barish Posted December 9, 2015 Posted December 9, 2015 Hi! The jessy vanilla image works fine, but when I boot the Olinuxino Micro with a SATA HDD connected, I don't have ethernet/ssh access anymore. Even reboot _without_ the HDD doesn't work, I need to restore the content of /boot with an SD-card-reader to make it work again. Sorry, I am (yet) not really into sunxi/uboot/kernel topics, so maybe there's a simple explanation to this behaviour?
Igor Posted December 9, 2015 Posted December 9, 2015 My first thing on the check list would be power supply. Is it powerful enough - Can you try with another one? Second thought. Have you finish the installation part? Waited for first auto-reboot? Have you made clean power off? Plug a monitor or serial comm to see what's going on.
barish Posted December 9, 2015 Author Posted December 9, 2015 Thanks for quick reply. The power is fine. I've been running the board with Olimex kernel and SATA system drive for more than half a year now (I've had problems with corrupted storage though so I want to try out a different kernel). Your image on the SD card is working fine as long as I don't boot with connected SATA drive. I am not sure if I can plug in the SATA on a running board, I believe I shouldn't? This would be another approach though. I have now put the original /boot content onto the SD card and could boot with this again. So I have access to all the logs, maybe you have an idea where to look? The onboard LED (green) came on normally, so I think the boot process at least started (but didn't arrive at ssh-deamon start?) BTW, on the SATA HDD, there's a complete debian wheezy installed, but this shouldn't affect the boot process, should it? I ordered a UART-USB interface yesterday, but haven't got it yet, so I have no serial access so far. If I find time I can pull out the board and try to connect it to a screen/keyboard, but at the moment I only have remote access.
Igor Posted December 9, 2015 Posted December 9, 2015 Strange. When you'll have a serial console, edit boot.cmd, change from whatever to: console=ttyS0,115200 and loglevel=7 And paste a boot log. This would be the best way to diagnose what's going on. Perhaps you will solve it when you saw the error.
barish Posted December 17, 2015 Author Posted December 17, 2015 Ok, I finally connected with UART, and there I get a login. Only ethernet doesn't work. The console output during boot: U-Boot SPL 2015.07-armbian-sun7i (Oct 11 2015 - 17:51:25) DRAM: 1024 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 U-Boot 2015.07-armbian-sun7i (Oct 11 2015 - 17:51:25 +0200) Allwinner Technology CPU: Allwinner A20 (SUN7I) I2C: ready DRAM: 1 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment Setting up a 1024x768 vga console Error: no valid bmp image at 66000000 In: serial Out: vga Err: vga SCSI: SUNXI SCSI INIT Target spinup took 0 ms. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst Net: eth0: ethernet@01c50000 starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found Hit any key to stop autoboot: 2 1 0 6944 bytes read in 162 ms (41 KiB/s) switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 1973 bytes read in 201 ms (8.8 KiB/s) ## Executing script at 43100000 0 bytes read in 121 ms (0 Bytes/s) 27924 bytes read in 343 ms (79.1 KiB/s) 5535136 bytes read in 607 ms (8.7 MiB/s) Kernel image @ 0x46000000 [ 0x000000 - 0x5475a0 ] ## Flattened Device Tree blob at 49000000 Booting using the fdt blob at 0x49000000 Using Device Tree in place at 49000000, end 49009d13 Starting kernel ... Uncompressing Linux... done, booting the kernel. Does this help? Is there an easier way to make the SD card working again (with ethernet) then to restore the whole /boot from the image? Via the UART connection?
Igor Posted December 17, 2015 Posted December 17, 2015 You need to alter boot.cmd parameters and recompile to boot.scr ... with proposed changes, otherwise we won't know where actually stops.
barish Posted December 17, 2015 Author Posted December 17, 2015 I'm sorry, I double checked, but this is what I did: I opened boot.cmd with nano and changed (in the setenv bootargs line) console=tty1 to console=ttyS0 and loglevel=1 to loglevel=7, saved the changes, then I entered "mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr" resulting in: Image Name: Created: Thu Jan 1 10:01:13 2015 Image Type: ARM Linux Script (uncompressed) Data Size: 1911 Bytes = 1.87 kB = 0.00 MB Load Address: 00000000 Entry Point: 00000000 Contents: Image 0: 1903 Bytes = 1.86 kB = 0.00 MB and did a reboot.
Igor Posted December 17, 2015 Posted December 17, 2015 Right: console=ttyS0,115200 Wrong: console=ttyS0 Have you waited few minutes at first boot?
pschasch Posted December 18, 2015 Posted December 18, 2015 Hi, on my R1, armbian 4.5 and 4.7 did also NOT boot with SATA connected...( I have a 2A openmoko_:-)-usb-charger ) I had to change my dts/dtb-file wich I compiled on R1 with kernel 4.2.6 for my R1 . sed -i 's/ahci: sata@01c18000 {/ahci: sata@01c18000 {\n\t\t\ttarget-supply = \<\®_ahci_5v\>;/g' arch/arm/boot/dts/sun7i-a20-lamobo-r1.dts crreating and replacing the armbian-lamobo-dtb with my compiled one, my R1 did boot with my and armbian-mailline-kernel again when SATA connected. regards
barish Posted March 7, 2016 Author Posted March 7, 2016 Sorry for not testing for so much time, it was quite a bad situation with the Olinuxino at work all the time. But I have good news: I just downloaded the latest Jessie-image, and the problem seems to be solved, I can boot with attached SATA drive without any issues. Thanks a lot for the ongoing development! 1
