I trying to use UART 1 & UART 2 at OPi Zero 2 Plus with no success with armbian stable and ubuntu server. I test all combinations, of fex settings, turn off everything
except required uarts, set uart_type = 2 and etc, and it did not connect. UART0 and UART3 works fine, but I need cts-rts lines from uart2 for hi speed (it's uart_type = 4, but I would like to start regular uart first).
tested with picocom, ft232 & pl2303
I use 8 & 10 pins for uart 1 and 11&13 for uart2 as described at http://linux-sunxi.org/Orange_Pi_Zero
Is it correct pins?
Thanks
