Hello. I'm having trouble with infrared receiver. Whether the sunxi_cir driver installed in kernel or not, there is nothing in /dev/input except "event0", which is the power controller. Dmesg doesn't show anything neither.
Version: Armbian 4.5 Lamobo-r1 Debian jessie next (unofficial), kernel 4.2.3.
IR support was declared on download web page, so I decided to get vanilla kernel. That's because I had already tried Bananian with 3.18 kernel, and there were huge problems with kernel ppp (up to freezes of whole device).
Has anybody encountered this problem?
I'm using IR receiver with mainline kernel, but as raw LIRC device (/dev/lirc0), not via devinput driver. However I do have input devices created by IR module.
Please load these modules
sunxi_cir
lirc_dev
ir_lirc_codec
and post output of these commands:
dmesg | grep sunxi-ir
dmesg | grep lirc
cat /proc/bus/input/devices
lsmod
Posted (edited)
shows nothing.
 % dmesg | grep lirc
[250575.979154] lirc_dev: IR Remote Control driver registered, major 248
 % cat /proc/bus/input/devices
I: Bus=0000 Vendor=0000 Product=0000 Version=0000
N: Name="axp20x-pek"
P: Phys=m1kbd/input2
S: Sysfs=/devices/platform/soc@01c00000/1c2ac00.i2c/i2c-0/0-0034/axp20x-pek/input/input0
U: Uniq=
H: Handlers=kbd event0
B: PROP=0
B: EV=3
B: KEY=100000 0 0 0
see? there's only the power controller.
  Reveal hidden contents
I already had added the sunxi_cir module in /etc/modules and rebooted couple times.
Edited by wildcat_paris
the spoiler maniac has updated the message
 % cat /proc/device-tree/model
Lamobo R1
however:
 % cat /proc/device-tree/soc@01c00000/ir@01c21800/status
disabled
there is another one:
 cat /proc/device-tree/soc@01c00000/ir@01c21c00/status
disabled
what should I do?
You should recompile /boot/dtb/sun7i-a20-lamobo-r1.dtb, changing "disabled" to "okay".
		ir@01c21800 {
			compatible = "allwinner,sun4i-a10-ir";
			clocks = <0x29 0x6 0x2a>;
			clock-names = "apb", "ir";
			interrupts = <0x0 0x5 0x4>;
			reg = <0x1c21800 0x40>;
			status = "disabled";
Use this post as example: http://forum.armbian.com/index.php/topic/382-armbian-on-pcduino3/#entry2444
Edit: you also need to add pinctrl values and ir0_rx_pins_a label:
		ir@01c21800 {
			status = "okay";
			pinctrl-names = "default";
			pinctrl-0 = <&ir0_rx_pins_a>;
	ir0_rx_pins_a: ir0@0 {
				allwinner,pins = "PB4";
				allwinner,function = "ir0";
				allwinner,drive = <0x0>;
				allwinner,pull = <0x0>;
				linux,phandle = <0x33>;
				phandle = <0x33>;
Thanks. I just tried your dtb file, and now:
okay
dmesg shows this:
[    8.681762] /soc@01c00000/ir@01c21800: could not get #clock-cells for /soc@01c00000/pinctrl@01c20800/uart3@1
[    8.681794] ERROR: could not get clock /soc@01c00000/ir@01c21800:apb(0)
[    8.681850] sunxi-ir 1c21800.ir: failed to get a apb clock.
[    8.681906] sunxi-ir: probe of 1c21800.ir failed with error -2
take note that the source of messages is sunxi-ir somehow.
Thanks. Now it shows devices in /dev/input, however I can not see anything from my RC though evtest. Can this be connected with settings in the dtb file? Anyway, I have to go now, thanks a lot for your help, will continue to work tomorrow, maybe.
First, test your receiver with irrecord, something like this (load lirc modules from message #2 in this topic):
sudo irrecord -d /dev/lirc0 /tmp/remote.conf
If dots are appearing when you start to learn, then Device Tree settings are correct.
Next thing you need to check - if you want to use devinput, you should probably load kernel keymap decoder (Edit: no need, they are built-in) and configure input device to use it. Check
cat /sys/class/rc/rc0/protocols
for list of available and selected (in brackets) protocols, try selecting protocol with
sudo sh -c "echo nec > /sys/class/rc/rc0/protocols"
or something like this.
Edit 2: Or install ir-keytable
Thank you very much, it works. Now I also read through the LIRC documentation and things get much clearer. The only question I have is why there was wrong dtb file. Guess it happens with small community distributions like this. Anyway, thanks again.
Hi,
I tried to follow those steps with the last armbian, and when doing
 sudo dtc -I dts -O dtb sun7i-a20-lamobo-r1.dts -o /boot/sun7i-a20-lamobo-r1.dtb
I got the error:
Hello I have the same issue with Infrared on BananaPi R1.
My device was installed with Armbian_5.00_Lamobo-r1_Debian_jessie_4.4.1
This is the output from commands:
Lamobo R1
disabled
I try to modify  /boot/dtb/sun7i-a20-lamobo-r1.dtb to proposed above value but , it's still not working.
I try to check again the value in /boot/dtb/sun7i-a20-bananapi-r1.dtb and I saw two value are changed strange
pinctrl-0 = <0x2d>;  it was pinctrl-0 = <&ir0_rx_pins_a>;
vabel ir0_rx_pins_a missing on ir0@0
It looks dtc  program change the values.
This is the way how I convert the file.
dtc -I dtb -O dts /boot/dtb/sun7i-a20-bananapi-r1.dtb -o /tmp/temp.dts
vi /tmp/temp.dts
dtc -I dts -O dtb /tmp/temp.dts -o /boot/dtb/sun7i-a20-bananapi-r1.dtb
Additionally I have IR LED transmitter which I intent to connect to some of GPIO , can you help me with that too. I saw in release history , that the image have support for that but I cannot find the module.
LED transmitter driver is working only on kernel 3.4.x , all other info is provided in the link you posted here.
Hello Igor,
Thank you for quick answer , now I'll download Armbian_5.00_Lamobo-r1_Debian_jessie_3.4.110 image.
Can you advice me about the way to start transmitter ? Walking around in Internet , I found only posts about lirc_rpi module where I can set options like modprobe lirc_rpi gpio_in_pin=23 gpio_out_pin=16.
I mean after I connect IR LED , for example to physical pin 10 which is gpio 16 , how to became operational in LIRC , irsend . Until now I make tests few days in Bananian but I get error: hardware does not support sending
Hello
I'm trying to activate the IR receiver, but when I try to re convert the dts I have this error:
ERROR (explicit_phandles): / soc @ 01c00000 / IR0 @ 0 has duplicated phandle 0x33 (seen before at / soc @ 01c00000 / pinctrl @ 01c20800 / i2c0 @ 0)
ERROR: Input tree has errors, aborting (use -f to force output)
I try to use the -f option?
My kernel is 4.5.2-SunXi (SMP) armv7l
Thank you
Resolved with this
