How Activate UART on Cubietruck
Nicoxygen
Hello, i reinstalled the latest version of armbian with jessie on the cubietruck, on UART0 (ttys0) i plugged in a razberry but since the last version it is not recognized and does not turn on. Is it possible that UART0 is inactive?
I have found on this forum for OrangePi with script.bin but not for cubietruck
Where is script.bin ?
thank you
Link to comment
Share on other sites
You are using modern kernel where script.bin does not have any role. Check docs.armbian.com for device tree overlay ... while uart0 aka serial console should be enabled by default. If not, than we have a bug.
Wrote on mobile
Link to comment
You open the port, modify the script.fex to open the uart3 ,uart4 as below:
[uart_para3]
uart_used = 1
uart_port = 3
uart_type = 4
uart_tx = port:PG06<4><1><default><default>
uart_rx = port:PG07<4><1><default><default>
uart_rts = port:PG08<4><1><default><default>
uart_cts = port:PG09<4><1><default><default>
[uart_para4]
uart_used = 1
uart_port = 4
uart_type = 2
uart_tx = port:PG10<4><1><default><default>
uart_rx = port:PG11<4><1><default><default>
Save the modification.
After the reboot, the uart3 and uart4 are available.
Link to comment
