asayed Posted January 9, 2025 Posted January 9, 2025 Hello Developers, I ran into some issues installing the latest release on an Orange Pi 5 Plus. The images I downloaded are as follows: Armbian_24.11.2_Orangepi5-plus_noble_current_6.12.0_kde-neon-kisak_desktop.img.xz Armbian_24.11.2_Orangepi5-plus_noble_vendor_6.1.75_gnome-kisak_desktop.img.xz The KDE version will install and boot from the 256GB emmc drive, however it only works if there is a 4K HDMI monitor attached to HDMI1, I was not able to get it to display on a 1920x1200 HDMI monitor nor a USB connected or HDMI connected portable display (2560x1440). The Gnome version will boot with any of those 4 types of displays (4K HDMI, 1920x1200 HDMI and USB C or USB C to HDMI portable display) so in the end I would most likely install the GNOME version and then add KDE or Enlightenment packages to it since I don't like GNOME at all (20 yrs Debian/XFCE4 user). There is one issue I have with the GNOME version: It does not detect the emmc drive and only the SD card and the 500 GB NVME drives are showing up in gparted and fdisk. I am looking forward to using Armbian on an Orange Pi 5 Plus as my daily desktop and I hope this can be easily resolved. I am open to using either version as long as I can use a portable USB C or HDMI display with less than 4K resolution. thanks -ali 0 Quote
Werner Posted January 9, 2025 Posted January 9, 2025 51 minutes ago, asayed said: The KDE version will install and boot from the 256GB emmc drive, however it only works if there is a 4K HDMI monitor Expected since this image uses mainline 6.12.y kernel which has basic hdmi support at most. 6.13 will bring a few more features but there is still lots of things WIP. 51 minutes ago, asayed said: The Gnome version will boot with any of those 4 types of displays This image uses Rockchip SDK kernel which is almost feature-complete. 52 minutes ago, asayed said: I would most likely install the GNOME version and then add KDE or Enlightenment packages You can use the build framework to create a clean KDE Plasma or Neon featuring image. 53 minutes ago, asayed said: It does not detect the emmc drive Hm. The sdk kernel has been bumped in version shortly after the November release. Please try this image I made for testing if that detects the eMMC correctly: https://fi.mirror.armbian.de/.testing/Armbian-unofficial_25.02.0-trunk_Orangepi5-plus_noble_vendor_6.1.84_kde-neon-kisak_desktop.img.xz 0 Quote
asayed Posted January 9, 2025 Author Posted January 9, 2025 Hi, thanks for the quick response. I never noticed this till now but it seems that even though the KDE and GNOME versions are both at 24.11 the kernels are different. Gnome being at 6.1.75 and KDE at 6.12.0. What's interesting is that the download page says all 5 versions are supposed to be at kernel 6.12 so I never thought about verifying the kernel versions I downloaded KDE 25.02 from the link above and will test it soon to provide an update. There is also a version with Kernel 6.1 on the download page, I suppose I could try that one also. thanks. 0 Quote
Werner Posted January 9, 2025 Posted January 9, 2025 We provide just a very small selection of images for each hw and even that eats a lot into our resources. See https://docs.armbian.com/User-Guide_FAQ/#why-is-there-no-image-for-board-with-bookwormjammynobletrixie-and-minimalclignomekdexfce-with-vendorlegacycurrentedge-kernel However the build framework makes it very easy to combine whatever you want together. Just like the image I provided you https://docs.armbian.com/Developer-Guide_Build-Preparation/ 0 Quote
asayed Posted January 10, 2025 Author Posted January 10, 2025 Hi, If this 25.02 image does not work then I will definitely try the build framework. One quick question: Will the build framework support the GPU drivers for the Mali-610. I know that Debain/XFCe is lacking the hardware drivers and I could not even locate the packages in the Bookworm versions you have available. There is a significant difference in performance (glmark2) between the Debian and the Ubuntu versions and I do plan to do some lightweight 3D apps (Blender, FreeCAD, etc) on the Orange Pi. thanks again for all your help. -ali 0 Quote
Werner Posted January 10, 2025 Posted January 10, 2025 Build your image with ENABLE_EXTENSIONS=mesa-vpu. This will address necessary packages for acceleration, depending on which kernel you choose. For desktop usage I recommend going for vendor branch (kernel 6.1.y to say) as mainline is still under heavy development. 0 Quote
asayed Posted January 10, 2025 Author Posted January 10, 2025 Thanks again. The 25.02 you provided did not find the emmc, so I am assuming its a kernel issue and not an Armbian thing. I noticed 6.13 is getting close to coming out, Fedora claims its on 6.13.0 so I am sure it will be in Debian (tesing/sid) soon enough. I am going to try some Debain or Armbian Bookworm images and see if I can upgrade in place Trixie - its all an experiment anyway for now. -ali 0 Quote
Solution Werner Posted January 10, 2025 Solution Posted January 10, 2025 Feel free to build an image with edge branch which is 6.13-rc...5..ish? I don't remember. Anyway this should give you a good idea about what to expect when it becomes stable after rc7. 0 Quote
