Banana Pi M1+ Extra Configuration
Hello everybody.
AFAIK Banana PI M1+ share the same costumed Armbian OS with Banana Pro. The Armbian can run pretty well without any changes on my Banana Pro. The problem is, with the same OS image, the on-board WiFi is not working and i can't remember what im doing (what i remember is I do something inside /boot directory), then the WiFi is detected and working properly on my Banana Pi M1+.
My simple question is
What is the right way to configure Armbian for Banana Pi M1+ after installation?
I assume all the default configuration is for Banana Pro and we need some tweak for Banana Pi M1+ especially to enable on-board WiFi and to use GPIO properly.
Link to comment
Share on other sites
The only change is board configuration files, relink /boot/script.bin to /boot/bin/bananapim1plus.bin and if you use mainline kernel add fdtfile=sun7i-a20-bananapi-m1-plus.dtb to /boot/armbianEnv.txt
Link to comment
i use: Armbian_5.25_Bananapi_Debian_jessie_default_3.4.113
and then:
apt-get update
apt-get upgrade
and:
rm -f /boot/script.bin
ln -s /boot/bin/bananapiprolcd7.bin /boot/script.bin
and add
Link to comment
Use mainline kernel, the one which is recommended and it will work. I don't know why it doesn't work in old kernel, which we don't deal with much. It must have been some driver/board settings issue.
Link to comment
Thanks for the tip, that fixed the wifi on my BPI-M1+
On other boards (various H3 based OPIs) armbian supports the wifi straight away, so I'm wondering why you don't include this change in the image?
Anyway, congrats for your distribution, and for your support.
Link to comment
2
Because our resources are underpowered "to fix everything". There are thousands of such small, add-one-line, issues on the task lists and only a few people are dealing with maintenance. A list is getting bigger and bigger while our resources stand still. All those few people also answer questions, develop new features, test, write documentation, ...
And honest appreciations are more or less the only external reward. Thanks!
Link to comment
