS + Nginx webserver serving Node apps now Any suggestions for a super stable uncrashable distro for the Opi5, for server use but with gui? I kind of hate to set everything up again, especially with the internal M.2 sata quirks, but I gotta have stability now. Hopefully I can ask a second question: is there an easy way to totally turn off HW acceleration in JR Ubuntu? Maybe I should try that first... Kind regards, Bas 0 Quote
Werner Posted 18 hours ago Posted 18 hours ago 1 hour ago, Bas said: Using JR Ubuntu We cannot support 3rd party OS. State your questions here: https://github.com/Joshua-Riek/ubuntu-rockchip/issues 1 hour ago, Bas said: Any suggestions for a super stable uncrashable distro for the Opi5 Armbian Though it is not uncrashable. Because no distro could every be, especially for this soc. Basically all distros available using the same vendor bsp, some are even built around Armbians modified sources (just like Joshuas images). 0 Quote
Bas Posted 18 hours ago Author Posted 18 hours ago Totally understand your reply. My experience with Armbian has been very positive, especially WITHOUT hardware accel. In HW accelerated JR I regularly see segmentation faults in Xorg, which make me think whacky chinese mali code is the cause though I'm not sure. Shouldn't segmentation faults be a thing of the past anyway? It should not even be possible except for broken hardware... Bas 0 Quote
royk Posted 16 hours ago Posted 16 hours ago - Using the panthor driver might help, the 6.1.75 kernel with the panthor overlay enabled. - If Xorg is the trouble maker, try wayland with Sunshine server and moonlight-qt as client. - Disable hw acceleration in de xorg config file, although here it never crashed for months 0 Quote
