lay Posted November 26, 2024 Posted November 26, 2024 Debian12 gnome Chromium cannot be opened, interface crashes. help,help 0 Quote
Werner Posted November 26, 2024 Posted November 26, 2024 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Igor Posted November 26, 2024 Posted November 26, 2024 3 hours ago, lay said: Chromium cannot be opened, interface crashes Try to update to most recent, try older versions ... If you use EDGE kernels, then you are at the edge and crashing is expected. EDGE is meant for experimenting, trying new HW features. But like @Werner already asked, we need to see logs. Without is not possible to help. For this hardware its recommended to use this image https://dl.armbian.com/khadas-edge2/Noble_vendor_gnome-kisak with preinstalled browser. Anything else is calling for troubles. BTW. This super complex application is developed by https://www.chromium.org/chromium-projects/ and if anyone can debug, are they. 0 Quote
lay Posted November 26, 2024 Author Posted November 26, 2024 chromium.desktop[3120]: *** stack smashing detected ***: terminated Nov 26 06:42:03 chromium.desktop[2990]: [2990:2990:1126/064203.098026:ERROR:gpu_process_host.cc(982)] GPU process exited unexpectedly: exit_code=6 Nov 26 06:42:03 chromium.desktop[3121]: *** stack smashing detected ***: terminated Nov 26 06:42:03 chromium.desktop[3122]: *** stack smashing detected ***: terminated Nov 26 06:42:03 chromium.desktop[2990]: [2990:2990:1126/064203.942006:ERROR:gpu_process_host.cc(982)] GPU process exited unexpectedly: exit_code=6 Nov 26 06:42:03 chromium.desktop[3125]: *** stack smashing detected ***: terminated Nov 26 06:42:04 chromium.desktop[3126]: *** stack smashing detected ***: terminated Nov 26 06:42:04 chromium.desktop[2990]: [2990:2990:1126/064204.018856:ERROR:gpu_process_host.cc(982)] GPU process exited unexpectedly: exit_code=6 Nov 26 06:42:04 chromium.desktop[3127]: *** stack smashing detected ***: terminated Nov 26 06:42:04 chromium.desktop[2990]: [2990:2990:1126/064204.055480:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.ScreenSaver.GetActive: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NotSupported: This method is not implemented Nov 26 06:42:04 chromium.desktop[3128]: *** stack smashing detected ***: terminated Nov 26 06:42:04 chromium.desktop[2990]: [2990:2990:1126/064204.088517:ERROR:gpu_process_host.cc(982)] GPU process exited unexpectedly: exit_code=6 Nov 26 06:42:04 chromium.desktop[3129]: *** stack smashing detected ***: terminated Nov 26 06:42:04 chromium.desktop[3130]: *** stack smashing detected ***: terminated Nov 26 06:42:04 chromium.desktop[2990]: [2990:2990:1126/064204.118118:ERROR:gpu_process_host.cc(982)] GPU process exited unexpectedly: exit_code=6 Nov 26 06:42:04 chromium.desktop[3131]: *** stack smashing detected ***: terminated Nov 26 06:42:04 chromium.desktop[2990]: [2990:2990:1126/064204.133910:ERROR:gpu_process_host.cc(982)] GPU process exited unexpectedly: exit_code=6 Nov 26 06:42:04 chromium.desktop[3132]: *** stack smashing detected ***: terminated Nov 26 06:42:04 chromium.desktop[3133]: *** stack smashing detected ***: terminated Nov 26 06:42:04 chromium.desktop[2990]: [2990:3077:1126/064204.145130:ERROR:zygote_host_impl_linux.cc(279)] Failed to adjust OOM score of renderer with pid 3133: Permission denied (13) Nov 26 06:42:04 chromium.desktop[2990]: [2990:2990:1126/064204.165725:ERROR:gpu_process_host.cc(982)] GPU process exited unexpectedly: exit_code=6 Nov 26 06:42:04 chromium.desktop[3134]: *** stack smashing detected ***: terminated Nov 26 06:42:04 chromium.desktop[3135]: *** stack smashing detected ***: terminated Nov 26 06:42:04 chromium.desktop[2990]: [2990:2990:1126/064204.184185:ERROR:gpu_process_host.cc(982)] GPU process exited unexpectedly: exit_code=6 Nov 26 06:42:04 chromium.desktop[3136]: *** stack smashing detected ***: terminated Nov 26 06:42:04 chromium.desktop[3137]: *** stack smashing detected ***: terminated Nov 26 06:42:04 chromium.desktop[2990]: [2990:2990:1126/064204.199662:ERROR:gpu_process_host.cc(982)] GPU process exited unexpectedly: exit_code=6 Nov 26 06:42:04 chromium.desktop[2990]: [2990:2990:1126/064204.199792:FATAL:gpu_data_manager_impl_private.cc(423)] GPU process isn't usable. Goodbye. Nov 26 06:42:04 chromium.desktop[3009]: [1126/064204.240108:ERROR:elf_dynamic_array_reader.h(64)] tag not found Nov 26 06:42:04 systemd[1900]: app-gnome-chromium-2990.scope: Consumed 4.237s CPU time. 0 Quote
Igor Posted November 26, 2024 Posted November 26, 2024 What about the most important logs? armbianmonitor -u 0 Quote
Igor Posted November 27, 2024 Posted November 27, 2024 Chromium on Debian is reported broken upstream and there is nothing we can do about except forwarding you this information https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=1088162 If you are not an expert, use recommended download options, Ubuntu Noble, where we control Chromium and where it works. Be happy that we are able to provide you that (only working) option. Here you can make a donation. 0 Quote
amazingfate Posted December 10, 2024 Posted December 10, 2024 Fixed by upstream 131.0.6778.108-1~deb12u1: https://packages.debian.org/source/bookworm/chromium 0 Quote
